Question about Panasonic Televison & Video
The drawer of my DVD player opens and shuts whilst empty but if I put in a DVD it shuts but will then not load the DVD and will not open. I have tried several DVDs. New ones straight from the packaging and ones that played OK only recently.
  • david_dally Jul 15, 2008
    Dan,
    Thanks for the reply. The make is PIONEER and the model is XV-DV77.
    Dave
  • 4,234 Answers
I would first suspect that the loading sequence is not completing properly. If the tray works without a disk, but has problem with a disc, the most likely problem is a slipping loading belt. Without knowing the make and model of the unit, I can't give you details, but I have seen this symptom with many units.
Can you post the make and model?
Thanks,
Dan
Posted on Jul 14, 2008
Whilst putting cd into my hi fi accidentally pushed close button drawer closed before cd properlyinserted. Now I cant open to get cd out
Look close, many times there is a tiny hole the size of a needle by where u put the CD in.
Pop a needle in there and it will release the CD as it opens the door.
Oct 19, 2015 | Televison & Video
Samsung blu ray player, dvd drawer will not open
Either the loading belt or loading gear wheels have the trouble. Sometimes the disc loading mechanism might need replacement. It won't cost mor for the mechanism. But will feel some difficulty in getting it from open electronic spare part market. it will be best to contact the authorised service center for Samsung to get it repaired.
May 12, 2012 | Samsung BDD5500 Bluray 3D Player
Wrong region message
power on.
open the drawer & LEAVE IT OPEN
press on the remote control
1 3 7 9
four small stars appear in the top left of the screen whilst you enter the code chose whatever region you want 0 is region free
once the code is entered simply enter the region number you require, close the drawer & press play
Mar 31, 2011 | Daewoo DVG-8500N DVD Player
Dvd "drawer" will not close.
The reason the drawer will not shut is because there is a problem on the mechanism that opens and closes the disc tray.
To fix this,
Get the appropriate screwdriver, unscrew the cover, you'll see a mechanism by the side of the opening, you'll see a rubber that controls the opening and closing of the door.
Try to replace the mechanism and it will be in good condition again.
take care
Jun 12, 2010 | Onkyo DV-S353 DVD Player
DVD drawer won't stay closed
the open button could be shorted meaning the unit is constantly being told to open its tray i think its worth having looked at and i think your sons off the hook dvds are pritty hard for kids to muck up unlike the older vcr you would no belive the things kids would put in them best one i ever saw was a weat bix and a slice of toast.
good luck
May 15, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
DVD drawer does not open when you push button to open DVD drawer
The most likely cause is damage, which should be seen with the eye. It could be a belt, broken cogs/teeth in the sledge mechansim, or a micro leaf switch bent out of place.
Apr 05, 2010 | HP dc4000
Can't open dvd drawer
try putting a Blunt knife into the top of the dvd drawer, or where you can get a knife in.
And gently prise the drawer open whilst pressing eject on the Player.
Failing this, you will have to *****disconnect from the mains***** remove the screws on the rear of the casing, remove the top cover, and take out the DVD Disk.
Replace then plug back in, to check if the player is Ok.
**** Only remove the casing if you feel competant**** And if the player has no guarantee Or Warranty****
Mike @ Compurepair.
Jun 12, 2009 | Samsung DVD-P241 DVD Player
Lg rc797t dvd drawer will not close consistently
I have a Compaq Presario desktop running XP Media Center. The DVD tray would open on power up, and kept openinig when pushed shut.
I discovered that the tray would frequently remain closed when I held open the flap (the flap with the open button). A few days after discovering this, I got to add some more tracks to my MP3 player - I only mention this intermediate stage in case it is material in curing the problem, as the next thing that happened was a power failure whilst the PC was on. Since then, the CD/DVD drive has behaved perfectly. I did have a temporary problem with AVG INternet Security being unable to load the necessary DLLs to run correctly in MS Outlook 2003, even complaining of a corrupt installation, but this dissappeared after a proper restart and AVG update.
So,
Compaq users: try holding the flap open when you attempt to close the tray.
Generally: with PC running and all applications closed, switch the power off at the wall socket.
HTH
Roger
Shaftesbury (UK)
Jan 25, 2009 | Computers & Internet
The drawer on the unit won't open.
When the DVD player is plugged into power and switched on, and won't power up (nothing shows up in the front display panel), the power supply unit in the DVD is blown. the noise that player made was probably a capacitor going off. You will have to get the unit repaired.
Jul 28, 2007 | NexxTech DP3222 DVD Player
Televison & Video Logo
55 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
