Question about Canon FAXPHONE L80 Laser
Setting I've been trying to set the date and time. However, the set and function buttons are non responsive. Help!
  • Anonymous Aug 07, 2008
    I need to set the date on the fax machine. I don't have a manual.
Posted on Oct 30, 2008
Setting date on Staples SPL-P500 calculator
You press TIME and then you have a button = (it's also written SET on it) press for few second, it will flash, you can now set the date, DD-MM-YYYY than =/SET than TIME again then, =/SET you can now set the time ( the button X / AM-PM to set am or pm) you press =/SET when you're done, and you're set !
Oct 22, 2012 | Staples SPLP500 Scientific Calculator
How to set the date and time
Setting the Date, Time and Date Stamp:
Use the following procedure to change the date and time setting.
1. Slide the Function switch to the capture mode.
2. Press the Mode button twice to turn on function menu. Press the Shutter button to confirm.
3. Press (up arrow icon) or (up arrows icon) to adjust the date and time. Press ◄ or ► to advance to the next setting.
4. When finished, press the Shutter button to confirm the setting; press the Menu button to return to the main menu, press the Mode button to exit the menu.
Jul 07, 2011 | VistaQuest VQ-500 Digital Camera
Setting Date & time
mcdevito75 here, generally you need operate 2 bittons to set your Casio watch, the MODE and SET buttons. Press the Mode button, you may have to hold it in for 2-3 seconds, see the display falshing, press MODe to go to each function, once at the function you want to adjust, press SET press MODE to move onto next function, once all functions are set, press MODE for steady display. If this fails, look for a small watch repair shop in your area for help setting up the watch.
Feb 11, 2011 | Casio Watches
I have a model 31420E skyscan & have lost the instruction manual. Also I live in Sydney Australia and don't know anywhere here to get help.
I couldn't find the manufacturers' web site but I found the following , which may help;-
The unit automatically receives the time signal everyday at midnight and makes any required adjustment to the time displayed.
The WAVE OK indicator and the Tower Icon on the display will show if the time signal is successfully received or after manually pressing the SET/WAVE button
You can trigger a Signal Receive operation at any time by pressing the SET/WAVE button, which will activate the Signal Search function of the unit.
To Manually Set the Clock
To Set the Year and Date
1. Press SET/WAVE button after setting TIME ZONE and DST
2. Press + or - button sequentially to set the year (holding down the button will change the year at a high speed)
3. Press SET/WAVE button to confirm the year set and start the date process
4. Press + or - button sequentially to set the current date (holding down the button will change the date at a high speed)
NOTE: The weekday changes automatically depending on the year and date
To Set the Time
1. Press the SET/WAVE button after setting the calendar
2. Press + or - button sequentially to set the minutes (holding down the button will change the year at a high speed)
NOTE: Once you the press + or - button, the seconds will reset to 00
To set the 12/24 HR mode and the Temperature Mode
1. Press SET/WAVE button after setting the time
2. Press the + button to toggle between between 12HR and 24HR (military) modes
3. Press the - button to toggle between C and F temperature display mode
4. Press SET/WAVE button to confirm and quit the set mode
Dec 20, 2010 | Watches
Date time stamp
The camera must be set in the Postcard mode under the resolution setting (L, M1, M2, M3, S, Postcard) on the function menu. Press Function, scroll down to bottom, then scroll to the Postcard mode and press the Set button.
Sep 07, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
How to set the time and date on an Audi A4 1.9 TDI
For time and date settings you must try the follows:
1. On the instrument cluster display you will find two small buttons at the bottom side. The left button is provided for time and date settings.
2. Pull the button once and you will see the "hour" number in pulse mode. Then turn the button finely on the right side step by step until you set up the "hour" number. When you finished the "hour" number setting you must pull once again the button until the "minute" number come in pulse mode.
3. Now turn the button finely on the right side step by step until you set up the "minute" number. When you finished the "minute" number setting you must pull once again the button until the "day" number come in pulse mode.
4. In the same mode you will set up also the "month" and the "year" numbers. After all settings you must waiting few seconds until display no more pulsing.
Please rate my response! Thanks!
