Question about ASUS M2N-VM DVI - Motherboard - micro ATX - GeForce 7050PV - Socket AM2 - UDMA133, Serial ATA-300
CMOS Checksum error.
Every time on POST screen CMOS Checksum error happened. and i have to press F1 and then adjust date & time and another settings which i saved earlier. If i rebooting then this problem not occurred. Already i change CMOS battery twice and upgraded to latest Bios Version 0807. But the problem still persists. Please guide me what to do.
  • 781 Answers
The only thing i can think of is when you changed the battery somehow the board terminals positive negative are not in proper contact with battery
did you try resetting bios by the pins on the motherboard
somewhere on the board is printed bios reset or words to the effect
most times it is a 2 pin connector with a jumper only on 1 pin connect the jumper across both pins remove and try to reboot
hope this helps
Posted on Jul 25, 2008
CMOS Checksum Erro
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
During the boot process you will see on the screen a certain key to press to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
You will also need to set the time and date
In the main or system setup screen you should be able to see the date and time Using your arrow keys navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date.
hope this helps you
Mar 15, 2012 | Gigabyte GA-8I865GME-775 Motherboard
Cmos checksum bad boots to the splash screen then goes black with a blinking white line tried reseting the jumper cmos no luck load default settings no luck removed psu and battery no luck
hope this helps you
Oct 08, 2011 | EliteGroup ECS Socket Micro ATX...
Compaq Presario 2500 stopped loading windows XP with a prompt STOP: c0000221 {bad Image Checksum} The image COMCTL32.dll is possibly corrupt. The header checksum does not match the computed checksum.
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
click start control panel date and time you can make your adjustments to the date and time from there also right click on the date and time on the bottom toolbar (bottom of screen) you should see Adjust date and time tab
hope this helps you
Sep 09, 2011 | Compaq Presario 2100 and 2500 ,NX 9000...
I used jumper bios reset and now gettin bad checksum error. on the mother board writen that K8N rev 1.01 i downloaded k8n motherboard rom file and renamed as k8n.rom and copied to disket. its deleting and...
Hi.
The most probable reason you are getting the bad checksum error is you have to set the date and time because you have cleared the CMOS and reset the BIOS.
You should also get a message that says press F1 to load defaults or press a certain key to access setup. Access setup (BIOS) and set the date and time. That should take care of the bad checksum error.
Another good idea is make sure the motherboard battery is not dead either.
Regards.
Jun 17, 2011 | ASUS Computers & Internet
Hello, when I put my pc running it says CMOS checksum error press F1 to enter or Del to enter setup, but I press Del when I save changes "save and exit" the computer restarts, but this time...
The Checksum error basically shows that boot settings which were previously set has been changed or reset. This usually happens when the battery loses its charge and thus fail to retain the CMOS settings. This can also be caused by a power surge or a damaged motherboard. But most of the times it would be the battery problem.
You can try replacing the CMOS battery and enter the values back into CMOS or reset values to default. Then switch off and boot up again.
Hope this works. Good Luck. ~SmokinJoe~
Apr 28, 2011 | EliteGroup KM400-M2 Motherboard
When i boot my system iam getting an error Check Date and Time settings and System CMOS Checksum Bad and Default configuration is used. F1 : Resume F2 :- Setup
Hi Good day!! That error maybe cause of your CMOS battery it may be not working, replace your CMOS Battery (2032 3volts), after you replace it with new one, set your date and time setting according in your time zone.
Oct 13, 2010 | Computers & Internet
I've replaced the battery but checksum error still occurs and F1 is suggested to press for setting time and date
Hi, try this link it has usfull information and help, your problem may well be that your BIOS needs resetting back to default:
http://www.tech-faq.com/cmos-checksum-bad-error.html
Aug 03, 2010 | Mercury P4VM800M7 Motherboard
**** RTC battery is low or CMOS checksum is inconsistent **** Press [F1] to set Date/Time
Hello
Please reset cmos to factory defaults.
Then enter the bios setup and configure it and save changes.
Apr 20, 2009 | Computers & Internet
Asus motherboard bios version1104
Whether it shows your cmos checksum error press F1 to continue or f2 to load default.? If this is the problem than kindly switch off the system check for the cmos battery and change the cmos battery and set the date and time properly in the bios and save it by pressing F10.This will resolve your problem.and if not than check the jumper setting on the motherboard is it set to clear cmos and if so kindly remove and set it properly to adjacent jumper ok. Have a nice time.
Dec 04, 2008 | Computers & Internet
Message before boot
plz try by changing the cmos battey
Jul 29, 2008 | Toshiba Portege M200 Tablet PC
ASUS M2N-VM DVI - Motherboard - micro ATX - GeForce 7050PV - Socket AM2 - UDMA133, Serial ATA-300 Logo
248 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
