Question about Cannon 10476G Dual Fuel (Electric and Gas) Kitchen Range
Cannon 10450G fan oven not heating up
I have a cannon professional 1000 (model 10450G - dual fuel). The fan oven is not getting up to temperature although the fan is working and the thermostat light comes on, oven light comes on etc. Conventional oven is working fine. Seems to have develped the fault after my wife took all the control knobs off and gave the whole thing a thorough cleaning - might be a coincidnce! Any suggetsions?
SOURCE:
SolutionGuy
  • 331 Answers
SOURCE: fitting a new control switch for the fan oven (model number 10450G)
Sesspod, 2 things... 1.) Pull the oven out and look on the back of it, there may be an envelope back there containing a technical data sheet which includes a wiring diagram. If not on the back, then possibly under the cook top. It is somewhere on your oven, sometimes the hard part is locating it. If you can find it, look closely and you'll see the wiring color and location is labeled. 2.) If you can't locate the tech data sheet, can you post a good macro picture of the back of your new switch so we can see what you're dealing with.
Posted on Aug 11, 2007
  • 139 Answers
SOURCE: cannon chichester calor gas oven
The FFD or it might be called an FSD in cannons case is faulty it needs replacing. The fault is that it is not forcing open the valve to let teh gas come through when it gets hot... These are easy to fit if you know what your doing .... Be careful it is a corgi man job. Flame faliure device or flame saftey device.... 100 %
Posted on Nov 21, 2007
SOURCE: need to set clock on my cannon chichester oven
Go to www.cannonservice.co.uk/hs/pages/manual/manualSearch.do you should find your model there. Terry.
Posted on Jan 31, 2009
SOURCE: Oven Ignition Keeps Clicking
Lift the cooker using a helecopter and drop it on cannon HQ as this is the only pleasure you will recieve from purchasing a cannon chesterfield cooker Looks like a RollsRoyce shame about the engine The first one we bought was plauged with problems Having only owned the cooker a few days and 3 visits from there very well mannerd technitians cannon replaced the cooker but alas the technitians had to visit again It has been over a year now and would you believe it top oven wont ignite niether will the rings and no its not the fuse in the plug Clock eluminated not bad for around 500 quid
Posted on Nov 25, 2009
  • 42 Answers
SOURCE: I would like to remove the controls on a Cannon Chesterefield
the control knobs can be pulled forward to remove.
Posted on Jan 03, 2010
I have a New World Double oven, dual fuel range cooker - NW 90DFD0 The main oven isn't heating up.
Hello Ally;
My name is Peter. I am a retired field service appliance technician.
You may not have a problem. Normally your oven will rise about 40 degrees F. above the set temperature and then shut down, until the oven temperature falls 40 degrees F. below the set temperature, then the oven turns back on.
Your oven temperature is controlled by you oven thermocouple.
You also have a high temperature limit switch, which turns the fan on when you go too far above the set temperature to vent the oven. This may be bad.
Mar 10, 2016 | Ovens
Fitting a new control switch for the fan oven (model number 10450G)
Aug 11, 2007 | Cannon 10476G Dual Fuel (Electric and Gas)...
My oven keeps switching off
main board problem, http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Cannon/Cooking/10430G_10475G_10476G_10682G_10685G_10688G_19504477602.pdf
Genuine Parts & Accessories UK: 08709 077 077 Monday to Friday, 8.30am to 5pm Saturday, 8.30am to 12noon www.cannonservice.co.uk Republic of Ireland: (01) 842 6836
Apr 11, 2015 | Cannon 10476G Dual Fuel (Electric and Gas)...
Fix a fan on a fan oven
Remove plate at rear of oven remove fan blade 3 screws hold fan in place remove bottom screw incompletely slacken top screws. Remove all screws holding rear panel you have bend top right hand corner of rear panel don't worry if pops back when refitted,best to wear gloves, remove fan replace refit in reverse.
Sep 26, 2012 | Cannon 10476G Dual Fuel (Electric and Gas)...
Electrolux dual fuel oven will not heat after self clean
The unit needs to be reset. The temperature had tripped the internal sensor of the unit. This usually has to be done by a professional since the back panel needs to be taken off and the power reset inside.
Sep 02, 2012 | Electrolux EW30DS65GS Dual Fuel (Electric...
Kitchen Aid dual fuel oven, getting an error message F 02
F2
Oven temperature is too high 1. Look for welded relay contacts on bake or broil relays. If this
happens, replace oven control (also called clock or ERC).
2. For SELF CLEAN
models: check door lock operation.
3. Look for a high resistance connection
or any other cause of high resistance in the oven temperature sensor circuit.
Check sensor, sensor harness and sensor harness connection at sensor and oven
control. Replace sensor if found defective.
Remember: Oven control
(ERC) measures resistance of sensor circuit, not actual oven
temperature.
Jan 02, 2011 | KitchenAid KDRP407HSS Dual Fuel (Electric...
Although the fan is rotating in the main oven the oven is not heating up.
Hello & Welcome to FixYa
This indicates oven temp failure and to check if that is bad then check the sensor for around 1100ohms, if it is more then that then it is the temperature sensor, if it tests fine then it is the electronic control board that is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Jan 01, 2011 | Stoves 600DFDOa Dual Fuel (Electric and...
Where can I obtain a Cannon 10588G instruction booklet
Go to Cannon website. Have model # and serial#, and look it up.
Apr 06, 2010 | Cannon 10476G Dual Fuel (Electric and Gas)...
Fan oven element will not switch off red light stays on fan not running
My cannon 10450g oven stays on when the oven switch is off .
I have replaced the elements but still have this problem
Oct 27, 2009 | Cannon 1085 Dual Fuel Range
Open Questions:
Cannon 10476G Dual Fuel (Electric and Gas) Kitchen Range Logo
129 people viewed this question
Top Cannon Kitchen Ranges Experts
Paul Carew
Vernon Taylor
 Mikey
Mikey
Are you a Cannon Kitchen Range Expert? Answer questions, earn points and help others
