Question about Canon PIXMA iP3000 InkJet Photo Printer
6A00 Service Error - Canon PIXMA iP3000 InkJet Photo Printer
  • 1 more comment
  • Anonymous Sep 29, 2008
    PIXMA iP4500 Service Error 6A00
  • Anonymous Apr 28, 2009
    printer displays 6A00 error paper jamed but there is no paper becouse printer cant take any paper sheet for printing
  • pepper01963 May 08, 2009
    keep getting this error message and printer making horrible noise
Service error 6A00.
Cancel printing and turn the printer off and then back on
If this doesn’t clear the error, see the printer manual for more detail.
Posted on Aug 16, 2008
5 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: My CAnon MP 610 has a service error 6A00. What is
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
whitebirch
  • 433 Answers
SOURCE: service error 6A00
The 6A00 is a Canon generic code for paper path jam. A sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, screws, cookie crumbs, cake, toast you get the idea. Get yourself a can of compressed air and blow the paper roller out, also a slightly damp paper towel and gently clean off the paper feeding rollers.
Anywho this should fix you up. good luck, please post rating, thank you kindly
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
Posted on Apr 27, 2009
SOURCE: Canon ip5200 Service Error 6A00
This might have something to do with canon's absurd print cartridge limitation agreement.... where the print cartridge will only print for a certain limit and then locks
Posted on Jul 24, 2008
SOURCE: Your Problem: canon ip service error 6a00
Had this error and did the following to solve the problem.
Turn the printer off.
Open the top cover and move the printer cartridge to the left.
On the right you can see a white part.
Press it down.
Turn the printer on.
if that doesnt help then there its better to call canon...
thank you have a nice day
Posted on Jun 02, 2009
Turned printer on and it comes up with Error Code 6A00
AP position error will trigger the 6A00 error code. An error occurred in the AP motor during purging operation. As per service manual, you will need to replace the sheet feed unit, logic board assy and purge unit.
Feb 22, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Apr 25, 2010 | Office Equipment & Supplies
Service error 5c10, error code 6a00 wored
6A00 is the error when the purge assembly is broken or jammed. You need a shop to install a new one since the entire print engine has to come out to replace it.
Dec 04, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Press it down.
Jun 02, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Will not turn on error 6A00
This is what I found from a service manual: AP position error [6A00] - Sheet feed unit (QM2-1220) - Logic board ***'y (QM2-1786)*1
What does it mean? This link should be useful: http://www.fixyourownprinter.com/forums/inkjet/37440
May 30, 2009 | Canon Pixma iP6000D InkJet Photo Printer
Check printer and 6A00 flashing
6A00 indicates that "an error occurred in the AP motor
during purging operation". This is a service call error and requires that the printer be brought into a canon authorized service facility for repair. The service facility would be able to fully diagnose the problem and properly repair it.
May 21, 2009 | Canon PIXMA MP530 All-In-One InkJet...
My canon mp610 is showing fault no 6A00 any help would be great bob chasey
May 17, 2009 | Canon MP610 Photo All-In-One Printer
Service error 6A00
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Mar 01, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Service error 6A00 in my canon ip 5200 printer. what should i do
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Feb 23, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Cannon MP810 when turn on display error A600. There is also no light displaying on the printing cartridge.
A600 or 6A00. If 6A00 then the fault code is for the AP motor position error. Error lies with the sheet feed unit, Purge unit or Logic board.
http://www.tradebit.com/filedetail.php/4588588-canon-pixma-mp810-printer-service-manual
This is a complete service manual
Sep 14, 2008 | Canon PIXMA MP960 All-In-One InkJet...
Canon PIXMA iP3000 InkJet Photo Printer Logo
1,162 people viewed this question
old marine
old marine
