Question about Compaq Evo N610C Notebook
Non system disk error
My nephew sent me his laptop. he said it was working ok when he mailed it to me but when I turned it on, it gave me a message that there was a non-system disk error. I called him and he said it must have come lose when shipping it to me. How to I fix it?
  • msorgen3 Jul 14, 2008
    How do I open it up to see if the screws came loose?
  • 74 Answers
Well i can say that your nephew is correct.
I should open it up and just look for lose cables.
Usally the screws are easy enough to spot.
make sure that you are grounded when you open it up, for example touch a element before you start working, dont touch your hair etc.
Hopefully its just a cables or else the hardware has gone broken.
Posted on Jul 14, 2008
  • KaffeSumpen Jul 14, 2008
    just whant to point out its not screws you are supposed to look for but loose cables. perhaps it was a mistype on your end but just whanted to make sure.
    usally you open laptops from underneath.
    Be very carefull, as i get the felling you have never done things like this before i would suggest you to call a friend that has some knowledge in computers.
Till this morning every thing was ok, but when I
Working off of my experience with a computer with a flaky power connection to the hard drive and when the drive fails to spin up there no operating system to read. I get the same message. Reach in, jiggle a wire and restart and it's good to go.
You either have a failed hard drive or it is not spinning up, or the operating system on the drive is unreadable due to corruption.
Oct 16, 2014 | Computers & Internet
What do i do when my computer shows the message non system disk or disk error
If your hard disk can detect on BIOS Setup,There is a problem on your hard disk. Whether the installed OS is corrupted or the hard disk itself have bad sectors. Sometimes Master Boot Record (MBR) issue. Try to make fresh install of OS
Feb 23, 2013 | HEWLETT-PACKARD 620 XT964UT Notebook PC
Laptop won'y start up has non-system disk or disk error
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 02, 2012 | HP Computers & Internet
Hello Sir, Vinoth here from chennai. I am using hp compaq nx 6115 for about 3 yr. now i am facing a regular problem in Hardisk. It is not detecting. So i bought a new Wester Digital hard disk 80GB, 6 month...
Check that your cmos mother board battery has not gone flat it should have 3 volts or more when tested .(it is a small coin sized battery on the motherboard not the actual laptop power battery) .this battery keeps the cmos time and settings if it goes flat then settings like time and enable disable and other functions can be affected
I hope this Helps
Andrew. A
Apr 01, 2011 | HP Compaq nx6115 Laptops
Error message
Please check if you have any floppy Disk in you A:\ Drive
If there is not Floppy, Try to change the first boot driver as you HDD in the BIOS
Please revert for further assistance
Thank you for choosing Fixya
Oct 20, 2009 | Compaq Armada E500 Notebook
Non system disk error or disk error when turned on
this happen when the computer does not detect the hard disk, check the cable and power connections of the hard disk
Sep 03, 2009 | Computers & Internet
Magellan Maestro 4250 2008/2009 Map Update will not update my GPS
I also had problems with a refurbished Magellan 4250. The paperwork inside said to install the 4.85 firmware update which I found would not work with Windows XP Home at least for me. I used my laptop which has Vista Ult 32 bit it updated with no problem that is so far the only solution I used.
Apr 21, 2009 | Magellan Maestro 4250 GPS
Non system disk or disk error
This error can be a couple of things. If the "boot block" on the disk has become faulty, the system won't recognize that the disk has an operating system on it and will generate this error message. If the disk is defective completely, the same error will occur. If you have a boot floppy or CD, try re-writing the boot block on the disk. If that fails to resolve the problem, the disk is defective and will need to be replaced.
Dan
Feb 25, 2009 | Compaq Computers & Internet
Issues with my compaq armada
dear mitchiko
did you tried by changing the cables?if the problem still persists than it might be a problem with your motherboard.Contact your vendor then.
Apr 04, 2008 | Compaq Armada 1700 Notebook
Problem with monitor
Hi Gabzie,
Don't worry regarding that the issue regarding the display could be probably you try changing the brightness when you  are plugged with  you power  supply and regarding the non system disk error may at that point of time the system has taken both the hard disk and dvd drive as master that is the reason you have got this message if this repeats then please provide me the serial no. and product no of the notebook and where do you live so that i'll guide you.
Oct 17, 2007 | HP Compaq nx6110 Notebook
Compaq Evo N610C Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
