Question about Westinghouse Refrigerators
Westinghouse model rs662t side by side fridge freezer - i have lost 2 of the feet/wheels in our move and would like to know where i can buy replacements?
  • 178 Answers
SOURCE: Westinghouse Virtuoso Fridge - Circuit Diagram
If it is kicking the circuit breaker out in defrost mode, then the defrost timer is faulty. It would be best to just replace the timer instead of checking the wiring schematic. Look at www.partstoday.com for helpful illustrations on parts and identifying pictures.
Posted on Mar 30, 2008
miket756
  • 2702 Answers
SOURCE: Westinghouse WSE6100SA fridge in side by side fridge freezer free
the thermostat has broken down and needs to be replaced,, normaly when they brake down they just stay in the closed poshion so the fridge freezes up get a new one fitted and all will be well
Posted on Feb 19, 2010
Testimonial: "Thanks for you fast response, very helpful. I thought this may be the problem but wasnt sure. Are the thermostats easy to replace? Could I DIY, How?"
  • 256 Answers
SOURCE: Replacing thermostate in Westinhhouse WSE6100SA fridge freezer.
I would recommend an appliance service company for this type of work!
Testimonial: "Thanks, was hoping it would be easy. I will try to chase up a service company"
SOURCE: Westinghouse Wse6100WA side by side Fridge-icing up/not cooling
This is a bad design flaw, the fridhe is cooled by fan forced air from the freazer. Two ducts vent into and out of the fridge fron the freezer and ice can block them up (which you can find if you take off all the plastic at the top and back of the fridge).
Hence, when they block up, the frindge does not cool, hence the thermostat tells the fridge to keep running which makes the freezer colder and colder, making the blockage worse.
You need to not only fully defrost the freezer (which can be done quicker by removing the plastic panel in the back of the freezer and using a hairdryer) BUT also fully dry the fridge before turning it back on.
To stop it happening again, avoid puting unvovered liquids or hot items in the fridge. Also avoid leaving the fridge and freezer doors open for long especially in humid conditions. As I said, it's a bad design.
Posted on Feb 20, 2010
SOURCE: Westinghouse Fridge and separate Freezer - What Watts?
internet daownlod maneger serial no need
Posted on Mar 15, 2010
Have lost manual what are the settings for a westinghouse 2 door fridge model rj5325r ?
usually they start mid range on the dial perhaps 4 then adjust as required later on
Nov 13, 2017 | Westinghouse Refrigerators
My Westinghouse fridge freezer, model WSE6100SF, was affected by a power cut lasting 3 days. It now smells, but not inside. Is there a drip tray under the fridge that collects the water?
yes there is but most are not removeable.... remove the cover in the rear of the fridge, the pan is located around the fan motor that's underneath the fridge... I would try pinesol, bleach or odoban to kill the smell..... good luck
Oct 09, 2014 | Westinghouse Refrigerators
I have a WESTINGHOUSE WSE7000SF side by side
Yes, they can and there will be a wayer line on the freezer door side that will also need to be disconnscted at the bottom.
Sep 21, 2014 | Refrigerators
Westinghouse fridge freezer model RS6437*4 FRIDGE SIDE KEEPS FREEZING UP
Could you please check that model number again? The number you posted came up as a range. The model number should be listed in the refrigerator section.
Oct 17, 2012 | White-Westinghouse White Westinghouse...
We have this model westinghouse fridge which currently opens to the right but are moving house and the fridge needs to open to the left. I can see holes on the left side with white plugs in them so it...
Yes depending on age. once changed doors never seal properly. because cabinet warps and seals flatten on one side. suggest to sell and buy another. you will never be happy if converted.
Aug 30, 2010 | Refrigerators
Freezer not working
Your refrigerator has a Control-defrost,adaptive timer ,PC board part number 241508001
This is providing your model is the one listed above your post WRS3R3EW. The model you listed in post does not come up. Until we can determine that the freezer is not defrosting you need to unplug and remove the back panel of freezer compartment to see if the evaporator coils are frozen or clear. If frozen this alone will cause a chain reaction that keeps vents to fresh food compartment open and cause freezing in that area. Go to link below and enter model number WRS3R3EW0 Then you will see a list of diagrams on left side, chose #11 this will show the control parts. Click link below Thanks, Sea Breeze
We offer free help and assistance also.
http://servicepartstec.blogspot.com/
Apr 27, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Mar 31, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
It won't be the defrost timer, unusual, it will be the defrost element inside the freezer section behind the back panel or a shorted defrost klixon.
Mar 30, 2008 | Refrigerators
How to move the fridge
The wheels are probably OK, the tech likely lowered the leveling feet in the front to keep it from rolling by accident. Turn the little level legs (the screw up into the fridge) until the weight is back on the roller wheels, then you should be able to move it. A pair of "channel lock" pliers on the rubber feet work the best depending on how much weight is on them.
Dec 30, 2006 | Amana ARB2217CSR Bottom Freezer...
Refrigerators Logo
107 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
