My Philips 20FP4121/05 has, starting a month or so ago, taken longer and longer to show a picture - sometimes there was sound alone - and now will not come on at all despite the light being on showing power to the unit (red at rest and gteen when with picture) The unit is only a year and a bit old... Many Thanks
Arpi
  • 326 Answers
SOURCE: No picture, sound works on Sony TV
Hello, maybe there is a contact error in power supply or the deflection stage. If the resoldering does not help- here are some possible solutions: remedy Replace flyback location LP04. Entered for KV32S22 /SONY (Chassis) remedy 2 Replace IC351, Q602, Q601 (2SC4834M), R607 (1R/0.5W), R622 (10R), IC641 (SI3090CA) and Q502 (2SC5148). remedy 3 Replace tuner. remedy 4 Replace R607, Q502 and IC601. Entered for KV32S22 /SONY (Chassis) remedy 5 Replace regulator IC, R607, check C609, C610 (0.68pF) and C613 (0.0022pF/500V). remedy 6 Replace horizontal output transistor (2SC5148), IC601 (MX0841) and R607 (0.1R). remedy 7 Replace IC1701 and IC601. remedy 8 Replace Q501 (2SC5148), R607 and resolder horizontal driver transformer. remedy 9 Check and replace horizontal output transistor Q502 (2SC5148) and IC601 (MXD8411AB-F). remedy 10 Replace shorted R607. Also check T501 and Q501 for dry joints. remedy 11 Replace C608. remedy 12 Replace Q602 and D648. remedy 13 Replace Q502, Q601, Q602 and R602. Entered for KV32S22 /SONY (Chassis) remedy 14 Replace D626 (6.2V). remedy 15 Replace IC801 and R607. remedy 16 Replace horizontal output transistor and the associated damping capacitor. Check flyback transformer and SMD microprocessor as well. remedy 17 Replace R639 (4.7R/0.250W) located on G board in standby power circuit. remedy 18 Replace D600. remedy 19 Replace C502 (0.47uF/50V). remedy 20 Check D655(1N4937), D657 (1S1834) and Q601 (2SC4423). remedy 21 Check D606 for leakage. remedy 22 Check yoke between vertical and horizontal windings for S/C. remedy 23 Replace Q601 (2SC4834MNP), R607 (0.1R) and C517 (2.2uF/250V). remedy 24 Replace R611.
Posted on Apr 22, 2007
smilemaker
  • 790 Answers
SOURCE: "Fan lock"
Use the below link to locate ur nearest service centers ...
its an hard ware cognitive factor u alone cant rectify it ..
http://maps.jvc.com/cAscList/index.asp
Posted on Dec 23, 2007
billyjones69
  • 42 Answers
SOURCE: KP43t70 NO PICTURE SUDDENLY
SYMPTOMS
No power
RESOLUTION
Found IC601, F601, and R612 on the G Board defective.
Get the manual at http://fletchersite.com/contact.php
Posted on Jun 01, 2008
  • 3 Answers
SOURCE: Sony SXRD KDSR50XBR1
I get the same problem (4 flashing red lights).
I done some internet troubleshooting and narrowed it down to an overheated power circuit card/fan issue.
It turns out one of the fans is failing and will not rotate at the appropriate speed to cool the power circuit card, this will kick out the 4 flashing lights from the diagnostics.
In lieu of replacing the fans I have a temporary solution:
For my TV (kdsr50xbr1) the fan in question is located on the far left side (facing the rear). You will see a grill on the back of the TV showing you where the fan is located.
First, get a can of compressed air and blow it into every fan. This will clear away a lot of dust and help the fans move easier.
There is one blower type fan located inside the TV, remove the back panel and look for a tall yellow circuit card just to the left off the center of the TV. Behind that card is a blower (stands upright looks like a tube). Blow air into that blower, you will see a lot of dust come through the duct and out where the large fan in the center is located.
Put everything back together. and provided the fans aren't too far gone the TV should be working again.
Also, if the issue comes back, try this:
When you turn on the TV, shoot a short squirt of compressed air into the fan (Far left facing the rear). This will give it a kick start and bring it up to speed.