Aug 27, 2009 | 2000 Audi A4
Need to change the time
You weren't precise if the change was due to Daylight Savings Time or just a general need to change the time so I'm giving you the complete set of instructions for changing the time
Setting the Time
Note: Use 24 hour and 60 minute format when setting the time.
For example: 2:00 pm = 14:00.
1. To make changes to your clock’s time setting, you must first put the clock into Program mode. See
section Accessing Program Mode to Update Calendar, Time and DST for instructions. When the
display flashes P1 dAtE, press the ◄ left button until P2 CL oc appears, then press the ● right
button.
2. Press the ◄ left button to choose 12-hour AM/PM display or 24-hour military time, then press the ●
right button.
3. Press the ◄ left button until the correct hour appears, then press the ● right button.
4. Press the ◄ left button until the correct minutes appear, then press the ● right button.
5. When the display flashes the correct time, press the ● right button.
6. The display flashes P2 CL oc again. To make changes to the DST start date or DST end date, press
the ◄ left button one time until P3 BDLE appears in the display and continue to How to Set the
Begin Date for DST. Otherwise, press the ◄ left button several times until END appears, and select
the ● right button to save your updated settings.
How to Disable DST
To disable Daylight Saving Time, set the DST beginning date equal to the ending date (i.e., DST begin
date = 08-03-09; DST end date = 08-03-09).
See next for details regarding setting the DST begin date and end date. Typically, clocks operating in
Arizona, Hawaii and Puerto Rico do not observe DST, and disabling the DST function typically applies to
those areas only.
By default, and unless otherwise modified, DST takes effect on the first Sunday in April and ends on the
last Sunday in October (this was the United States standard through 2006).
How to Set the Begin Date for DST
Note that in 2007 the standard for DST changes to a different start date and end date. The steps below
correct the change in the new start date for DST. The new start date and end date need only be changed
once, since the clock’s rolling calendar function auto-calculates the start date and end date for DST every
year thereafter.
Note that if the begin date for DST has passed, in addition to modifying the begin date (and end date),
you will also need to modify the time.
1. When the display flashes P1 dAtE (see earlier section Accessing Program Mode to Update
Calendar, Time and DST for instruction), press the ◄ left button until P3 bdLt appears, then press
the ● right button.
2. Press the ◄ left button until the correct year appears, then press the ● right button.
3. Press the ◄ left button until the correct month appears, then press the ● right button.
4. Press the ◄ left button until the correct date appears, then press the ● right button.
5. When the display flashes the correct year, month and date, press the ● right button.
6. When the display flashes P3 bdLt, press the ◄ left button once to select next menu option, P4
EdLt, which provides a way to set the end date of the Daylight Saving period.
Setting Daylight Savings Time for model PIX-10/15/21
Page 4 of 4
How to Set the End Date for DST
correct the change in the new end date for DST. The new start date and end date need only be changed
year thereafter.
1. When the display flashes P4 EdLt (see conclusion of previous section How to Set the Begin Date
for DST for instruction), press the ● right button.
6. The display flashes P4 EdLt again. Press the ◄ left button several times until END appears, and
select the ● right button to save your updated settings.
Note: To disable the Daylight Saving Setting, set the beginning and ending date to the same date.
Apr 16, 2009 | Office Equipment & Supplies
Buttons become non functional samsung sgh e250
the problem on it is the keypad connector,, its a small circuit that connect the keypad to the board,, just go to the technician and tell about what i say
Feb 28, 2009 | Samsung SGH-D900 Cellular Phone
Setting month, date, and day of the week on non-digital watch
Try pulling the stem out. Turn the stem in the counter clock wise direction and see if that changes the date/day
Dec 21, 2008 | Watches
Need help with Kenneth Cole Reaction Watch - setting date/time.
for a watch face that has a day of week, date, and moon calendar: There are two click points on the set-pin. pull out 1 click to access date/moon calendar; spin clockwise to set the moon calendar. spin counterclockwise to set date.
pull out pin 2 clicks to set time, just like any other watch
Mar 06, 2008 | Watches
Canon FAXPHONE L80 Laser Logo
63 people viewed this question
old marine
old marine
