Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Power Surge - No lights on control panel
Hi
over the weekend we had a lightning strike that knocked out my Garage Door Opener. The wall panel has no lights on it. The main unit still has the green light on it, and seems to be powered (it was on a surge protector). The remotes also don't work, nor does the outside keypad.
Anyone got any ideas?
Andy
  • birdnest1008 Jul 14, 2008
    After the storm, our remotes stopped working. the door will still open and shut using the wall button that looks like a normal doorbell. If reprogramming the remotes is the solution, i do not know how to do that. there are three buttons on the remote, one large, one med, and one small.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,001 Answers
  • High-speed,transmission rate synchronization and transfer music, contacts, quickly and efficiently.
  • Flexible cord,lighting cable perfect forevery house hold ,when you want to use your device in bed or other on soft place
  • Durable,with nylon braided,better to protect the cable.
Amazon com Charm sonic 2Pack 4 9Feet 1 5Meters Lightning Cable USB Charger...
Posted on Dec 30, 2016
  • 504 Answers
Was the surge protector one made special for door openers? (it would have lots of connections for safety eyes etc. not just a plug in?
If not you probably have blown safety eyes or circuit board.
Hope this is helpfull.
Posted on Oct 05, 2010
  • 74 Answers
U might need to change Lightning/Power Surge Suppressor the comes inside of ur motor connected between the black and white cables of the power input of ur motor
Posted on Mar 15, 2009
Liftmaster 3265M. Two units. Why does neither work since lightning storm?
Chamberlain Liftmaster garage door opener problems ...
? 3:10
https://www.youtube.com/watch?v=Zq_CxeTXoSM
Jul 2, 2013 - Uploaded by Mike McCarron
Might have taken a lightening strike, knocked out GFCI that was on the circuit that garage door opener was on. When I ... And sometimes after it happens it takes 30 or so seconds before the opener will work again. ... The keypad unit worked well butneither the homelink or the remote units worked.
Garage Door Openers - Lightning Strike - Forum - Bob Vila
www.bobvila.com/posts/30883-garage-door-openers-lightning-strike?...
Aug 6, 2005 - The house did not lose power and I do not believe the house was actually hit. ... the light comes on on the unit (as expected), but neither door opens or ... Afterplugging it back in, try opening the door with the hardwired button first - if it still doesn'twork, chances are your opener's taken some damage but not ...
I Have A Liftmaster Garage Door Opener Unit. The Remote Work ...
www.diyforums.net/i-have-a-liftmaster-garage-door-opener-unit.-the-re.
Jan 01, 2016 | Building Materials
Storm knocked out door opener. There is power to it, but no lights come on on any panel and the lights don't come on. What is the most likely problem? Is there a rest or fuse?
Not sure what your door opener is like but if there has been a local strike, or a power surge , it is possible it has been fried. Probably best to let an electrician take a look at it.
Good Luck
May 30, 2015 | Craftsman Garage Door Opener 1/2 HP Chain...
On my chamberlain liftmaster garage door opener I have to hold the button on the wall to make the door go down how do I fix that
That's easy!....What you,ve got is whats called in the garage door business as constant hold down! You physically have to hold the button to make the door go down because there is a problem with the infrared sensors, Check both sensors on the sides of the garage door to see if the indicator lights are on ...if not check to see that they are aiming at each other and you will be able to tell if they are by the indicator lights , if they are not aligned your door will not come down! That's the safety feature built in in the event your infrared cameras don,t work so you have to physically stand there to make shure nothing is under the door as it is coming down! Also check your infrared sensors wires to the garage door opener in the event one of them came loose from vibration of the machine ! One other possibility can also be that your sensors where shorted by a nearby lightning strike ...the sensors have small computer boards in them that could get affected in the event of a nearby lighting strike so it will send a surge that can fry them , also I have seen when a house has become flooded the boards also short out ...so if you hav,nt had lightning strikes or floods you can eliminate those senarios, but my guess would be they are not aligned so check that first! Glenn installer of over 30,000 gaarge door openers and still counting! Hope this helps you
Mar 12, 2014 | Building Materials
I had a lightening strike at my home. Since then, the garage door does not function with wall switch or remotes. when i press the switch, light comes ON on the door opener and i hear a click but nothing...
Well, I don't think that disconnecting the garage door from the garage door opener would affect function.
The lightning strike could have destroyed the circuitry inside the garage door opener, seeing that it won't operate with the wall switch or remotes.
It's likely that a board was fried by the lightning which would render the garage door inoperable.
Aug 08, 2010 | liftmaster Chamberlain Garage Door Opener...
Chamberlain open light
That light is controlled by a relay on the logic board. The relay must be sticking. This is a problem commonly caused by lightning strikes or power surges. The only cure I know of is a new logic board.
Apr 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Craftsman garage door opener
Replace the logic board. I have seen this problem in the field. More often than not it's due to power surge or lightning strike.
Oct 02, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Garage Door Opener
THE POWER SURGE PROBABLY FRIED THE TIMER CIRCUIT.
CAN YOU TURN OFF THE LIGHT FROM YOUR WALL CONTROL?
THE ONLY FIX I KNOW IS A WHOLE NEW CIRCUIT BOARD. - NOT CHEAP
HOPE THIS HELPS
Jul 10, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman 1/2hp Garage Door Opener
Thats one of the symptoms of a lightning strike or a power surge. Without actually being there I would suggest replacing the back-board. But as with lightning strikes and power surges sometimes other electronic components could have been damaged as well.
Jun 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Light flashing and control won't work
Your opener has been hit by lightning or power surge.
If it's not too old you can replace the 'back board' (the computer board on the back of the opener.) Also If the opener has safety sensors one or both of them may be burnt out too, and if it was really bad then the rpm sensor will go too. So you could be looking at paying half the cost to repair or just get a new opener. Up to you, and get a surge protector. Lift master has a good line of products and makes thier own surge protectors for thier products.
Jun 14, 2008 | Sears Craftsman LiftMaster Chamberlain...
Opener has power but does not open.
The surge probably knocked out one (or more) of the safety sensors.
There may also be a fault on any control board involved.
Each of these components (including the main drive motor) will need checking that they are still working correctly.
Only by a process of elimination will you find the fault. This can be done by checking the outputs of each sensor in turn, and testing operation.
Make sure the system is isolated before atempting this, and ensure a safe working practice is followed.
It's not worth losing fingers over!
Once the fault is found, do not use untill a replacement is fitted.
Hope this helps.
May 20, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
338 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
