Pic focus & convergence
Have to pic/focus then align covergence crossairs each time i switch on !! is it just the ic's (stk392-010) that need to be replaced ??
  • spudy40 Jul 16, 2008
    soldered joints appear ok
  • 4,234 Answers
Before you replace the ICs, try resoldering the connections on them. Also check the area for other poor solder connections. Resolder any that appear tobe grainy or have rings. Update this with your results and report if the symptoms change.
Thanks,
Dan
Posted on Jul 14, 2008
  • ABRsvcs Jul 16, 2008
    If the solder joints are good, then the ICs are most likely defective. Replace them and the problem should be solved.
    Keep us posted.
    Dan
Magic Focus button will not line up picture. Red and green colors shadow images.
The tv have a problems known as a convergence picture problems it is dead.The tv have any colors lines like R,G,B mis alignments,tv have any colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead and the causes of these problems.The tv convergence board must have to repair like replacing like 2 STk covergence ICS and some or all of it resistors too.To fixed the tv convegence board to solved the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
Sep 02, 2011 | Hitachi 53SDX01B 53" Rear Projection...
The red light is out of alignment convergence
Tv colors lines R,G,B mis alignment any way,the tv covergence board these parts are dead.The 2 STK convergence ICS and s ome or all it resistors are dead.The shop will,cost u $300-350 for parts and labors.
Sep 13, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Won't stay in focus? keeps getting red out of focus.b
Tv have a problems known as a convergence problems,it dead.Any colors lines R,G,B mis alignment.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved the covergence problems.Try website like Tvrepairworld.com to buy a whole refurbish convergence board for the replacement.The Samsung/Akai tvs used the same convergence board.Or the shop will cost u $300-350 for parts and labors.
Aug 19, 2010 | Samsung Televison & Video
Unable to flash focus, red curved lines at the top of screen, manual convergance will not work, problem started after a lightning storm with power surge
Ur tv now,totally have dead parts,on the tv convergence board.That,why ur flash foucus or manual covergence alignment R,G,B colors line will not matches up.The convergence board parts 2 STK convergence ICS and some or all it resistors,must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 29, 2010 | Sony KP-51WS510 51" Rear Projection...
The blue is blury
This tv have a problems call convergence,it dead.The tv convergence board must have the 2 STK convergence ICS and some or all it resistors are dead.These parts must change to solved covergence problems.The shop will cost u $300-350 for parts and labors.
Jun 12, 2010 | Hitachi 57F500 57" Rear Projection...
Out of focus
Ur tv have a problems known as Convergence,it dead.The convergence board the 2 STk convergence ICS and some or all it resistors are dead.These parts must be change to solved covergence problems.The shop will cost u $300-350 for parts and labors.
May 26, 2010 | Sony KP-51HW40 51" Rear Projection...
Zenith R56W36 covergence problem
you will need to replace conv ic's then auto converge..
Oct 19, 2007 | Zenith R56W36 56" Rear Projection...
Convergence Problem?
If one of the colors (red, green or blue) is suddenly shifted, especially on one side of the screen, then one of your convergence IC's has burned out and needs to be replaced. A good rule when this happens is to replace both STK392-110 convergence output IC's with the updated and improved STK392-150's. This is by far the most common failure in those projection sets and is fairly easy to correct. If you do not have experience in replacing covergence IC's and realigning the convergence circuits then allow a qualified tech to handle it for you.
Aug 04, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Convergence.
possible covergence ic are faulty and that your sensor is either sensing it or is at fault also,can the pattern be corrected with adjustment,if not your amps are the fault.
Apr 26, 2007 | Hitachi 51F500 51" Rear Projection...
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
