Question about Acer Aspire 5100 Notebook
Won't Boot Up
USB ports had stopped working and I was told to reboot holding ALT and F10 to get to the usb port settings.
When I tried this it gets to the Windows screen and then freezes. I can reboot holding F2 for setp no problem although can't see anything in there that would help.
F12 works for boot menu but F8 doesn't work for safe mode so I can't get in.
One other thing I have just noticed is that the screen it gets stuck on says windows XP but I have vista installed. Not sure if it always said that or not although I assume it did.
Any help gratefully received,
Clare
  • 4 more comments
  • clareM Jul 14, 2008
    As far as i know it has vista only.
    I waited about half an hour.
    Its the acer 5100 and is about a year old.
    Thanks
    no it doesn't go past the windows loading picture. I can't get into device manager or anything else
  • GamerBots Jul 17, 2008
    I fixed this same problem using a registry scanner. Here's a link to a good free one:
    www.your-free-info.com/RegCure
    I've used this one and it sped up my computer by quite a bit. Hope this helps.
  • Michael Ortega
    Michael Ortega May 11, 2010
    Ok, so you're only getting to the Windows Vista or Windows XP splash screen? Please clarify which one. I know you mentioned Windows XP before, but I thought that might have been induced through some keyboard key combinations.
    If you boot up without hitting any keys you get as far as the Windows splash screen.
    The progress meter on the bottom half of the screen makes a couple rounds and then the machine reboots? So you're stuck in a rebooting loop?
    MO
  • Michael Ortega
    Not sure what the boot up issue is, but let's backup to the original USB problem.
    Can you go into device manager and uninstall your USB Root Hub drivers? This will more than likely disable your keyboard and mouse as you remove the Root Hubs if the keyboard/mouse are connected using USB. Just reboot your computer after and the drivers should reinstall automatically.
    The windows XP boot thing could be somekind of bootable xp diagnostic partition provided by ACER although I've never seen this.
    Let see what the USB removal and reboot does first.
    Can you boot up into the normal operating system?
    MO
  • Michael Ortega
    Is the machine setup to dual boot with XP or Vista?
    How long do you wait when the machine freezes before turning it off or restarting?
    What model of laptop is this? and how old is it?
    Problem Solver:
  • 9 Answers
  • 31 Answers
When you restart your Computer, hit F11 alot until you get into the Startup Settings.
Choose Format Drive
Let it format
When you start your computer again, you will be all set. But you will lose all of your files, so be careful.
If this helps at all, please give me a FixYa. - Evolution
Posted on Jul 15, 2008
Why is the usb ports of my HP laptop not working?
You can try doing two things. First you can go into the BIOS (F10) and restore to default settings. Reboot. Assuming you have windows vista or windows 7, from within Windows go into device manager and find the usb hub(s) right click and go into properties/advanced. You will have the option to reset the hub. Do it for all hubs. Reboot. If this still does not work, then your option is to have the motherboard repaired or replaced or just get a usb external hub so you can have more ports.
Aug 20, 2014 | HEWLETT-PACKARD ProBook 4520s
OnBoard USB Ports Not Working and No PS/2 Ports!
When you boot the machine does it tell you what key to hit to get into the BIOS or System Setup? If so, press it. Maybe you need to try another keyboard if it won't allow you to press a key to get into the Bios or System Setup.
Apr 21, 2012 | Dell XPS 400 PC Desktop
My Acer Aspire 1 will not boot properly. There ia a small white cursur blinking in the upper left corner. I tried Alt f10 but that did not work:-( Do you have any suggestions?
Reboot (by pressing Alt Ctrl Del) press F2 frequently after reboot to go to bios setting. Make sure NO flashdisk/ thumbdrive plugged in to usb port. Choose hardrive as firstboot (in the bios setting under the boot tab) save the changes and exit
good luck
May 19, 2011 | Acer Aspire One Netbook 8.9" Notebook
Reboot and select proper boot device or insert boot media in selected boot device and press a key what does this mean
This sounds like the starting screen when you re install an operating system on your computer. I would first try to exit out with the ESC key, Exit with out saving. If that doesn't work correctly, try unplugging the Pc and restarting. Hope this helps!
Best Wishes and Good Luck!
May 05, 2011 | Acer AspireRevo 3610U2002 PC Desktop
All the usb ports have stopped working, so my printer/scanner and mobile phone downloads are not accessable, nor is my external hard drive that i back up everything on. Front and back of machine!
You may want to check the BIOS settings; reboot and repeatedly press F2 until the setup screen appears. Check the onboard devices section and make sure that the onboard USB ports are enabled, then press F10, select 'Save and exit'. The system will reboot; check the ports again
Jan 27, 2010 | Dell PRECISION 360 P4 HyperThreading 3200...
Can't enter BIOS
Hi there.
  • Boot the system. Press F2 to enter the BIOS setup.
  • Press ALT-F
  • Press ALT-B
  • Computer will restart and display a message indicating it is re-detecting IDE drives. After a minute or so, Windows will start. Test the device that wasn't working before.
  • If you want to restore other BIOS settings you have set, such as the boot sequence, you will have to restart the computer and enter BIOS setup again.
If this does not work try another usb keyboard in the same port.
Good luck and thanks for using FixYa!!
Apr 22, 2009 | Dell OptiPlex GX280 PC Desktop
Acer Orbicam does not work anymore
Sounds like a driver went astray.
Normal 0 Try disconnecting the Camera from the USB port and reinstall the CD software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Jan 07, 2009 | Acer Aspire 5610-4648 Notebook
Usb ports not working
TRY DISABLING USB'S IN BIOS BOOT THEN REBOOT AND ENABLE.RICHARDM69
Jun 06, 2008 | ASUS P4GE-MX Motherboard
Acer Aspire 5100 Notebook Logo
205 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
