Question about Casio Cameras
I dropped my Casio EX-S880 and the plastic panel on the end of the camera nearst the lens has broken. This panel is screwed on using 2 screws so i wondered whether i could order it somewhere as a spare - Any ideas?
Called Casio UK and orderd as a spare part Tel 0208 208 9567.
Posted on Jul 15, 2008
Overexposure for pix mode.video seems okcamera 2 yrs old casio EX-S880
Check your "exposure compensation" setting. It should be at "0". You can set it lower if your pics are still overexposed and see if you can find a setting you like.
Jul 01, 2010 | Casio Exilim EX-S880 Digital Camera
I have a casio exilim camera and its been dropped a couple of times. Now sometimes it appears blurry and only takes about 5 pictures out of 20. Also, it erases pictures automatically sometimes. Is this...
I would consider buying another camera because everything is mechanical inside so chances are the parts inside were damaged when the camera fell that could result in damage auto focus, damaged lens, internal motors and such etc.
Aug 08, 2009 | Casio Exilim EX-S880 Digital Camera
Dropped my exlilim ex-s880 in the sand and can view pictures only
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 06, 2009 | Casio Exilim EX-S500 Digital Camera
Battery Problem Casio EX-S880 Digital Camera
Ive had this happen twice. The first time I went back to the store and talked to the tech people to see if it was a problem with the camera itself but ended up buying a new battery. About a week ago, I finally found my charger to plug in the camera that I hadnt used in weeks to find the same problem once again. It must stem from long periods of non use. After finding this question I continued my research and the Casio website tells you to call 1-800-435-7732. Dont know if that helps much but I will be calling them in a little while. Good luck.
Mar 08, 2009 | Casio Exilim EX-S880 Digital Camera
Casio Exilim EX-S880 will not turn on
The problem is the spring terminals inside the camera are not making good contact with the battery. I had to use a screw driver and gently push them to the left to make better contact with the battery terminals. There are three connections. I stress that you be gentle. This not the long term fix but you will be able to take pictures in the short term.
Feb 25, 2009 | Casio Exilim EX-S880 Digital Camera
Cracked outer casing on Casio Ex-s880
Find a broken camera for sale somewhere (online or offline) and use the parts to fix your camera. You can even sell the leftover parts and possibly make back what you paid for them in the 1st place.
Nov 12, 2008 | Casio Cameras
Casio ex-s880 model
It could be the battery isn't taking a charge. Since your purchased the camera last February you could be still covered under warranty. I would check with Casio.com. I found this link on their website:
http://www.casio.com/support/authorizedservice/
Jun 22, 2008 | Casio Exilim EX-S880 Digital Camera
Ex-s600
Casio isn't going to sell just those parts. They are going to make you send it into them to be fixed.
May 01, 2008 | Casio Exilim Card EX-S600 Digital Camera
Casio Exilim Ex-S880
I have had this issue on several Casio camera the lens comes out fine and then goes right back in some times it just gives you two beeps and nothing else. the problem is with the lens its focus motor is out of ajustment. According to Casio this is not covered under any type of warrenty coverage and that ****.but hehe sometimes you can take it back to places like bustbuy and if you have your receipt they will sometime swap it out. But lets say they don't. well you sometime can get a replacement lens for it off ebay for pretty cheap. This is only if you are sure that you can fix the camera. If you choose to have it fixed make sure you shop around there is a huge diffrence between shop to shop.
Dec 25, 2007 | Casio Exilim EX-S880 Digital Camera
Cameras Logo
50 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
