Have single horizontal line on 36" sanyo crt. believe vertical control circuit. what are common problems that i can check?
  • 4,234 Answers
This is usually a failure of the vertical IC. This should be a small flat IC attached to a heatsink and may be marked LA7837 or something similar. If you can solder, try resoldering the pins first as poor connections can cause this as well. If that fails to resolve the problem, replace the IC.
Dan
Posted on Jul 14, 2008
Screen picture shrinking . Two wide white horizontal lines
Check vertical output circuits. They control the up and down deflection and when not working you get straight line across front of tube.
Aug 02, 2015 | Televison & Video
TV has a great picture but wont "hold it". Keeps going to a single flat horizontal line across the middle of the screen. Tapping on side of TV used to bring it back but now, nothing. Just a line.
Vertical scan output section circuit fault. Absence of vertical scan causes the single horizontal line on screen. Horizontal scan output section is OK. Contact any service technician to troubleshoot the vertical scan output section circuit. If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Horizontal line fault to CRT based TVs are given.
Oct 06, 2014 | Televison & Video
After power on the screen goes very bright(white) and then immediately reduces to a single horizontal line and powers off within 3 secs
This is a problem with the vertical circuit and can be as simple as poor connections at the vertical IC or a defective IC. Expect a parts cost in the $25 range for this repair.
Dan
Aug 14, 2010 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Picture go into a thin line.
You have a thin horizontal line in the center of the TV. You, in this case have vertical IC that has bad grounds. Resolder the vertical IC pins and check the capacitors in the immediate area and replace these caps as necessary. If you still have a horizontal line, you will have to replace the vertical IC. Find a TV tech or someone with electronic experience to do this for you. Should be reasonable to fix. Thanks for asking and Good Luck!
May 30, 2010 | Sanyo AVM-3659S 36" TV
Vertical line in center
If the line is "vertical" then the vertical circuit sounds OK. The problem would be in the horizontal deflection.
Check yoke connection and solder around horz defl circuit.
If the line is horizontal then I would suspect the vertical IC.
Apr 02, 2009 | Sanyo DS31520 31" TV
The screen just shows a single line in the center from top to bot
vertical deflection failure. either solder on vertical ic, or bad capacitors in vertical circuit, and bad resistor &or ic failure. we fix these in home for 150.00 including 1-year warranty and trip. (oh plus tax for the next stimulus) mch
Mar 08, 2009 | RCA 36F530T 36" TV
I have a KV27FS210 sony wega trinitron tv. It turns on and has a single horizontal line across the center of the screen then buzzes shows a continuous zigzag line from the top to bottom of the screen with...
The single horizontal line is a problem with the vertical circuit. Look for a small flat id attached to a heatsink that should be marked LA7837 or something similar. Try resoldering the pins of this IC first. If that does not resolve it, replace the IC.
Keep us posted.
Dan
Feb 20, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
RCA-single horizontal white line
Your vertical deflection IC is bad.
Nov 04, 2008 | Televison & Video
Single Horizontal line
The vertical IC has failed. Open up the back and look for a small flat IC attached to a heatsink. It should have about 11 pins or so and be marled LA3847 or something similar. First try resoldering the pins as it is common for the connections here to go bad. If that fails to resolve the problem, replace the IC.
Keep us posted.
Dan
Aug 18, 2008 | Mitsubishi CS-36609 36" TV
Horizontal Line
A LINE left / right thru the middle ( horiz line) indicates a problem in the vertical circuit.First step is to solder the pins of vertical o/p
IC.........Next, troubleshoot vertical circuit to look for problem...T.
Please rate solution................................
Nov 15, 2007 | Hitachi 36CX39B 36" TV
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
