The power supply is a 5 VDC, 500 mA (outer negative, inner positive) commonly used for mp3 players, but probably you must cut the mini usb plug and adapt a compatible jack with the hub.
I've found I have more things with this power supply mini plug: I have an old chinese mp3 with a little hole in the side to plug a power supply, and I have a FM Signal Transmitter (with a plug for audio it is for sending the audio of any source that can take headsets, up to the air as FM radio to hear "wirelessly" in my car radio), and I have some pair of mini PC/netbook/cell baffles with USB powering and a deck for my smartphone. In this mini baffles, the usb powering cable is on one side an usb plug, but at the end of the wire is a little plug made of the same size and +/- as for the Encore! I think you can either connect the usb to a "USB port power supply" that are cheap and has a usb power out, if you get this USB power cord, it would be solved with an power supply of the kind that has USB female plug in.
