Maybe the problem why your device won't charge it is because of the usb cord you are using or it is either the usb in your device. To fix your problem, you need to simply check your cord if it is still functioning and the usb in your device. If the cord does not functioning at all, better buy a new one in order for you to charge again your device and to use it again.
SOURCE: When charging the spy net
Did you push the left button (has a green minus sign) at the bottom left of the video display? The battery indicator will be on the upper right.
SOURCE: Do you connect to a
Yes, connect it to a computer to charge the battery. Push the left button (green minus sign) at the bottom left of the video display to turn on the battery indicator.
SOURCE: what do i do if
I am wondering the same thing. My son got it for Christmas and I just plugged it in and it doesn't appear to be doing anything. I also would like to know how to hook it to the internet. It doesn't read when I plug it into the USB port.
[email protected]
SOURCE: how to charge spy net watch
"The Spy Net Video Watch will need to be charged via the USB charger that comes with the unit. Although the watch comes with a small charge out of the box, you will definitely want to charge the unit before use. The approximate charge time is a reasonable 2 hours and can be charged via a laptop or home computer. If the watch ever loses its charge, there is no risk of losing any data since it uses a fail-safe memory feature that keeps your data secure and safe. Like most electronic devices, you may see the watch "freeze" from time to time, but you can fix this quickly by holding down the reset button on the side of the watch."
http://www.populartoysforchristmas.org/spy-net-secret-mission-video-watch/
