Question about Whirlpool EL7ATRR Refrigerator
Placing a refrigerator in the garage
I have been told that newer refrigerators with a freezer on the top (3 years or newer) will not work in an attached garage in any cold weather areas because they will not continue to run once the air has reached a colder temperature. Is this correct?
    Scholar:
  • 62 Answers
IF YOUR GARAGE TEMP GOES BELOW 35 THE REF MAY NOT WORK WELL BECAUSE MOST REF HAVE THE THERMOSTAT AS THE REF CONTROL. THE TEMP IN THE BOX IS SENSED AT THAT POINT AND SHUTS OFF, THE REF SEEM TO WORK BUT THE FREEZER WILL WARM UP.
IF YOU WANT TO USE A REF IN THE GARAGE, FIND ONE THAT HAS THE THERMOSTAT CONTROL AS THE FREZER CONTROL. LOOK AT THE CONTROLS, THE ONE THAT HAS AN OFF POSITION IS THE CONTROL THAT IS THE THERMOSTAT. SO, THE FREZER CONTROL SHOULD SAY "OFF" SOME NEWER REF WITH FULL ELECTROINIC CONTROLS MAY WORK AS THEY HAVE INDIVIDUAL SENSORS FOR BOTH THE REF AND FREEZER SECTIONS.
Posted on Sep 01, 2008
The freezer works but the refrigerator does not work
Could be the fan isn't working inside to send air from freezer section to refrigerator section. If it works for a few days and refrigerator quits could be a defrosting issue.
Jun 16, 2012 | Refrigerators
I have a kenmore model refrigerator freezer model #70982991. It has a top freezer and the mfg. date is 10-00. Right now the freezer part is working but the refrigerator is not. It is used in my unheated...
Lack of freon isn't an issue. Check the internal fan between the freezer and fridge. It is usually located behind the back panel in the freezer. If not there, check upper back of fridge. The internal fan blows the cold air from the freezer to the fridge. When it goes out, the freezer will freeze but the fridge won't cool.
Sep 04, 2011 | Refrigerators
I need to replace the refrigerator from our garage. I bought a simple kenmore with the freezer on the top, only to find out that this type of freezer/ refrigerator will not work in the garage. I need to...
We have the same problem. Sears told us we needed to get a garage kit. It is a small heating element that installs somewhere around the compressor. Cost $20-$30. Just orderd ours today.
Jan 06, 2011 | Kenmore Refrigerators
Would like to put older side by side refrigerator in our garage. I was told in the winter, when it gets cold the freezer side will not keep foods frozen. I had an older top freezer refrigerator in the...
It could be a problem depending on how cold your garage gets in the winter. Most refrigerators depend on the compressor turning on to cool the freezer section and that cold air is used to cool the refrigerator section. If your the temperature in your garage gets in the 30-40 degree range in the winter. The compressor may not turn on sufficiently since the refrigerator is typically around the 35-40 degree range. This will cause the freezer to warm up to the fridge temperature and your freezer items will defrost.
Nov 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Have not run in a year.Cleaned and put in garage.Freezer working great but bottom is not coolong and fan run all the time.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 31, 2010 | Frigidaire FRT17G4B Top Freezer...
Frost free freezer icing up
It should still be covered under the warranty.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 02, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Our garage refrigerator is getting old and we wan ted to replace it. 2 people have told us if a newer one is in an area where it gets 40 ior below we may have problems. True? How old must it be to avoid...
All of the new one will not work well in a garage. Your best bet will be a unit that is more than 7 years old. If you cant find one try a Hotpoint, this is GEs little brother. The hotpoints have an older design. I use one in my garage Model # HTS18GBSWW You should be able to find this at any appliance store around $500.
Jul 24, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Freezer not working in garage top mount freezer on refrigerator
Sears is technically correct. It wouldn't work with the old coolant either. The principle is simple. The refrigerator is the same temp as your garage - it is not running. It must be in a 60 degree room to work properly. The sensor to turn it on is in the fresh food compartment, and it never calls for cooling; therefore it appears you freezer only is out - but they both work together. Hope this helps!
Feb 17, 2009 | Kenmore 64522 Top Freezer Refrigerator
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Traulsen Commercial Freezer needs charging?
The refrigerant level is low. The only thing is that the unit may not have a low charge. There can be several things that cause the unit not to refrigerate properly. It could have weak valves in the compressor or even a bad TXV(thermostatic expansion valve). Have you had this box repaired yet.? I see that this is an old post.
Dec 09, 2008 | Traulsen 24.2 cu. ft. / 685 liter...
Whirlpool EL7ATRR Refrigerator Logo
390 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
