Cannot find keyboard configuration program - Computers & Internet
  • 813 Answers
Use usb keybord
Posted on Jul 14, 2008
I have just bought a second hand Compaq 5185 keyboard and I would like to know how to configure the special top buttons. Some work, others don't.
Certain models of HP desktop computer come with an "Internet Keyboard" packaged in with the other equipment. This Internet Keyboard differs from a regular keyboard in that it has a series of buttons along the sides that allow you to do things like open your Web browser with the tap of a button. You can reassign the actions to these keys and reprogram it away from its default settings using your Control Panel.
Click "Start." Click "Control Panel." Click "Keyboard." Click the "Hardware" tab, then click the "Properties" button. Click the listing for the Internet keyboard key you want to change. In the "Target" box, select the program you want that key to open. Click "Apply." The specified key will now open the specified program. Repeat this step for all of the other keys on your Internet keyboard that you want to configure.
http://windows.microsoft.com/en-US/windows7/Keyboard-shortcuts
Feb 01, 2013 | Computers & Internet
I would likke a manual for a toshiba L775D computer that explains the keyboard and etc.
Until now, I've never found a software that can be used to fix keyboard.
Based on experience, in keyboard have configuration button, which can be used to turn off, the hardware functions. When we press a button, the keyboard will ignore damage to the hardware.
Configuration button is press one button or several buttons at once. There is no manual that I have ever read. I'm using experience, instinct and trial and error method, to fix keyboard without replace keyboard.
Dec 05, 2011 | Toshiba Computers & Internet
Microsoft wireless keyboard 4000 and wireless mouse 5000. Installed software and recognizes mouse and keyboard but only funtion as standard devices, none of the bells and whistles work. open software and...
If you want to check if the software is installed correctly and the keyboard is working fine try using the multimedia key. If you are able to use the multimedia keys for reducing and increasing the volume or mute the sound that means it is working fine.
If you are trying to configure the Favorite keys then you will have to select the buttons from the software and link it to the particular program of your choice.
Open the software application
Select the button that you want to configure
Click on the browse button to select the program of your choice to open with that button.
Jul 21, 2010 | Microsoft Wireless Optical Desktop 5000...
How to unlock a laptop keyboard
You can manually test which mode the keyboard is set to and change its configuration by following the steps below.
  1. Open a word processing program and type the word jump on the notebook's keyboard.
  2. If the word displays as jump , then the keyboard is set to its default mode. If the word displays as 140* , then the keyboard has been set to a number pad configuration.
  3. To switch modes, press Fn + Num Lock . (Fn key is next to Ctrl key on the left)
  4. Type jump again to confirm that the keyboard configuration has been reset.
The keyboard's configuration has been successfully reset.
May 27, 2010 | Computers & Internet
Mx5500 no connection
Windows 7 firewall program is blocking your program.
Dec 31, 2009 | Logitech MX 5500 Mouse
Reasons won't record midi data
Hi Danadepatter,
You have to check were the problems is, with exclude way.
1. you first find out if your "master keyboard" really works: Try to run another program where you can run the the keyboard(you can use a trial and the uninstall it after)
2. if that works then it is another place not the keyboard, then it can bee the program / sound card / configuration . you can find the reason manual here :
http://www.scribd.com/doc/13823619/Reason-4-Manual-English
Check if the configuration to the midi keyboard is ok.
FOR THE SOUND CARD: be sure that you do not have anything else that can interrupt the sound card. Shut down other recorders and other software that use the sound card and bee sure that you use the same sound card configuration (normally it is realtec the default)
If nothing happens please go to the support here for Reason software :
http://www.propellerheads.se/company/contact/techsupport/index.cfm?fuseaction=get_article&article=reasonsupport
Hope that helps
Have a nice weekend
Please rate my answer
Sep 25, 2009 | Propellerhead Reason 3.0 (991010004) for...
Programming the MAIL button
make sure that you have loaded the right drivers for you keyboard. under control panel go to keyboard ther should be a tab that allows you to configure going to a standard version of outlook ar you may be able to set it to go to a specific url if not using a microsoft product for your mail
Jun 04, 2009 | Computers & Internet
Keyboard 10 key, digits aren't working, just the symbols
it is sure that keyboard has not any problem, check the foloowing:-
application configuration
setup configuration
virus
shift key pressed
Nov 03, 2008 | HP Compaq nc6000 Notebook
Keyboard changing key configuration
the key combination you mention is Left Alt + Left Shift.
It changes the keyboard layout to the next one in the listed of available keyboard layouts.
To configure the layouts, go to Control Panel -> Regional and language settings -> Languages tab -> Details
Under Installed services, the keyboard layouts that are currently installed are listed.
If you don't need to change (is needed if you want to type norwegian for example, since it has some special characters), you can simply remove all unnecessary layouts.
May 23, 2008 | Logitech Cordless Desktop S 510...
I need to program my email key to look at my current outlook 2003,and not pick up a new version
The steps for configuring keyboard drivers in Windows XP are different than in other operating systems. Use the following steps if you have already downloaded and installed the latest HP keyboard driver for Windows XP. Step 1: Configure Internet and shortcut buttons
  1. Click Start , and then Control Panel .
  2. Click Printers and Other Hardware and then Keyboard or click Keyboard if you are in Classic view. The Keyboard Properties window appears.
  3. Click the Buttons tab. You will see a list of Internet and shortcut buttons.
  4. Double-click the button you want to configure (such as, CONNECT or Internet).
  5. Configure the button to open a Web page or software. The figure and table below explain how to use each field in the Configuration window.
  6. After you have made your changes to the button's configuration, click OK .
  7. On the Keyboard Properties window, click Apply .
  8. Repeat the previous steps for each button you want to configure.
  9. After you have configured the buttons, click OK on the Keyboard Properties window.
May 20, 2008 | Computers & Internet
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
