Have a Alto Active x tra High pressure washer and it keeps contantly pulsating have followed instructions for trouble shooting but does not cure it. any Ideas.
  • 41 Answers
Have you bled the air out of the supply hose could be an airlock.
leave power off and pull trigger until no more air comes out of nozzle then turn power back on
Posted on Jul 14, 2008
Alto 4050 x tra diagram
It could have a crack in the water input switching assembly (where you screwed the connections onto).
Oct 28, 2017 | Garden
Ultimatex pressure washer problems !
Ultimate-X 1500 PSI Power Washer ?the nozzle maybe set to low pressure....try pull push nozzle or twisting
http://repairshed.blogspot.com/2013/09/pressure-washer-lance-nozzles-what-you.html
Jul 13, 2013 | Garden
Landa pressure washer LT 4035-4000 psi. Why is it losing pressure and continually pulsating?
If the pump is pulsating rapidly most likely valves are leaking or debris under valve keeping one or more from closing. If the pump pulsates slowly, comes up to pressure then low pressure then repeats, problem is pressure regulator /bypass. Or you could have a combination of both. Try lowering the pressure to lowest setting to see if slow pulsation stops. As parts age within pump and debris hinder operation you can no longer operate at full pressure. To make the pump last, use highest pressure as needed and everyday work using only 60 to 75 percent of capacity.
Mar 19, 2013 | Garden
How do I adjust the pressure on an old Northstar Pressure washer. Honda 18.0 HP, GX610 V-Twin
The following link will give you great troubleshooting for all pressurewashers. http://www.pressurewasherservice.ca/serv02.htm
There are several way to increase pressure. Primary way is to turn the pressure regulator knob in the direction to increase tension on the spring. Pressure regulator is located on the pump (or very neer) and usually has a large spring. Sometimes the spring is hidden under a twist knob. If the adjuster seems to be already turned to max then you may need to just change the pressure tip. The tip/nozzle is actually where the pressure is created by restricting the flow of water thru a very small opening. Use a new tip of the same gpm flow that is required by your machine. 18 hp machine has potential for very high pressure and high gallons per minute. Use trouble shooting guide above for more information. Good luck
Sep 30, 2010 | Northstar Garden
Pressure washer pulsates
Could well be the main jet slightly blocked in the carburettor.
Jun 04, 2010 | Garden
Hi I have an Alto Force and it it has simply stopped operating. Fused changed etc but still no luck.
Try the machine without the high pressure hose on. if that fails you will need to check that you have power to the switch on the machine.
May 21, 2010 | Garden
Pulsating when idle
The motor doesn't pulsate when you are spraying and pulsattes when not spraying is normal otherwise the pressure will just keep building and burn out the pump. However, if you are not using the sprayer right away then the unit should be shut off until your ready to start again.
I hope the answer is helpful, please rate if the answer has helped in any way. Good Luck and have a great weekend.
Apr 03, 2010 | Karcher K 3.98 M Electric Pressure Washer
Kew Alto Force X-TRA cold water supply pressure sensor problem
Have the same p-washer (5-6 years old) and the same problem. Opened it and the pressure switch is the crook. A plastic pin has an inner and an outer spring on it (two consentric springs). The smaller inner spring is completely rusted away so the switch no longer operates correctly. Obviously the spring was of a too low quality. The service office say a new switch cost around 400NOK (50 euros) - so the washer is too expensive to mend. But I will try to get it working without the inner spring. Doubt if I succed. So will have to dump the washer.
Mar 19, 2010 | Garden
Pressure washer is pulsating when powered on
it just the presure building back up ,it will last years doing this,i would not worrie as replacing the presure pump will only be a temp fix and it will do it again ,most washes do this after a year or lots of use.
Dec 31, 2009 | Karcher 1750 psi Electric Pressure Washer
Inadequate pressure from my Alto pressure washer
Clean out spay head nozzle with small diameter wire and check that head is pulled or push in or out for high pressure.
Jul 28, 2009 | Garden
Washing Machines Logo
314 people viewed this question
Top Washing Machines Experts
