Question about Dryers
Maytag ldg610 flame starts ...lasts for 2 min. and goes out. never comes back on
  • 525 Answers
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
Clicking on the underlined links will take you directly to that page.
The most common failure mode is the gas valve solenoids and from your description, I would recommend replacing them. The link below will take you to the page that shows the coils and their price. Still very well worth it since you obvoiously take care of your appliances, due the age of the dryer.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=2780&PPStack=1
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 14, 2008
Heat will only heat for a few mins.
I would check the flame sensor and use steel wool clean the flame sensor or if you have a thermocoupler I would check that
Jan 21, 2018 | Heating & Cooling
Flame ignites and stays on for @2-3 mins and then goes out and will not re-light
Sorry to read about your problem, I hope this helps you out.
you may have a defective flame sensor
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Maytag Dryers
My Maytag MDG7600AW gas dryer doesn't dry clothes any more. It take over 3 hours to dry at first. but now it won't dry any more. After reading the posts here, I open up the front panel and clean up all the...
The problem is the dryer coils are failing. They tend to fail as they heat up.There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Apr 23, 2010 | Maytag MDG7600AW Gas Dryer
Flame goes out when fan kicks on
If the flame lights all the burners within 2 seconds but does not stay on, you may need to clean the flame rod found at the farthest end of the burner box. It will be located at the end of the box that lights last. It will be a probe that is in the flame of the last burner. If it has carbon on it or scale, take an old tooth brush and scrub it. Check the wire connected to it and follow that wire back to the circuit board and check that connection.
Dec 11, 2009 | Goodman Heating & Cooling
Gas burner only stays on for 5 seconds off 1 to 2 min.taks two hours dry clothes
No air flow. Blocked venting , Blower wheel broken or cloged. Check to see if the air is blowing out side at your vent. If your ingitor comes back on but no flame your gas coils are no good.
Nov 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Clothes not drying properly
Consider a blocked air flow/vent problem or bad gas valve selonoids. Important to check outside vent door if present to make sure it is opening all the way. If not the dryer goes off on thermal overload. If vent is clear consider selonoids located on top of gas valve held in place with 2 philip head screws. One has a two prong electrical plug and the other has a three. Last check Lp tank for gas. Thank you
Jun 01, 2009 | Dryers
Heater lights fan comes on flame goes out
There is a flame sensor located in the same area as the ignitor (usually on the other end of the burners). remove the flame sensor with the power off. Then use steel wool or light sand paper to clean the silverish end. Reinstall the sensor and ToDA you are done! Best of Luck!
Jan 29, 2009 | Goodman GDS80904BNA Open Flame Heater
Furnace pilot problem
check the pilot gas pressure, might be too weak and blowing out when the blower starts, the clicking noise is the gas valve shutting down when it detecks no pilot flame, that park is normal.
Jan 10, 2009 | Honeywell Power Humidifier: Furnace...
Maytag gas dryer fires, then shuts down
may be the coils on the gas valve. there are 2. usually they need replacing when the ignitor glows but no flame
Nov 20, 2008 | Maytag Dryers
Dryers Logo
81 people viewed this question
Top Dryers Experts
