Question about NEC Versa VX Notebook
Wher s d RAM
I have a NEC Versa M400 notebook ,need to locate the RAM so as to upgrade ,... cud sum1 pls guide how to open d notebook and get to the RAM ...d manual s not available online as well
  • Anonymous Jul 28, 2008
    yes the notebook quiet stupid acctually,, if the ram so complicate to locat better sold to eliphant for use it
1) You'll need a small screwdriver and phillips head screwdriver.
2) You will need to stick the small screwdriver head in between the row of function keys and speaker cover. Gently and carefully unclip the speaker cover away from the keypad.
3) Once the speaker cover is off, gently remove the keypad away from the clips that are holding it in place. You'll need a screwdriver to do this. Once this has been done, rest the keypad down without having to disconnect it from the circuit board.
4) You'll see a silver cover to the right. Remove all the small phillips head screws. Lift the cover off and underneath the thin black plastic sheet is your RAM.
5) To remove RAM simply pull the two metal clips that are holding it outwards and the RAM will pop up and then you can slide it out.
6) To replace/add RAM, slide the RAM into it's slot. It can only go in one way. Once it's in, genlty press down on the RAM and it should click back into it's place. Make sure that the metal clips are holding the RAM in it's place.
7) Screw silver cover back on, put keypad back on making sure it is clipped back into it's place, put the speaker cover into the allocatd slots and gently press down and you'll hear it click into place.
Posted on Oct 23, 2008
Hi I have an NEC KW300 laptop, it currently has a duel core 2 processor with 2ghz, it has 1gb ram at the moment. I want to upgrade it now with a 2gb ram. Do you have any idea if those laptops has a DDR2...
Hmmm, something does not appear correct. The Crucial memory selector indicates that the Versa Premium will hold 2 256 MB DIMM for a total of 512 MB.
Aug 15, 2011 | NEC Versa Premium Notebook
How to update ram on NEC Versa M400?
I don't know what a NEC Versa M400 is, but i'm prosuming youve checked under the memory pannel on the bottom of the laptop? if the rams not under one of the pannels on the bottom then you will find it under the keyboad.then just release the 2 clips on either side of the chip & it will pop up. pull it out & put the new one in,you'll see they only go in one way.
Jun 17, 2010 | Computers & Internet
I want to down load driver : Nec Versa Pro
I don't have network card driver NEC versa ProR
Jan 08, 2010 | NEC Versa VX Notebook
Upgrade NEC Versa VX
You can insert the Windows XP CD while logged on Win 98 and run a test from the CD. Obviously you need a larger Hard Disk and at least 126 MB RAM to bring XP to a usable speed. You can look for RAM upgrade options in this page.
Apr 18, 2009 | NEC Versa VX Notebook
NEC Versa Notebook S Series User Guide
Here you go.
NEC Versa VX User Guide
Don't forget to rate my solution FixYa
Mar 01, 2009 | NEC Versa VX Notebook
Where is the RAM SIMM Slots in a NEC Versa LX?
The SO DIMMs (RAM) slot is located below the keyboard on these.
Just a quick note:
Installed Size: 64 MB / 256 MB (max)
Technology: SDRAM
Form Factor: SO DIMM 144-PIN
More info -
Mar 27, 2008 | NEC Versa LX Notebook
Upgrade a NEC
What are you wanting to upgrade? The ram or the operating system?
Your laptop can take upto 256mb of ram. Its the old pc66 sdram that it takes. A 128mb stick would certainly make a big differance on top of the 64 you already have.
Chances are that you have a lot of progs set to start on startup. Turning off some of these will make a big improvement.
heres how to do it in win95
hope that helps :)
Dec 29, 2007 | NEC Versa SX Notebook
How to upgrade memory
The NEC Versa m500e has 2 memory slots. Each slot can hold DDR PC2700 with a maximum of 512MB per slot.
I'm not sure where the memory is located on the Versa, but normally in the middle on the bottom of the laptop there is a memory slot. on some units the memory is located under the keyboard, so you have to remove this first to change the memory.
Hope this helps
Dec 27, 2007 | NEC Versa FX Notebook
NEC Versa VX Notebook Logo
124 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
