Question about LG 24 in. LD-12BW5 Free-standing Dishwasher
LG DISHWASHER THE DETERGENT TABLET WON'T POP-OUT DURING WASH CYCLE, WHEN THE DOOR IS OPENED ITS STILL INTACT, AND DISHES ARE LEFT DIRTY AFTER NORMAL CYCLE.
    Problem Solver:
  • 11 Answers
This is a common fault if your drain hose or the drain pipework after it is blocked by tissues or fluff etc remove the drain hose from the vertical drain pipe or u-bend connection and check that all are free of obstructions. Also a lot of machines have a filter located at the bottom of the machine either behind a flap at the front or located near the pump at (usually) the back of the machine underneath. This can be got at by either removing the back panel if there is one or tilting the machine forward to access it from underneath chock the drum with wood to avoid drum suspension damage or re- attach the drum bolts which were removed when the machine was delivered if you still have them. The pump will have a rubber hose attached before it and the pump is connected to the machine end of the drain hose, often the rubber hose is large bore and incorporates a hard plastic filter designed to trap buttons coins etc before entering the pump and damaging the impeller blades, remove any debris.
In essence you are making sure the the whole drainage route from the drum to the final drain point is clear and free flowing.
Posted on Jul 14, 2008
  • sandip  panchal
    sandip panchal Jul 19, 2008
    u have to with a proffesinol repair he will charge u for this $50
Initially the soap dish had residual detergent (cascade packets) but now the detergent door won't open during cycle
probably needs a new spring. you can order a whole new door with spring easier, just search google for appliance parts
Jan 26, 2012 | Jenn-Air Dishwashers
Soap dispenser not emptying during cycle. Dishes
Checkout this tip that I wrote about that problem...
Dishwasher Repair Problem Detergent Cup does not Open
http://www.fixya.com/support/r4225828-dishwasher_repair_problem_detergent_cup
Dishwasher Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Jul 18, 2010 | Maytag Dishwashers
Dishwasher 3 in 1 detergent tablet not dissolving.
I believe that the instructions for using these 3-in-1 tablets is to place it in the open dish detergent cup, rather than in the closable compartment, since the tablet needs to get doused by a lot of water in oder to fully dissolve and be effective in getting the dishes clean.
Since the tablets are designed to dissolve more slowly, they are able to be used for the entire range of washing cycles. If it's a constant problem and you don's have an open detergent cup below or next to your closed detergent dispenser, just toss it into the bottom of the dishwasher instead.
The reason that the tablet isn't getting dissolved fully is because the door is preventing the tablet from dropping all the way out and the door is shielding the tablet from quite a bit of water spray.
Another option is to take a look at your owners manual for the dishwasher and see if they recommend these all-in-one tablets versus regular powered detergent and liquid rinse aid.
Hope that helps and best regards!
Jul 31, 2009 | Electrolux Dishwashers
My whirlpool dishwasher soap dispenser is apparently not opening during cleaning. I find dirty dishes and clumps of soap in the hopper. Whirlpool quiet partner II
I bet your clumps of soap began with the beginning of the use of a different DW detergent powder.
Try this (trust me) Go buy a box of brand name Dishwasher powder (e.g. Electrosol or Cascade) Use it for two loads of dishes and report your results back here. OK?
Apr 17, 2009 | Dishwashers
Doesnt dry dishes, top rack not clean, has been serviced 3 times
If you have checked everything that was mentioned (and none of them are the issue) then either the heater inside the unit is not coming on during the wash and rinse cycles and/or the fan motor inside the door is not coming on during the dry cycle. A technician can easily check this out with the correct tools and by putting the unit into test mode.
As for the top rack dishes being dirty and there being soap left in the dispenser, this sounds like wash motor is either weak or the vario motor is not switching between the upper and lower spray nozzles. The sump assembly should be replaced for this issue.
Jan 18, 2009 | LG 24 in. LDF7810 Built-in Dishwasher
Frigidaire Model FDB2810ldc0 s/n:TH43526319
Dishwasher is leaking water from underneath during the rinse cycle and a small drip during the wash cycle
Sep 22, 2008 | Dishwashers
LG Dishwasher model LD-1415M. Detergent compartment not opening during washing cycle. Any ideas? Cheers. Joe
First off, clean the detergent dispenser as best you can using white vinegar.. make sure you get any and all left over soap deposits off the cup and edges of it then,... try cycling the dishwasher without any dishes on the hottest setting and after it is about ten minutes into the cycle.. pause it and add two cups of white vinegar inside the dishwasher.. That should remove most , if not all left over deposits from the system. See if that frees up the dispenser .. Make sure the drain filter is has been cleaned thoroughly prior to running this process.. Hope this helps...
Sep 14, 2008 | LG Dishwashers
Dishes won't come clean
If you have dishes (typically cutting boards or really tall dishes) that block the dispenser door from opening, the water cannot wash out all the detergent during the wash cycle. Check to see that after loading the dishes, your detergent door has clearance.
Aug 26, 2007 | Frigidaire 24 in. FDB126RB Built-in...
Tablet door dosn't open during cycle
It sound like a detergent cup issue (the door doesn't open at time) A very simple test for it is to place a tablet on the bottom of the dishwasher for a full cycle and to see what happen to the tablet. In case the tablet will be dissolved : - The detergent cup can become clogged with old dried detergent that prevents it from opening at time. Sometimes just cleaning the cup takes care of the problem. - The detergent cup opened by a bi-metal switch or a wax motor located inside your dishwasher door(behind the detergent cup). If cup's cleaning will not solve the problem, you should replace the bi-metal switch or the wax motor (depend which of them is used in your machine). Good luck !
Jul 02, 2006 | Hoover 24 in. DT999 Free-Standing...
LG 24 in. LD-12BW5 Free-standing Dishwasher Logo
207 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
