Question about Rio Carbon MP3 Player
I have changed the hard drive to a 16 GB
It works fine but it over heats to a untouchable degree please help me
  • 1 more comment
  • Edward Welch
    Edward Welch Nov 17, 2008
    u r gay it is wrong i broke it and its possiable u noob!!!!!!!!!!!!!!!!
  • Edward Welch
    Edward Welch Nov 30, 2009
    ??????????????? but i have??????????????????????
    ur a bit wrong there!!!!!!!!
  • mowcius May 11, 2010
    This is obviously untrue because the Rio carbon does not accept hard drives or CF cards of 16GB capacity. The highest a Rio carbon could theoretically accept is 8GB.
    Guru:
  • 155 Answers
This i not a possible problem due to the Rio Carbon only accepting a theoretical size of 8GB in a hard drive or CF card. There are no components in a Rio Carbon that could heat to such a high temperature unless you class 30 degrees C as an untouchable degree. If so then you are an idiot.
Posted on Jul 16, 2008
MY Transcend external drive of 160 GB was working fine in my DVD player (Phillips) but after formating the same, the DVD player is not yet to read the contents (music, movies, etc). The file system...
Windows has limitation over 32GB,
you need to use a free tool like this:
http://tokiwa.qee.jp/EN/Fat32Formatter/Fat32FormatterEN.zip
unpack and use as following:
in Physical choose the disk carefully, you can erase your main disk accidentally,
click in the blue area and it change the color to green, (in this moment has a NTFS filesystem)
then choose Delete Partition and OK, the HD area change its color to grey,
choose again the grey area and again it change to green,
if you know very well your hard disk choose Quick Format, otherwise it could takes a long time to reformat.
Click on Start and it Makes the rest.
i hope this will help you!
Jul 09, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
When I insert my LaCie iamaKey Flash Drive - 16 GB into my Mac computer it reads "The disc you inserted was not readable by this computer". I have tried it on other Macs and it says the same. It...
Some flash drives need to be formatted for the the device that you use it on.
the Mac you are using it on may not recognize the device and see it as incompatible.
Jun 13, 2011 | LaCie iamaKey 130871 Flash Drive - 16 GB...
Kingston Data Traveller DT101 16 GB. Plug it in, no LED flicker as it usually had. PC assigns a drive letter as removable disk. Clicking drive letter results in "please insert disk". Second Data...
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options update driver disable uninstall scan for hardware changes
select properties you should see options in the general tab to troubleshoot policies volumes driver and details under the driver tab you will have the options to check the driver details update driver rollback driver or uninstall
hope this helps
Apr 11, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have bought a new 16 GB data traveler. when it is insert in computer the computer does not give any response.Did some instalation is needed?
hello, if this is new and not responding to your computer, try other usb device see if that will work w/ you computer, if it does so most likely this 16 GB is not working at all, final test is try this 16 GB to another computer see if that will work. if still not working, return it to were you bought it. Thank you for using Fixya.
Mar 08, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Firelite 49 GB is no longer recognized by my PS3
hi,
it's cause when you formatted the disk, you choose to use ntfs file system and ps3 can only read fat32.
when you format a hard disk or eaven a usb drive you can choose wich fort to use.
there are different tipe, most common are fat, fat32, and ntfs.
most actula operating system uses ntfs, but fat32 is still he more compatible.
reformat your hard drive as follow:
got to "my computer" on your desktop, right click on your hard drive and choose format.
a window should pop up.
under file system chose fat32.
leave untouched all other fields.
you could perform a quick format, but i suggest a full complete format, so leave all untouched and wait till end.
now it should work.
regards,
Paolo.
Jun 04, 2010 | Verbatim SmartDisk Firelite Portable USB...
Gateway m 1625 operating system not found and its overheating
This means either the operating system on your hard drive has become corrupt and you will need to reinstall your operating system or, more likely, your hard drive has failed and you will need to replace the hard drive and the operating system.
As for your heat issue, use a can of compressed air and blow out all the vents on your laptop. This should help the heat issue; note that it is common for the laptop to feel hot as it is dissipating the heat from inside.
Thanks and please take a moment to give this solution a thumbs up rating with a solved solution as I answered your questions. Thanks.!
Apr 05, 2009 | Gateway T-1625 Notebook
Hard for key to turn to ignition on 1996 dodge ram
Hi! Your ignition key switch is defective, by u forcing it to turn causes more damages.You should get it changed.
Dec 31, 2008 | 1999 Dodge Ram
Heating problem
Hi Radan, Did you get this problem solved? We have an Electrolux Kelvinator Split System and ours is doing exactly the same thing. I am struggling to find a solulution. Would be great if you can offer any advice.
Thanks Nicolle
May 03, 2008 | Heating & Cooling
Heating problem
The LG>LW5200ER AC is not listed as a heat providing unit. Click on link and this will give you the spec's
http://www.epinions.com/pr-LG_LW5200ER_Air_Conditioner
Hope this helps.
Oct 19, 2007 | LG LW5200ER Air Conditioner
Rio Carbon MP3 Player Logo
103 people viewed this question
Top Rio Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
Joseph Hoffmann
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
