This is the second time the exact same thing happened.
It's caused by a coin getting into the drain, and after the motor continuously slams it into the inside of the drain assembly, it wears thin and finally cracked. Exact same 1/4mm spot both times.
I replaced the entire part last time. This time I'm going to repair it with 2 part epoxy as well.
I've just had this same problem and successfully fixed such problem. I had to set the washer on blocks and crawl underneath while the wife was turning the washer on spin cycle for a few seconds. After following the leak I discovered the drain pump assembly was cracked. Some epoxy and a day of curing / drying cut the leak out like a charm. I also went ahead and ordered a new drain motor while I was at it and installed.Good luck!Davejr021@yahoo. Com
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
