Question about Indesit 24 in. D61 Free-standing Dishwasher
Strange behaviour! Hi. Our machine has been unused and plumbed in since we moved into the property (18mths ago) and not required its services until recently. After filling with appropriate rinse aid, salt etc.. We choose the appropriate cycle [1. Intensive or 2. Normal], turn on and after approx. 10 seconds the cycle stalls and we hear a continuous ticking sound..!?  We open the door and everything is bone dry! Has any body experienced the same problem? Many thanks
I think it has to do with a faulty program disc. it can't switch to the next program phase. try turning it a bit.
Posted on Aug 18, 2008
We have a Samsung SMH1816S Microwave and about a month ago we had a scheduled power outage. Right after we noticed that every time we open the microwave door, the fan runs. It doesn't sound quite right,...
Likely an electronic component has failed. It sounds strange, but this sometimes occurs to electronic devices that had been previously working just fine -until it is removed from power. When power is restored, the device fails. This type of behaviour is normally associated with power surges, but it can simply happen to electronic devices that have been in service for a while. Have you ever noticed an incandescent light bulb "blow" when you switch the light on? Unfortunately, the controller circuit board will require replacement, which may not be economical.
Nov 12, 2014 | Samsung 1.8 Cu. Ft. Over-the-Range...
Microsoft wireless keyboard 3000
Delete ALL the keyboard/mouse drivers and let your computer re- install the recommended drivers.
Mar 04, 2014 | Computers & Internet
Hi, i have a zanussi timeline 1400 washing machine.. I have recently moved house, and when i went to use the washing machine after plumbing it in, it now says E51 error on the screen.. What is the cause of...
the E51 "motor power triac short circuited" could be a fault on one of the PC boards as triacs are usually on printed circuit boards. This could have blown due to a short circuit somewhere else (like the motor for example) - I would advise that an engineer is required if you can't see anything obvious with the motor.
Jun 03, 2011 | Washing Machines
The basket seems out of balance, makes a strange noise when spinning. The machine is only one year old. Is there a way for me to open the machine to rebalance the basket or make sure something isn't...
It could just be that the machine is not 'balanced'.
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Mar 25, 2011 | Roper Washing Machines
Reg has not been in use for 18mths i want to use
the backup battery has lost its charge, causing the machine to loose it's data. you will need to check the battery, recharge it, then reprogram all data back in the machine.
Apr 28, 2010 | Casio Parts Cash Register PC Desktop
Kenmore 110 Heavy Duty 70 Series Washing Machine won't spin
Can you move the basket by hand...if so you need a basket drive. If not you have a bad clutch or gear case
Jun 07, 2017 | Kenmore 24032\24036 Top Load Washer
Strange readouts on my computer dissplay
THE 2 WARNING ARE RELATEDM U HAVE SOMETHING DAMAGED OR DEFETIVE IN THE TRACTION CONTROL SYSTEM, U NEED TO GO TO A FRONT END SHOP AND HAVE AN INSPECTION DONE.
Mar 11, 2009 | 2006 Cadillac STS
Can't take photographs when flash is on
Hi
The powershot s5 IS does in fact have some strange behaviour issues especially on the first rev firmware. For example if you take 15-20 flash photos consecutively without powering down your camera the flash recycle times will increase to about 15sec, so you'll have to wait about 15sec before you can take another flash photo. The work around is to power down the camera and then turn it back ON. Another strange behaviour is manifested by its inability to lock focus after taking a "no-flash" photo, then popping up the flash and trying to take a flash photo. Again the work-around is to power down the camera, pop-up the flash and then power it back up. Confirmed these behaviours in two other cameras of the same model.
Jul 13, 2008 | Canon PowerShot S5 IS Digital Camera
A530 flash problem
in this model the flash IC becomes faulty if so u should consult an expert.
Sep 08, 2017 | Canon PowerShot A530 Digital Camera
Epson aculaser c 1100
What was the service error code It would look something like Service Required E510. This show on the panel and/or in the status monitor
Without this code all we know is your printer has something wrong with it.
Sep 14, 2007 | Epson Aculaser C1100 Printer
Indesit 24 in. D61 Free-standing Dishwasher Logo
119 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