It is important to note that the compressed air cans do contain a liquid and as such are not compatible with electronics when they are plugged in. Try your hardest to keep the can upright and not allow the liquid to squirt out where it shouldn't. If it does it will evaporate in a few seconds.
Ok, relatively long post, to summarize:
1. Open back of TV, blow compressed air into every fan to clean them.
2. Blow air into whichever fan is causing problem if it happens again.
3. Keep the can upright if the TV is still plugged in. Don't sue me if you fry your TV.
4. If this doesn't work (has for me) replace fans
Posted on Jun 19, 2008
chrispurs1
  • 372 Answers
SOURCE: The picture on my goodmans
Hi.
Your problem sounds like the lead that connects from main pcb to the lvds pcb.
These have gold coloured connections that become tarnished & dont make good contact.
You can try to sort this out your self but please be very carefull the fine wires on the plugs can be easily damaged.
If you do decide to have A go you will need tin of air duster & elecrical spray switch cleaner, You are only to clean plug & socket connections on lvds lead & pcb.
http://dysonmanuals.llc.nu/
Posted on Jul 13, 2008
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
I have a philips flatscreen (32PF5331 / 12) that I bought it around 3 years ago. Everytime I turn on the TV, I only get the sound then I should turn the TV on and off (sometimes 5-10 times) before I...
Hello, not positive what part you need...but it sounds like maybe the main board needs replacing. I have purchased parts many times from a company named ShopJimmy.com. I included a link to the part from their site for your model. Hope that helps!
TeeVeeMan2@gmail.com
http://www.shopjimmy.com/catalogsearch/result/?q=32PF5331
Aug 25, 2011 | Philips Televison & Video
Bought element tv model flx-3711b in 2008, worked well until about a month ago start having problems, it start taking longer time to come on, sometimes picture comes on but no sound and sometime loud sound...
The problem you are having is a common and easily repaired one. The problem is caused by a failing power supply board. If you can do a little soldering then you should be able to do the repair. Check out this article on repairing the power supply in this model.
http://www.ccl-la.com/blog/index.php/visco-vsc-37v1-no-picture-lets-repair-it/
If you don't want to do the repair yourself we do offer a repair service, you can use the link on that page to request service.
I hope this helps you, if so please rate our solution.
BuddyMc
Jan 11, 2011 | Element Electronics FLX3711B 37 in. LCD TV
Hi I have a Samsung LE46M86BDX , and its beginning to take longer time beforer showing the picture, normally you can hear a "click" after 2-5 sec. and the picture shows, for a few days ago the "click"...
I had the same problem. http://www.youtube.com/watch?v=tK7zFBBU6p4&feature=related We're not alone - its a common problem with Samsung. I watched a few of these and was able to see the bad capacitors, de-soldered and replaced them for under $5.00.
Sep 01, 2010 | Samsung 32 in. LCD Monitor TV
Slow to turn on Phillips flat screen tube big screen
That is a common issue with the last generation of the phillips big screens, the best answer for this is one that i got at a meeting with phillips service several years ago. On philips the tv will not show a picture till the tubes are balanced out, simular to sony, but in a phillips if the white balance is not correct the picture and sound will be muted till all three tubes have warmed up enough to produce a good white balance. As the set ages the tubes become weaker and this procesess takes longer.
May 07, 2010 | Philips 43PP9202 43" Rear Projection...
Get ERR message when trying to take pictures/troubleshoot no help
Two possible things to check.
First, a bad memory card can easily cause this problem. Try replacing the card.
Secondly, could be a poor connection between camera and lens. Be sure contacts around the rim of lens and lens opening are clean and free of dirt, dust and debri. Do not get anything inside your camera when you remove the lens. Dust is a killer to the sensor in the camera.
Mar 22, 2009 | Nikon D50 Digital Camera
Phillips 42pf9630a 42 in
A code 7 is related to a hardware problem that reqiures service.
If you want to get a referal to a Philips authorized service center call 888-744-5477 and they can prive contact info for a servicer in your area.
Aug 21, 2008 | Philips 42PF9630A 42 in. Plasma Television
No picture
phillips 17in lcd no picture
Oct 29, 2006 | Philips 17PF9945 17 in. LCD HDTV
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Electro Med Services...
