Question about ASUS K8V-MX Motherboard
PATA Harddisk connection
I am having difficulties connecting PATA Harddisk to my K8Vmx motherboard. Please guide me on how to connect it to the board and how to boot the system from this device
  • Daniel Jenkins
    Daniel Jenkins May 11, 2010
    If you don't know you shouldn't be working on computers to be honest with you....
    President:
  • 2,351 Answers
Hi Murtazasoni, if you have the manual for K8V-MX motherboard you shouldn't have any troubles. You can download it from this link, Win XP; http://support.asus.com/download/download.aspx?modelname=K8V-MX&SLanguage=en-us
The IDE data ribbon only connects to the PATA drive & motherboard in one direction. Please see the top of page 1-22 for instructions. Most data ribbons for IDE drives have three connectors. The connector farthest from the other two connectors (Two connectors very close to each other), is plugged directly to the motherboard as shown & explained on the top of page 1-22.
If you are only connecting 1 PATA drive to the data ribbon, connect it to the last connector on the ribbon, leaving the next connector for another PATA drive.
Setting the jumper on a PATA drive. Every hard disk drive has a large white sticker on it. This sticker includes information about the drive. Things like the model number of the drive. There is also information regarding how the drive is to be set. Example: if the drive is to be the only drive in the system its jumper should be set to (Master drive only). If there is another PATA drive in the system connected to the same ribbon cable than change the jumper on the drive to, (Master with a Slave). The second PATA drive's jumper must be set to, (Slave). Connect the power cable to the PATA drive ['s]. Re-check all connectors (internally) before closing the case. Boot the system & press the Delete key on the keyboard every two seconds until the main bios menu opens. Open your manual to the top of page 2-7. Here you'll learn how to move about while in the bios. At the main menu you should see your PATA drive. Listed to the right of Primary IDE Master you should see the model number of the PATA drive listed. If not than the drive was not connected correctly. Shut down the system. Unplug the power cord from the system, open the case & re-check the data ribbon for correct orientation, solid insertion & solid insertion of power cable to drive. Connect the power cord to the system & boot to the bios again. Once the drive is listed go to the title Boot, section 2.6, page 2-27 & follow the instruction through to page 2-28.
Open your CD-ROM drive & load your windows CD, close the CD drawl.
Save bios changes & exit. The system will auto restart.
The system should start loading windows if you set the boot device correctly as shown in the manual.
If you find this too difficult to follow, suggest you ask a friend with more PC knowledge for assistance.
Mike
Posted on Sep 09, 2008
How to connect power ,reset ,hdd led and power and data cables to asus KV8-MX mptherboard
Below is a link to Asus website. You will need to put in an OS under download to get the list to pull up. At the bottom of the list you will find Manuals. Hit the plus sign and I would down load the Users manual, it should have what you are looking for in it.
http://www.asus.com/Motherboards/AMD_Socket_754/K8VMX/#download
Hope this helps
Apr 10, 2012 | ASUS Computers & Internet
Hi, I'm having K8V-MX Asus mother board with AMD 3000+ processor wih 1GB DDR ram, with 80 GB PATA Segate HDD connected. After adding 500GB SATA HDD to this mother board, my system performance is very low....
Thanks for the details. I have used K8V-MX Asus motherboard and found it very reliable with quite reasonable performance. It definately supports 500 GB Sata drive and there must not be any issues after increasing just the storage. However, Operating System upgrade may result in sluggish performance. Drivers dont seem to be an issue to me either.
I suggest to review a few points detailed as under: -
- K8V-MX Asus Supports RAID, so, check for any RAID Drivers/ settings. (You dont have to use RAID for two Hard Drives of different make, capacity and speed). Try using one disk at a time having same Operating System (e.g. Windows XP) and compare the performance.
- Infact SATA Drives have better data transfer rate than IDE, which results in enhanced performance.
- Some Programs (that you may not be using with 80GB drive) Like antivirus may result in decreased performance.
- Please Review you Operating System environment and software installed. Make sure that the new drive & Operating System are free of any virus, which results in CPU Utilization upto 100%.
- Also, motherboard supports Max 2GB RAM, so you may consider adding more RAM.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
CreativeTECH
Jan 27, 2011 | ASUS K8V-MX Motherboard
Hi, I'm having K8V-MX Asus mother board with AMD 3000+ processor wih 1GB DDR ram, with 80 GB PATA Segate HDD connected. After adding 500GB SATA HDD to this mother board, my system performance is very...
You can get free online remote Support by mailing this problem to googolplexcorporation@gmail.com .
This may be due to two problems
1. Due to Virus
2. Due to Insufficient RAM .
You can mail for free remote Support for Viruses
How to connect two optical drives to the motherboard?
Hi boss2415,
Well, that depends on what type of optical drives you have. The board (sweet) has 6 SATA ports, if both of your optical drives are SATA drives, then just plug them both into the next consecutive SATA port. Now, if you have a PATA drive, my suggestion is to get a dual PATA cable to connect to the board. Make the one you'll use the most the Master and the other the Slave. And Bios and Windows will automatically setup the drive letters for you.
Good Luck
Mark
Jan 24, 2010 | ASUS P5Q SE PLUS Motherboard
Boot failuer and cmos error and not detect by bios
reseat your pata hard drive, take out the power cable on your system tower, press and hold the power button for more than 15 seconds and then take out the connections on the hard drive and put them back in and then using cmos setup to default values and now try to start your system and see if your hard drive is detected.
if not
swap the power connector with some other free power connector, and try if this also not work
swap your pata cable with another pata cable and if this also doesn't work
either your hard drive or your motherboard is bad.
If You think my solution was helpfull please do rate me
Regards
Ltoso
Jul 23, 2009 | Gateway Essential 400 PC Desktop
Computer will not start
first you connect your harddisk data cable to mother board
connect your hard disk powercode using smps
connect smps 24pine connector threw mother board
connect 12v connector threw mother board
connect cpu&external fan connections
also connect the front panel connections on mother board using mother board details
Jun 17, 2009 | ASUS A7N8X Motherboard
I hav d same motherboard which was workin fine but now it stopped detecting my pata hard disk which was primary. but sometimes it detects it n den while i m working, suddenly my pc turns off n it doesnt...
this is the connection problem. there is loose connector betn cable and your hdd. first remove the harddisk, connect cable, be sure that it is connect correctly. do connect it loosly. i hope. then your hdd work.
May 13, 2009 | ASUS P5RD1-VM Motherboard
Asus k8vmx vista drivers
If U R Using Vista Then ::
Go to Device Manager Then Update Driver From Internet Connection Then All Drivers U can Upgrade Using This
Apr 29, 2009 | ASUS K8V-MX Motherboard
Hardware Detection problem with ASUS K8VMX Mother Board
Firstly, Put a new battery on your motherboard(usually a cr2032).
Unplug everything except the ram and try to boot up.
Switch off and gradually attach one component at a time and reboot.
Remember to turn off every time you add a component.
This happens because your bios chip is getting mixed up because you are changing the configuration all the time.
Hope this helps
Jan 19, 2009 | ASUS K8V-MX Motherboard
Foxconn motherboard 945g7md
Are you connecting them via SATA or PATA ?
If you are using PATA you'll need to set the jumpers on the drives. One needs to be a master and the other has to be a slave. Normally the Hard drive would be considered the master.
If they are SATA drives go into your bios and make sure the SATA ports are enabled and not in RAID mode.
Nov 16, 2007 | Foxconn (945G7MA-8KS2) Motherboard
ASUS K8V-MX Motherboard Logo
436 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
