When I try to print on A4 paper the Canon printer pulls on the right side of the paper only and it jams. I can still print on the small sheets (A5?) or on my 4 x 6 photo paper.
Check to see if this will affect your guarantee and if so would probably not go ahead with it.
Protect yourself from shock by disconnecting the power cord from the back of the Canon printer.
Unhinge the back access panel of the printer. .
Look through the opened back panel and look for paper or any other object that should not be there. Remove any paper or obstacle you find jammed there.
Close the back access panel. Make sure that it latches back into place.
Find the front or top access panel. This is the panel you would lift to change ink cartridges. Open this access panel and look for paper or any other object that should not be there
. Remove any paper or object you find jammed here. If you find paper pull slowly or the paper will rip and create a major problem.
Close the front access panel. Make sure that it latches back in place.
Put the power back on..
Posted on Jul 15, 2008
Where do I load paper in a Kyocera FS-C5350DN Full-Color Laser Printer
At the bottom of the printer you will find the paper cassette. Pull the handle and the cassette will slide out. Eventualy you will need to ajust the size of the paper.
Jun 23, 2014 | Kyocera FS-2000D Laser Printer
I getting Error code 13.02.00 for HP Printer LJ2300dn
solution clean the paper sensor and service the two solenoid that's the problem inside the printer
Jan 21, 2013 | HP LaserJet 2300dn Printer
Problem with Canon Pixma 4300 inkjet. Orange alarm lamp flashes 10 times on switching printer on. Have tried plugging and unplugging power cord, and checked that there is no paper jam. Please help. Brian
Hello Brian,
I found the following on Canon's website.
Not sure if it will fix your issue but thought it might be worth a try:
Ten flashes:The Cassette is not installed properly/Cannot perform duplex printing
  • When loading from the Cassette, install the Cassette properly and press the RESUME/CANCEL button.
  • When performing automatic duplex printing, the size of paper may not be compatible with automatic duplex printing. The sizes of media suitable for auto duplex printing are A3, Regal, 11" x 17" (Tabloid), B4, A4, Letter, 10" x 12", 8" x 10", B5, and A5". Make sure that the size of the paper loaded in the printer is correct. Pressing the RESUME/CANCEL button will eject the paper and restart printing from the front side of the next paper. The reverse side of the ejected sheet will not be printed.
Best of luck
Regards
Mar 02, 2011 | Canon Office Equipment & Supplies
Is it canon laser LBP 3300 printer take Legal Size printing ?
Here are "little" specification:
Body installation method desktop page printer
Photosensitive medium OPC drum
Exposure method semiconductor laser
Development method Toner projection development
Transfer method by roller
Separation method by curvature
Cassette pickup method by pad
Multifeeder pickup method by pad
Drum cleaning method by blade
Fixing method on-demand
Delivery method face-down/face-up
Toner supply type by toner cartridge
about 6000 prints (A4, single-sided; at 5% image ratio)
Warm-up time in standby: 0 sec (at power-on: 10 sec or less)
Print area top: 5 mm; bottom: 5 mm; left/right: 5 mm (if envelope, top, bottom, left,
right: 10 mm)
Printing resolution 600dpi
First print time 9 sec or less (approx.; A4)
Print speed (A4) 21 pages/min (approx.)
Cassette paper size A4, B5, A5, Legal, Letter, Executive
Multi-purpose paper size A4, B5, A5, Legal, Letter, Executive, Envelope DL, Envelope COM10,
Envelope C5, Envelope Monarch, Index Card, Custom Paper Size (width
76.2 to 215.9 mm, length 127.0 to 355.6 mm)
Cassette paper type plain paper (64 to 90 g/m2), heavy paper (91 to 120 g/m2), recycled
Multi-purpose paper type plain paper (64 to 90 g/m2), heavy paper (91 to 163 g/m2), recycled
paper, transparency, label paper, envelop (DL, COM10, C5, Monarch,
B5)
Cassette capacity 250 sheets (approx.; plain paper, 64 g/m2)
Multi-purpose capacity 1 sheet
Delivery tray stack 65sheets (Face-down) /1sheet(Face-up Output Slot)
Memory 8 MB (internal; no optional memory available)
Operating environment
(Temperature range) 10 to 32.5 deg C
(Humidity range) 20% to 80% RH
Noise 52.8 dB or less (during printing; based on ISO9296; announced noise
emission)
Power supply rating AC100V±10% (50/60Hz ±2Hz)
Power consumption (Maximum) 790W or less (approx.; 20 deg C; for input of rated power supply;
including peak value lasting 1 sec or more)
Dimensions 370 (W) x 375 (D) x 258 (H)mm
Weight printer: Approx;11kg; toner cartridge: Approx,0.8kg(2.5K)
Option paper feeder
Jul 06, 2010 | Canon LASER SHOT LBP 3300 Printer
Paper feed problem
Hi
This is happening due to paper jam on the gear or roller of the paper feed mechanism. Check for any small bits of paper or sheet stuck. To check lift up the top plastic lid of the Canon printer. Check to see if a jammed sheet of paper is visible inside the printer. Remove the cartridges and check for any small paper bits stuck under the print head. Pull the paper out gently through the bottom end of the printer(if any). Close the top plastic lid. Power On the printer and check.
If it doesn't work then power off the printer, wait 10 seconds and power it back on. try once again to print. If it doesn't work then Open the Canon printer software. Click "Options" and then select the "Clean Print Heads" button.
Daniel Scott
Jun 14, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Paper jammed but no paper is jammed.
Sounds like something has fallen into the paper path. Use a flashlight and small mirror to look down the slot where the paper goes. You may have to use a straightened paper clip or the like to help remove the obstruction.
Jun 26, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Problem printing on matte photo paper
no thats why it is not working the right way you have to use the semi gloss paper thats what it requiers
Jan 03, 2009 | Brother MFC-3240C All-In-One InkJet...
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
Jammed paper
If the paper is lodged too far into the printer and can't be removed:
Press the power button to turn the printer off.
Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
Close the front cover.
Press the power button to turn the printer back on.
Resend your document to print.
Ensure that:
The paper is a recommended paper for inkjet printers.
You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
The printer is on a flat, level surface.
The left paper guide is against the side of the paper.
You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
The left paper guide does not cause the paper to bend in the sheet feeder.
Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
Envelopes or the appropriate specialty papers are selected in the printer driver.
You are using a paper or envelope size supported by your printer.
Apr 28, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon Pixma mp510
The top-loading sheet feeder accommodates approximately 150 sheets (depending on weight), and the front feeder is good for around 100 sheets. Actual media sizes supported by the main feeder (top-loading) include A4, B5, A5, Letter, Legal, Envelopes (DL size or Commercial 10), 10x15cm(4" x 6"), 10x18cm, 13x18cm, 20x25cm, and Credit Card (54x86mm), while the front feeder is less accommodating with just A4, Letter, and B5.
Jan 27, 2008 | Canon Pixma MP500 All-In-One InkJet...
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
