Question about Brother Office Equipment & Supplies
All cartridges have ink but will not print black
Fax machine will not print clear copies, have cleaned several times
  • 134 Answers
You may need a new printhead. This is service center replaceable item. Best to find your local service center at Brother usa.com
Posted on Jul 14, 2008
Copy result is blurred
Does the printer scan OK?
Is the platen glass clean?
Dec 10, 2013 | Epson ME OFFICE 620F MULTIFUNCTION INKJET...
My fax keeps printing the same fax continually. I have checked the other end and there fax is all OK. How do I make it stop?
It may be they have been sending the fax several times using ring back, if you go into the menu there is a setting to clear memory this should stop the copies.
Jul 18, 2011 | Brother FAX-2920 Plain Paper Laser
How do I turn off protocol monitor on sharp fax model fo-235
Had exact same problem on UX 177. You need to clear the memory. On the UX 177 unplug machine, press and hold down the COPY button then press and hold down the STOP button. Keeping these two buttons pressed plug machine in. It should display message "clear memory ?" let go of the COPY and STOP buttons and press the START button. Will then display message "memory cleared". This will also wipe out all other programming but it is the only way to stop protocol report. Then reprogram all your settings.
That stopped protocol report printing after each fax. On some machines it may be the stop and start button the need to be held down on startup. It also seems to make a difference which button you push first even though machine is unplugged.
This problem returns after a power failure so if you have a lot of numbers programmed in you might want to get an inexpensive uninterruptible power supply or plug fax into UPS for computer if you have one.
Mar 03, 2011 | Sharp Office Equipment & Supplies
Copying problem
Vertical lines on the copy usually indicate a dirty drum or Corona wire. The Corona wire should be cleaned each time you replace the toner cartridge. This is done by moving the Corona tab back and forth across the wire several times to clear it of debris. You may also want to check the drum for debris. Holding the copied page to where it feeds out and lining up the line or mark on the page will give you an idea as to where the dirt may be. Best of luck with your printing issue.
Greg
Nov 04, 2009 | Brother IntelliFAX 2800 Laser Fax
Text is not printing clearly.
Change the photoorganic drum and the cleaning blade,if the cartridge is refill 2 or more time change the cartridge.
Sep 07, 2009 | Office Equipment & Supplies
Sent faxes not printing clear
Per Brother's User manual,
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_4100_4750e_5750e_EN_98.PDF
Clean the machine’s interior and the primary
corona wire of the toner cartridge This is a common cause for your printing/copying problem. This should solve your issue. Best of luck.
Greg
May 20, 2009 | Brother IntelliFAX 4100 Laser Fax
Dirty copies.
Does this streaking problem occur when printing (not copying)? If it does then you are probably looking at a consumable issue. Alot of times black streaking is caused by a defective or spent drum. Is your drum new? There is also a blue piece on the drum unit used to clean the corona wire that cleans the drum. Have you tried moving it back and forth several times?
If the problem only happens when copying and the streaks are as bad as you make them out to be then you problem have a bad CIS unit (scans your originals for faxing or copying)
Inkworks
866-381-0541
Nov 21, 2008 | Brother IntelliFAX 4100 Laser Fax
How can I get the fax and copy to print clearly?
Still sounds like a bad ink cartridge, try cleaning the bottom of the cartridge with a Kleenex and soapy water. Dry it off real good.
Look where the cartridge sits and clean the same way.
Ink jets are dead technology.
Nov 11, 2008 | HP 640 Inkjet Fax Machine
Clear vertical lines when printing that do not clear up by shaking toner
does it do it on copies and internal test as well???
1- check the thin strip of glass inside the machine and make sure it is clean, look at the toner are there any line on there that corresponds?? yes then replace.it could be coming from the drum or toner. I beleive the drum is a seperate piece from the toner
Aug 27, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
26 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
