Question about Refrigerators
GE PROFILE REFRIGERATOR: ALWAYS RUNNING...FAN IN THE BACK DO NOT WORK
  • Anonymous Dec 20, 2008
    Our profile is almost always on.  We can always tell because it seems unearthly quiet when it shuts off!
  • mcfakd Feb 23, 2009
    I have had my fan replaced twice - the noise it made was ridiculously loud and would come on in the middle of the night keeping us awake. I have had the new fan in for a full week now and I do not think it has turned off - though it is much quieter. Also, the fridge has not returned to the set temp yet, it always is running warmer than the set temp - even after 12 hours of no doors being opened. The fridge is only 14 months old and the problems started 8 months in.
Sea Breeze
  • 4654 Answers
SOURCE: GE profile refrigerator line freezes, fan blows but no cold air?
OK, I think I understand. Thing is we need to do a few things to see if your control board is the problem or if the fan or a freon leak is the answer. You need to tell me if this began suddenly or if over a period of time. I have been having trouble lately from Fixya if the customer (YOU) responds to my solutions. Let me know if you want my help and I will see if I get a email letting me know of your response, Thanks, Sea Breeze
Posted on Jul 12, 2009
woodchuck789
  • 4070 Answers
SOURCE: ge profile refrigerator door stop isn't working
Did it ever work or for some reason you never noticed it before? I've had to swap the door stops to get the door to stop. They can usually be swapped around according to what's needed in different situations.
Posted on Jan 20, 2010
SOURCE: have a GE profile model # PDE18LBRARSS
We have the same fridge and same problem.....our fan is freezing up. We have had to take the bottom panel out and use a hair dryer to melt the ice around the fan (serveral times!) I dont know what the solution is or why this is happeneing (we have the temp set very low).
please help.
Posted on Mar 21, 2010
  • 19 Answers
SOURCE: Ice maker in our GE profile refrigerator is not working
Ice maker Diagnostic Test:
- Remove the ice bucket
-Turn the ice maker off, wait 15 seconds than turn it back on
-Press the ice paddle three times, this will begin diagnostic test.
-PLEASE DO NOT TOUCH ICE MAKER DURING DIAGNOSTICS
-In 3 minutes you should see the rack inside turn 360 degrees
-AND the ice maker bowl should fill with water
-IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A service call is approx $80. The $80 will be deducted from the part/labor if you choose to purchase/install parts from the service technician. If not, you will pay for the service call. Good luck.
Posted on Apr 05, 2010
SOURCE: ge profile psc23pswa rattling noise
I have the same problem. For me though, it's not the fan (I cchecked it as suggested). It appears to be the ice maker. The noise stops when the freezer door is open. The ice cubes are also not great (hollow). I think we had this problem before and it was a problem with the water line being frozen. Any suggestions?
Posted on Jun 10, 2010
Ge profile bottom freezer model # PGSS5NFXA SS. Got up this morning and freezer thawing both fridge and freezer same
Not sure if the compressor is running. If not, you'll need a repair man. Since fans are running, most likely the thermistor. Also, if you haven't unplug from the wall, wait 10 seconds then plug back in; this may reset the control board. The link below may help. GE Refrigerator Not Cold Enough
Feb 03, 2015 | GE Refrigerators
GE Profile Side-by-side Refrigerator TFX28PBBABB
Most ge have a Multispeed fan control on board. But if you had to start the fan with your hand, I would guess it would be a fan issue
Sep 08, 2012 | GE Refrigerators
Freezer will not freeze. Fan is always running
pull the ref out from the wall remove the back panel and see if the condenser coil is dirty if so unplug the ref clean the coil and place a fan behind the ref for 1 hour to cool the compressor then plug it back up give it 24hours to get back into cycle
Nov 18, 2010 | GE Profile Arctica Stainless Steel Top...
GE profile refrigerator model # PDS22SCRRS not cooling. I looked in the back and condensor fan is not working. Should I assume that it needs a new motor or is it possibly the motherboard which I have read...
Check to see if you have 110 volts at the motor with the compressor running. If you do then your motor is bad - replace it. Also make sure something has not gotten in the fan to keep it from working. The fan must run to keep the compressor cool and from over heating. Be sure to put the back of the refrigerator back on when you are through.
Jul 20, 2010 | GE Profile PSW26P Stainless Steel Side by...
Have GE Profile refrigerator Quit Working
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 21, 2009 | Refrigerators
Fan in freezer under ice maker won't stop running.
Hi yes the fan blade could be hitting the shield or ice, remove the fan cover & check
Dec 23, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Profile Stainless Steel Top Freezer Refrigerator
Check the compressor.
Unplug for 15-20 min. plug it back in and listen for the compressor to start. You will have to be behind the ref to listen and make sure you hear the compressor start and not just a fan running. If you hear a clicking noise then the compressor relay is bad.
Dec 16, 2008 | GE Profile Arctica Stainless Steel Top...
Always defrosting GE Model 20
clean the condenser coils at the back and make sure the condenser fan by compressor is running if is not running you mightg need to call a tech to trouble shoot it or if you want repl both the motor and main board like i said you might need a tech to trouble shoot it
Oct 16, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Profile does not run.
Just to be sure... check your owners manual to see if this unit has a "showroom switch". It's a little switch that turns off the compressor, etc. but lets everything else light up so the sales persono on the showroom floor can show it off. Some customers have hit the switch to "on" during cleaning by accident.
Sep 29, 2006 | GE Profile PSS26NGS Side by Side...
Refrigerators Logo
705 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
