Question about Refrigerators
Samsung rl-39 fridge freezer
My samsung rl-39 fridge freezer starts up for 1 minitue then stops and shows rd on the digital display, i have de soldered all the main switches and removed whiskers of metal this has still not solved the problem, should i replace the whole pcb if it is a reed switch problem or should i look at the motor relay?
woodchuck789
  • 4070 Answers
SOURCE: Frost free freezer icing up
It should still be covered under the warranty.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Posted on Sep 02, 2009
  • 3 Answers
SOURCE: Problems with my samsung fridge/freezer SR-L36/SR-L39
is whisker growth like ***** hairs?
Posted on Jun 04, 2008
SOURCE: Samsung SR-L39 fridge freezer switching off
tarsia upatvane
Posted on Aug 30, 2008
farfield
  • 462 Answers
SOURCE: fridge condensation - freezer thawing
OK now I'm wondering are theses numbers your getting 4 -9 the actual temps of the refrigerator and the freezer? and do they feel this cold and correct to you? I know the refrigerator side shouldn't be below 34 or so and definitely not below 32. If this is correct and the numbers are not settings but temps. (Now if you have a touch pad its electronic. If it has knobs it has a separate defrost and thermostat and are electro-mechanical)
If electronic Your control board and possibly defrost control are out.
It would more likely be the sensors going to the board(s) It will both sensors have the possibility of causing your problem. 1 will control the run of the compressor (and this one could and probably is connected to the inside coil) and 1 will control the air damper tween the refdg and freezer compartments, and may turn on the inside fan operation too.
(this would be my first suspect if these are degrees numbers). Look at the thermostat control see if it is attached to the indoor coil (usually the tube leavign the indoor section. If its not attached its not sensing the coil temp and when goes into defrost wala its not senmsing temps like its designed to do. Look for a broken clip or possible a plastic wire tie that holds this sensor in place.
Please get back to me with what you see - find on this look up.
Posted on Mar 18, 2009
  • 534 Answers
SOURCE: The digital display on my rs2555sl Samsung stopped
circuit board controling temp to both fridge and freezer is out. Could have been fried by an electrical surge or just a badcircuit board.
Sorry
Dave
Posted on Jan 28, 2010
Fridge warm, Freezer OK
You will find very good info HERE.
Good Luck.
Mar 03, 2008 | Samsung RS2578BB Side by Side Refrigerator
Samsung fridge freezer SR2028CVW not cooling or freezing
If you have used it since 2004, it probably is worn out.
May 02, 2017 | Samsung Refrigerators
My alarm for "open door" is going off non stop for
For most Samsung and Samsung clones The switch for the light also tells the cpu the door is open, some door switches are two in one so it is possible the light could go out if you closed the door and the switch could still be bad. an easy test would be to remove the switch (with the fridge Unplugged ) and test. the two switches should show closed in one direction and open in the other with one switch on and the other off on many models terminals 1&2 being light and 3&4 bell with no connection between the two switches for most models PS. if the switch is good and good for the 4 terminal ones i would be looking at a bad control board or cold solder joints at plug pins on the board. for modes with a hi low display screen it may also stay in hi. and yes i guess the wires could have gone bad and could be open but that's a very long shot
Apr 19, 2011 | Samsung RB2155SH Bottom Freezer...
Hi cant get my Samsung fridge freezer to turn on - just the letters RD appear in the top digital display Any ideas Thx Dave
hi RD stands for refridgerator defrost ...
prob best to switch of for 5 mins and then put back on - has anyone been playing with buttons at front as this can put appliance into service mode where this code can show up ??
samsung fridge freezer diy channel on toutube
hope this helps ">
Feb 07, 2011 | Microwave Ovens
Digital display on LG fridge just keeps cycling options. Showed "ER" error. Any ideas on how to get it to stop? The freezer is still cold but the refrigertor isn't cold at all
Hello sewing6
Welcome,
You said,
digital display on LG fridge just keeps cycling options. Showed "ER" error. Any ideas on how to get it to stop? The freezer is still cold but the refrigerator isn't cold at all
Try turning the fridge and the freezer off at the controls.
Then turning off the breaker for the fridge for 5 minutes .
then turn the breaker back on and restart the fridge and freezer!
This should reset the system and solve your problem.
let me know how it goes.
Thank You,
Huuum
Please remember to leave a rating! Hopefully a "solved "one.
Oct 12, 2008 | LG Refrigerators
Side by side fridge freezer
Based on your weird display issues I'd lean toward the control board problem. At least that can be "one" of a couple problems...
Feb 01, 2007 | Samsung RS2578BB Side by Side Refrigerator
Refrigerators Logo
309 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
