D-link model dl624s don't have cd, using zd1211b ieee 802.11 b&g usb adapter on laptop / need step by step instructions for laptop using windows xp, in windows connections window, two lan or high speed items are listed, top one is "wireless network connection 2" second one is "1394 connection" when i select "create new connection" i get wizard but i do not know what choises to make on connection type and so forth help ps
    Guru:
  • 1,342 Answers
You can download the User's Manual and Installation Guide for the dl 624s HERE
Posted on Jul 14, 2008
I need pa3758u-1mpc wireless driver.. any help?
Maybe you don't. In control panel go to Device Manager. Click on the little arrow next to Network adapters. Right click the adapter and uninstall it. (don't delete drivers if asked) Then re start your computer & see if that repairs the bad driver.
If that doesn't fix it,(YOU MUST USE SOME WAY TO GET ON THE INTERNET) (plug in to your router or use a portable usb wifi adapter) repeat the same steps & rt click the adapter & Update driver & select Search automatically (not find on this computer) . It goes on line to Microsoft & it searches it's driver base & finds the proper driver & installs it. If it either finds a better driver or says you have the correct driver & still doesn't work you have a physical problem with the wifi adapter on the mother board. then you need to use a USB wifi adapter like this one. rt click & open in a new tab to view
Trendnet N150 Mini USB Wireless Adapter - IEEE 802.11b/g/n, 2.412 ~ 2.484GHz, 150Mbps, WPS, USB 2.0 (T156-2502) 1 $9.99 $9.99
Oct 04, 2014 | Toshiba Satellite Computers & Internet
I have lost my CD installation software of Belkin N wireless USB network adopter. now i need it to reinstall it .so, can you tell me that how can i reinstall it without CD installation software.
You just need to go to the BELKIN Support website and select your exact model of USB adapter as well as the operatin system that your computer is running. Here is the link to the support website:
http://en-us-support.belkin.com/app/product/list/q/network-adapters/session/L3RpbWUvMTMwMDgyMzYzOC9zaWQvanJ4bV9BcGs%3D
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated.
When you find the driver for your model of USB adapter, just download the file and run it, then follow the onscreen instructions to install your USB adapter.
Good luck.
Mar 22, 2011 | Belkin Play Wireless USB Adapter (F7D4101)
I have the router but no istructions on how to use it?
Here is a link which shows step by step instruction
TP Link router setup instruction
Hope fully it will resolve your issue
Mar 11, 2011 | AGPtek TP-Link TL-WR340GD IEEE 802.11g...
How can I get Windows 7 Movie Maker to recognise input from my Sony DCR TRV18E Handycam?
On page 230 of the user manual, it describes how to transfer movies from the camera to a computer using an i.Link (IEEE 1394) cable. You will need the 4 pin i.Link cable and an IEEE 1394 connector on your computer in order to do this. You cannot use the USB cable to transfer the video from this camcorder -- you can only transfer still images using the USB cable.
You will have to buy this i.Link cable and (if you don't have a IEEE 1394 port on your computer) a IEEE 1394 adapter card for you desktop computer. If your laptop computer doesn't have a IEEE 1394 adapter, then you're pretty much out of luck.
Once you have the i.Link and 1394 issues resolved, then Movie Maker should then recognize the camera.
Dec 27, 2010 | Sony Handycam DCR-TRV18E Mini DV Digital...
I bought AE1000 wireless N USB adapter, and i cant get it to install, says "wireless adapter setup requires that wireless connections are managed by Microsoft windows, says to try the following,...
When you insert the setup disk on your computer, you can exit from the setup and then connect the adapter to the computer and a new window will popup "Found New Hardware Wizzard" and in that select the option "Install the drivers Automatically" and click on next, so it will automatically search for the drivers and install it on your computer... Once the drivers are installed on your computer then you can try to connect to your wireless network.
Setup
The Linksys AE1000 Wireless USB Adapter helps you connect your computer to a wireless network for quick Internet access. Installing the Linksys AE1000 is fairly easy. Just follow the steps below in setting up the Linksys AE1000 on your computer or laptop.
Minimum system requirements
- A computer with 1 GHz or faster processor.
- 512MB or more RAM.
- An available USB port.
NOTE: The Linksys AE1000 is supported for Windows 7, Vista SP1 and XP SP3 but NOT for Mac.
Step 1:
Insert the Setup CD into your CD-ROM drive.
