I have a Philips FW530C/22 and it keeps coming up saying no CD on every one I put in. It will not even read a CD Lens cleaner any help would be great Thanks Dave
  • MikyM Dec 30, 2008
    Message "no disc" when I want to play a CD .
CD Pick-up needs to be replaced.
VM1201 CD MechanismPhilipsis the replacement around £23-£26 to buy new one
Posted on Jul 15, 2008
Put cd in, says it’s reading disc, after10 seconds it says Not Playable, then ejects disc
hi Nancy.
this could be dust on the lens that reads the disc.
Use a disk-based lens cleaner to remove ground in dust or dirt from the CD player's lens. These lens cleaners look like a regular CDs, but have specially-made bushes on the reverse side that gently remove excess dirt from the CD-reading lens. Simply put the CD in your player, and press the "Play" button to clean the lens. Do not run the cleaner more than once, as excess brushing can cause scratches on the lens.
Polish the lens. Use a glass or eyeglass cleaning solution and a lint-free cloth to gently polish the reading lens. Clean it by using a low amount of pressure and softly polishing the lens and its surrounding area using soft, circular motions. Do this for about a minute or two and then allow the player to sit for a few minutes before trying to play a CD.
read up some more at this link.
How to Fix CD Player When It Won Play Techwalla com
Dec 20, 2017 | Audio Players & Recorders
When I open my Philips DVD player and put in disc it will not load and tells me NO DISC. Please help!
You might want to try using a DVD lens cleaner disc like the Philips CD/DVD Laser Lens Cleaner SVC2330 or SVC2520 or equivalent from many AV accessory vendors to help restore the cleanliness of the player read lens, so that its ability to read discs is restored. These discs have a tiny brush stuck onto the "playing" surface that polishes the lens, when the disc is played as normal. There is often an audio commentary to go with the cleaning.
Sep 13, 2017 | Philips Televison & Video
My dvd player has just stopped playing disc's? I insert a disc, it loads up as the little circle comes up, saying loading. Then it says bad disc.It stops. Does anyone know what could be wrong here?
Couple things could be. I've found : the disc can be dirty, wipe it off. Or if its damaged the lens won't read it.
What usually helps the most is to put a lens cleaner in the player. they sell them. I only have a CD cleaner ( prob called lens cleaner). It still fixes it for me.
Jul 20, 2015 | Televison & Video
I have a philips wireless music center wacs700 when i put disc s in even a lens cleaner disc it comes up cant read disc can you tell me what the problem is
lens cleaner not alway working.use air to blow unit out,,lots of dust inside of units...try to clean lazer with earbud very softly untill it shines,90% its works if not u need to replace lazer and hope its not the mpeg board...im a technician
Mar 28, 2012 | Philips Audio Players & Recorders
Philips mc235B/37 CD player no longers plays CDs. I get a "No Disc" error or an "Error" message. CD's often don'teven spin. If they do, they spin slowly, then stop, and start spinning in reverse before...
if you can see the laser then gentaly with a soft cloth wipe the lens
and then try
if that doesnt work then i recoment that you call philips and see what they say because it is slightly older than one year they might replace it for free
if not call the shop that you bought it from
May 09, 2010 | Philips MC235 Shelf System
Wacs7500 streamium cannot read discs, just says 'no disc' or cannot read disc. have tried a cd lens cleaner with no success
remove the cover and gently clean the lens with a q-tip dipped in rubbing alcohol, then blow the lens dry. if all else fails, replace the optical pickup assembly (lens and spindle motor) or the whole player.
Jan 28, 2010 | Philips Audio Players & Recorders
Disc error when reading dvd
try to clean dvd plaer lens with a lens cleaner...
Jan 14, 2009 | Philips Magnavox DVD/VCR Dual Player
PHILIPS CDR 606 RECORDER. I was useing the above machine till yesterday without any problem at all. Today i keep getting message "insert CD" after i have put a cd in.. I have tried differnt...
Either the optics have failed or the lens is dirty. Try opening up the unit and cleaning the lens using a cotton swab and alcohol. Basically the unit can not read the disk and is requesting that you insert one. If the cleaning fails to resolve the problem, you will need to have the optics replaced.
Dan
Jun 13, 2008 | Philips Audio Players & Recorders
Philips hts 6510 no disk prompt does not play dvd
Ok looks llike a lens problem..Try this
Get a lens cleaner CD with liquid..Put two drops of liquid on the brush of the lens cleaner..insert the CD in your drive and play it..If it plays fine otherwise you will need to replace the lens..Get it replaced rather..should run you about 25-50$.If you want to get it repaired give it for repair only in a Philips showroom..
Oct 15, 2007 | Philips HTS-6500/37 System
Fw316C cd player will not read discs
Buy A CD Lens Cleaner and put it in to the CD Player and keep retrying until the drive plays it and then follow the instructions for the CD Lens Cleaner after its finished try playing a CD if it still wont play try another disc and if it does not play that try reset the player by unplugging it for five seconds if it still wont play the CD drive has failed in the drive and you need a new stereo. Stereos dont last forever so dont be surprised if you need to buy a new one
Aug 17, 2007 | Philips FW316C37 Shelf System
90 people viewed this question
 Grubhead
Grubhead
