Touch screen on a spot and it actervates another spot
    Problem Solver:
  • 27 Answers
This screen either needs to be calibrated, or it could be damaged
Posted on Jul 14, 2008
Install hot spot in galaxy prime core
From the Home screen, touch Apps .Touch Settings .Touch More networks .Touch Mobile Hotspot.Touch the slider to turn Mobile Hotspot on . If you are connected to a wireless access point, you will be disconnected before you can use the hotspot. Touch OK to continue. The Wi-Fi hotspot icon is displayed at the top of your screen when the hotspot is on.
Mar 11, 2016 | Net10 Samsung Galaxy CORE Prime 4G with...
How to fix blank spots on the screen that get worse when you touch the screen?
do you still have a complete picture ?,are the lines coloured,?
do the lines go from left to right or do they spread out from the blank spot in a circular direction like the suns rays?
from your description above i am sure you are describing a broken lcd screen,if i am right there is no repair feasible for this set..
Len
Aug 31, 2014 | LG 42PC3RA 42 in. HD-Ready Plasma TV
What does calibrating a ipad mean
Whoever used the term "calibrating an iPad" may have been referring to touch screen calibration.
Some touch screens need to be adjusted, or "calibrated", or the device may act as if you touched a different spot on the screen than you did. The iPad screen does not need to be calibrated.
If the iPad make a mistake about what spot you touched, the error may be due to:
  • a defect or damage;
  • a screen protector;
  • a cold finger;
  • a hand that is holding the iPad and inadvertently touching the screen;
  • a finger that is inadvertently touching the screen.
Apr 26, 2012 | Apple iPad (16 GB) WiFi Tablet PC
Ihave a touch diamond 2 and the touch screen wont function properly. I touch it on one spot and it clicks somewhere else on the screen
TOUCH SCREEN
the touch screen of the phone you are using is weak and it is not responding properly again.
in other to resolve the problem,you will need to replace the touch screen with a new one.
For touch screen replacement , Contact a technician.
Take car
Jun 24, 2010 | HTC Touch Diamond2 Smartphone
I think i bumped my corby pro and now wen i touch the screen it responds but i also get some spots on the screen wen i touch it. no matter wer i touch the spot appears at the center
well you have done the damage when u dropped your phone so really no one can actually help you!
But you could go back to the store you got it from and just nagotiate a deal!
Apr 16, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
A sun spot on the screen?
Sounds like you literally burned the screen. You can get replacement parts here http://www.ifixit.com/iPod-Parts/iPod-touch
-=/ Daft Tech /=-
Oct 27, 2009 | Apple iPod touch
My Htc Touch pro screen, looks like it has a large wet spot in the middle, i know for a fact it hasn't been near water, my screen is totally visable but not able to use by touching the screen, what could...
I suggest taking it to your compaany store but before you go to the store and have them tell u the phone is water damaged, you can save yourself the trip by looking for yourself. There should be a little square located in the back of you phone right below the battery and a little square locatedd on the batery where it connects to the phone. If the phone has water damage then the littl e squares should be red if they dont have water damage, the squares should be white with a plaid kind of design.
Jun 17, 2009 | HTC Touch Pro Smartphone
Iphone screen smashed, touch still works but white spots
If hard resetting and restoring it doesn't work you have a broken LCD screen. There is an iphone repair guide website that shows you how to replace the screen yourself.
Mar 18, 2009 | Apple iPhone Smartphone
White oval spot in center of screen on garmin 2720 gps
The touch screen is made up of several layers. A thin plastic layer, a micro thin metal layer, microdots for insulators, another thin metal layer, and a final plastic layer. All of these layers amount to the thickness of a sheet of paper. This whole stack is bonded to a thin sheet of glass and placed over the actual TFT display.
If the touch screen is still working the moisture probably isn't between the layers. My guess is moisture got through one of the gaskets and made it's way in between the touch screen assembly and the TFT display.
If you want to clean it:
Remove the six screw holding the case together.
Split the cases and pull the patch antenna out of it's slot.
Remove the four silver screws holding the display assembly into the front bezel.
Unhook the small ribbon cable that goes to the infrared receiver under the red lens.
Pull the display assembly out of the front bezel. It won't come all the way out because of cables.
Use a razor to cut the plastic tape holding the touch screen bracket to the TFT display.
Unlatch the 4 conductor ribbon connector nestled between the 2 big white wires.
Use a penknife to unbend the metal tabs keeping the touch screen from coming loose. I usually just do the ones by the IR receiver.
Now that the touch screen is in your hand you can carefully clean the moisture from between the two assemblies. The gaskets are tricky to install again but it can be done, maybe you'll see where they were leaking.
Jan 18, 2009 | Garmin StreetPilot 2720 GPS Receiver
A magnet touched my screen
My son touched my television screen with a magnet in two spots leaving two discolored areas on the screen,purple and green in hue. I read many quick solutions to this problem on the net and none seemed to work completely,so what i did is took the same magnet that touched the screen and held it in my fist,then with TV on i waved my fist all around the screen working from the spots outward to the edges and this worked completely! Hope this helps someone..
Apr 04, 2006 | Sanyo DS27800 27" TV
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