Step 2:
Click Set up your Linksys Adapter. Proceed to Step 4.
If you do not see this, click Start on your computer and click Computer. Double-click on your CD-ROM drive. Continue to Step 3.
NOTE: For Windows XP, the file may be known as Setup.exe.
Step 3:
Read the License Agreement and click Next.
Step 4:
Insert the Wireless USB Adapter into a USB port on your computer or laptop.
Alternatively, you can also use the USB Extension Base to connect the Wireless USB Adapter. Plug the Wireless USB Adapter into the USB Extension Base and connect the Base to a USB port on your computer or laptop.
Step 5:
If you have an Easy Setup key, select Yes, I have an Easy Setup Key and click Next. Proceed to Step 8.
Otherwise, select No, I don't have an Easy Setup Key and click Next. Proceed to Step 6.
NOTE: For more information on Easy Setup Key, click here.
Step 6:
Select your wireless network and click Next.
Step 7:
If prompted, enter the wireless password for your network. Proceed to Step 10.
Step 8:
Follow the on-screen instructions. Click Next once you have completed the on-screen instructions.
Step 9:
The installation is complete when you see the screen below. Click OK.
Step 10:
You are directed to the Cisco Connect screen. Click Close to exit.
Nov 04, 2010 | Linksys AE1000 IEEE 80211abg IEEE80211n...
I have a laptop running 802,11 g/b and vista and I Cant connect to linksys wag160n wireless router(802,11 n). laptop sometimes recognises network but when I try to connect it wont. could you help ?
Hi, You cannot connect across wireless protocols. In other words to connect to 802.11 n you need an "n" adapter.
Now, the router should be backward compatible & provide wireless g/b but you may find that when you search for networks it will be listed as a seperate network name (from the same router)
Try searching for this other network. Your router documentation should advise you of its default name & any set up process
Dec 23, 2009 | Acer Computers & Internet
How do i install the 2wire usb wireless adapter without the cd?
Got to:
http://drivers.alege.net/6924/2Wire-80211g-USB-Wireless-Adapter-Driver-Windows-98SE-ME-2000-XP-download.html
and download the free self-extract installer - twwgusb_2.3.1.3.exe
READ the Readme_first.txt and follow the 2-step instruction.
NO NEED FOR A CD!
Aug 06, 2009 | 2wire (1000-100052-000) 802.11g/b Wireless...
How do you install wireless usb adaptor
A wireless USB adapter is a simple device that connects to an open USB port on your computer or laptop, allowing you to connect wirelessly to a network that is within range. They come with different connection speeds, ranges and security protection allowing you to connect to the Internet and use email servers, without complicated setups. Installing USB adapters to a computer is a simple task that anyone can perform. With just a few steps, you can access wireless networkmag-glass_10x10.gif where there is one.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Moderately Easy Instructions
  1. Step 1 Research around before purchasing a wireless USB adapter. There are many different networking companies such as Belkin, Netgear and Linksys (see links in Resources). Compare prices and features such as speed in megabytes per second (mbps). Look for wireless USB adapters with a compliance of IEEE 802.11b or IEEE 802.11g. These options give you increased security on your network.
  2. Step 2 Plug your purchased USB into a USB port on your computer. Depending on the chosen model, you may have an installation CD. Place your installation CD into the CD-ROM on your computer, and follow the setup instructions to install the wireless USB drivers. Some adapters will install automatically.
  3. Step 3 Locate the wireless icon on the lower right of your computer screen. If there is an "X" marked on it, use the manual that comes with your purchased wireless USB adapter to configure it properly. The wireless icon usually lights up when a wireless connection point is detected.
  4. http://www.microsoft.com/windowsxp/using/networking/setup/wirelessadapter.mspx#2
Dec 11, 2008 | Computers & Internet
Learn to connect wireless usb adapter
Hello raab2011,
On the wireless usb, you connect it to a USB port on the back or side of your computer normally. What kind of laptop do you have? When you do this you need to follow the wireless adapter instruction manual and have the CD in your laptop.
1). Put CD in your laptop
2). The hardware wizard comes up
3). It will step you through when to plug in your adapter.
4). Follow the steps on the screen to install it.
If you have any questions. Feel free to respond to this.
Kay
Jackson Communications
Aug 02, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Computers & Internet Logo
159 people viewed this question
David Payne
David Payne
