Question about Dell Computers & Internet
Dell Power Supply
I have plugged in y power suppy in my d505 latitude dell laptop but it doesnt seems to charge my battery
I put another battery from oter laptop and its the same problem
Please help!!
Regards
  • shanky75 Jul 14, 2008
    I have a another laptop of the same make and the power supply
    seems to be working fine with the other laptop so I think there is nothing wrong with the power supply but something to do with the laptop itself but I am not sure wat to look for in the laptop
    Regards
    Master:
  • 788 Answers
You can test the power supply using a multimeter. I use a paper clip to get in the middle if my multimeter probe is too large. If there isn't any power but the light on the power brick is on (if there is one) then there is most likely a break in the cable. In any case turn to eBay for a replacement, should be quite easy and inexpensive to find. Or you could pay more and get one from Dell. Companies like APC and Targus make usniversal adapters but they're expensive and not optimal.
Posted on Jul 14, 2008
  • Richard C Cohen
    Richard C Cohen Oct 04, 2010
    Hello there...just a warning about Dell power supplies and laptop supplies in general...that center pin (at least in Dell) DOES NOT have significant current/voltage on it at all--that isn't what it's for!! The center pin in the connector is the battery-charge signal contact! It only will have 1 volt or some fraction thereof on it! It simply tells the circuit to begin charging the battery when necessary. When checking the presence of the charging voltage/current, you must BE CAREFUL not to touch the inside of the barrel to this pin!!! The inside metal barrel and outside is separated by a dielectric shield (insulator material) so the two never touch. Everyone thinks that the center pin is the positive--it isn't! Just have to emphasize because I'm trying to save someone from mistakenly blowing a good power supply. Yep, I'm a tech and I've BEEN THERE! The distances in that connector are SMALL so you really have to be on your game when troubleshooting.--Just trying to help out---
My Dell D505 Latitude will not power up. The 3 green lights flash for less than a second and then it switches off. It was working fine until a few days ago. Any ideas of how to fix this as all my work is...
Sounds like ether a blown power supply. That happens when the laptop battery has alittle juice left.
Try to take out the battery from the bottom and plug the laptop in the wall. If the laptop powers up you battery needs to be replaced. If it doesn't power up, you need to replace the power supply.
Good Luck,
jsgrepair@co.nr
Aug 23, 2011 | Dell Latitude D505 Notebook
Dell Latitude D505 won't turn on
hello there this could be alot of things ,please check battery ,also check power supply make sure both of these are functionable ,remove the battery and just connect the power supply and see will it turn on you should have power now ,if not you may replace the power supply please check these with other pc igf you can this will allimanate if it faulty or not ,on the other hand it could be the bios but more than likely its just a power problem ,please let me know goodlook
Mar 26, 2011 | Dell Latitude D505 Notebook
D505 not charging battery, was working when plugged in - now won't even come on even when plugged in. I have replaced the battery and also the power supply - help.
1. Try using only the power supply.
2. If it won't turn on, unplug power supply then use just the battery.
3. If these two steps doesn't work since you've already replace the battery and the power supply.
You'll need to replace motherboard.
Jan 03, 2010 | Dell Latitude D505 Notebook
Laptop wont charge battery
its a comment fualt with laptops the micro switch that switches between charge and main power goes faulty on them, you could be acutally onto some thing here because ther eis alot of people with laptops that wont charge at all, and if they knew ur little sequence you got going on there maybe you could save their laptops been door stoppers.
Dec 01, 2009 | Dell Latitude D410 Notebook
My dell d505 latitude laptop has the dreaded
Sounds like your battery is dead. They go bad in laptops and need to be replaced in a couple years.
1) Unplug your battery and power laptop on with just AC adaptor. If laptop runs normal then you need to replace battery.
2) If it doesnt turn on at all then your motherboard may have a problem. The power supply is integrated on MB on most/all laptops.
2) if you need a motherboard replacement, try http://accessories.us.dell.com/sna/DellPartsFamily.aspx?c=us&cs=19&l=en&s=dhs
Nov 25, 2009 | Dell Latitude D505 Notebook
Dell latitude d505 will not power on
the dim on and off indicates
the ac power jack or adapter may be bad
its charging battery then not
check the pin in the laptop to see if it moves
or the end of the adapter could be bad
even if the green light is on
try not to wiggle to get to work, or you can break connection
Jul 21, 2009 | Dell Latitude D505 Notebook
My dell d505 powrs up on battery fine but wont power up on ac
did it start by it seeming to have a connection problem. The pins in Laptops tend to get loose. Or the box on your ac adapter could have blown. Best bet.... order a new AC. You can search ebay or the web for one
Apr 08, 2009 | Dell Latitude D505 Notebook
D505 will not power up
for this problem
go to http://support.dell.com>techincal support> enter your service tag> then check for battery issue it will tell you the meaning of each code being displayed on the laptop and you can resolve the problem,
one thing you can do is
take out the battery, take out the ac adapter from the laptop
now press hold the power button for 15 seconds
now put in the battery and ac adapter and see if the battery is charging and laptop is starting if not call dell support,
further queries are welcome
Jan 15, 2009 | Dell Latitude D505 Notebook
Computers & Internet Logo
1,012 people viewed this question
Alun Cox
