Question about Kenwood Audio Players & Recorders
Replacement drive belts for kenwood cassette recorder kx-w4020
3 Suggested Answers
  • 22 Answers
SOURCE: Looking for source to replace broken cassette drive belts
find something else with the same size belts there just belts don't have to be same kind i'd go a lil smaller then the old ones
Posted on Mar 27, 2008
SOURCE: I need a parts list
Hi 1George I found a replacement belt that works but not an exact replacement. P/N FRM9.6 Flat belt from Gateway electonic in St. Louis Mo. BUT you may have to try and order it from the manufacture www.russellind.com as I had to sort thru a bunch of belts to find this one. It works great. more info. e-mail sales@russellind.com bar code # 3152-00129 Good LUCK tedglow@charter.net
Posted on Oct 18, 2011
Kenwood kx-w6050 dual cassette deck. play, rewind n forward got problems? Whats seem the problem to be?
It needs servicing by a Technician- often times say it only needs belt but you can replace belts and still have the same problem. The dried lub has to be removed and new fresh non- degrading grease needs to go in and then it will work. Dual cassette decks are usually not worth the $200 it will take to work on two mechanisms. You might find a $10/Hr technician but I doubt it.
Aug 07, 2015 | Kenwood Audio Players & Recorders
GE 3-5027 portable cassette player/recorder belts
I have a GE Battery operated Cassette Recorder, model no. 3-5025A and the spinals that turn the the cassette will not turn. I believe I need the 3 tiny belts that make it work need to be replaced. The are different sizes, do you know where I can purchase these belts?
Mar 15, 2014 | General Electric Cassette Recorder &...
Kenwood KX-79 CW dual cassette hook up?
Just connect the deck via tape 1 the out of the deck going to the in of the amp. While the out of the amp goes to the in of the deck.
The tape deck itself will automatically choose the player that plays the cassette. One will play the other will be on pause (if you press both play buttons) till the tape stops then the other will play. For recording from tape to tape one deck will be the copy and the other the copier. There should be a dubbing button which you press to record tape to tape. Some models have a high speed dub also. For recording from the amp unless both decks have record buttons you will only be able to record with one deck. Make certain the dub button is not set.
Dec 25, 2013 | Kenwood Audio Players & Recorders
Looking for schematic for Kenwood KX-55 stereo cassette tape deck
These dual cassette deck are rarely worth he effort to put repair time into. I checked Hi Fi Engine and they did not have anything. Is it worth a $100 repair bill? if not then look for a good solid single deck.
Mar 31, 2013 | Audio Players & Recorders
I have a kx-w4050 dual kenwood tape deck niether side will play hear click and counter moves one then another click. Is there a way to fix this?
Yes, the belts need to be check and idlers or whatever drive mechanism that is used in that system. Dual deck units are among the most unreliable units there are and a reason I tell people for the last 30 years not to buy those things. Almost most of the time they are not worth fixing due to their poor performance at the end. These are facts not just opinion.
Jan 14, 2013 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
I have a Kenwood KX W 4070 double cassette deck. The left hand cassette player doesn't work (I can only play cassettes on the right side recording one.)
The flywheel belt would have broken or gone slack and fallen off the motor pulley. You can confirm this by opening the top and looking inside. If you can shake the machine holding it upside down the belt might even fall off.Replacing the belt is a tricky job. Its like putting back a bicycle chain except there is a metal plate behind the flywheel and your hand won't go there.
Mar 09, 2011 | Kenwood Audio Players & Recorders
Hello I have a Kenwood KX-9050S and the right
Hi, you can check both the motor and the rubber the makes the motor move. you will need to change one of two.
May 19, 2010 | Audio Players & Recorders
Mar 27, 2008 | Audio Players & Recorders
Replacing a belt on the Kenwood KX 1030 Tape Deck
Hi Jeff
You do have to take the front fascia off the unit to get access to the mechanism mounting screws, to then get the mecha into a position that you can remove the capstan flywheel plate etc to replace the belts and clean drive surfaces. You can get an entire replacement belt kit from here
These decks are well worth repair if you have an interest in cassette decks. Good luck, and thanks for using FixYa. If you need more advice , feel free to ask me :)
regards
Graeme
Feb 11, 2008 | Audio Players & Recorders
73 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
