Question about Bunn Cuisinart Coffeemaker: Pour-Omatic Coffee Brewer ( O Matic)
Bunn coffeemaker I POUR WATER IN COFFEE MAKER AND WATER RUNS OUT ONTO COUNTER SOME GOES INTO CARAFE BUT ALOT RUNS ON COUNTER.
  • 74 Answers
If you still have warranty on the machine take it in to the nearest service center.
Its probably a lose pipe in the machine. so if you dont have warranty left just open it up and look for lose pipes and reconnect them.
Posted on Jul 14, 2008
We have an older style white Bunn Pour-omatic coffee maker. Model GR. Model # D-267.325. We are looking for the nozzle that screws onto the bottom of the water tank and disperses the water into the...
you should be able to go online and locate a bunn service centre in your area, contact them and purchase a 5 hole sprayhead. It will be metal instead of plastic but will work fine.
Sep 05, 2011 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Should I leave the Bunn Pour Omatic Coffeemaker plugged in at all times?
Yes, the coffee maker keeps a tank of water pre-heated, that is what allows it to brew coffee in a couple of minutes. The exception would be vacation (away from home) or other times when you won't be using it for a few days. Visit www.bunnomatic.com if you have lost your user manual.
Dec 31, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Just bought a new Bunn Thermafresh and it overflows coffee grounds and coffee all over. What can I do?
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Don't overfill the basket with grinds.
2. Ensure you are using the correct grind for an automatic drip coffee maker, neither too fine nor too course. (See instruction manual.)
3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz.
4. Make sure the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Make sure that the Pause 'n Serve button isn't sticking. (If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.)
8. Clean your machine with vinegar or as instructed by your user manual at least three times per year, more if your water supply is hard. A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew, to produce "off" tasting coffee, or to clog and overrun the filter basket as the water runs through the grinds.
9. Ensure that the coffee machine is sitting level on the counter.
Nov 04, 2009 | Bunn NHB Coffee Maker
Bunn coffee maker leaks all over the counter. What
there's probably a 'silicon rubber' hose that feeds hot water to the 'grounds basket'- it may be loose, or damaged. is it leaking water, or coffee?? we have a bunn 8-cup, which has a pre-heated water tank that brews a pot in about 3 min. energy waster, but when you need coffee, you need coffee!!! is your filter holder properly centered? is the carafe lid hole clean and un-obstructed?
if it's leaking water, and not too costly to replace- you may consider replacing it with a new one!
good luck!
Oct 09, 2009 | Bunn GRX-B Original 10-Cup Home Coffee...
No manual with Bunn NHBX coffee maker.
before plugging in place your empty filter basket in the coffee maker and place a pot under it. Slowly pour in two pots of water using the pour pitcher. Now you can plug it in. it'll take 15 min to heat up first time . when you brew your first pot leave your water level a little short,because the water will expand (only the first time)
May 06, 2009 | Bunn NHBX-B Contemporary 10-Cup Home...
The tray where I pour the water is broken at the seal where the water goes into the tank. Where can I get a replacement?
You can call Bunn Home in Springfield, IL at (800) 352-2866. They have a kit which you can try at no charge. If that does not work they will replace your coffee maker at at discounted price provide you send the old one in. Hope this helps.
Apr 07, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
BUNN BT10B carafe leaks from spout down side while pouring
I emailed the company again and they are replacing the thermal carafe at no charge. Thanks!
Nov 15, 2008 | Bunn BT10B Coffee Maker
BUNN Pour-Omatic
Most likely it is your tank heater, but look on the top of the tank heater, because sometimes the wire will burn off the top of the element
May 20, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Lid on carafe
Sadly, I have about 10 people who have this coffee maker. It is a wonderful little coffee maker and is very delicate.
the worst problem all the people here say is the lid leaks like a waterfall or it leaks by dripping non stop while pouring.
I had to call Bunn, who made this machine, and they have yet to figure out a solution to this problem other than having people who own this machine buy a whole new carafe with new seals.
You might try your local applianace repair store. Sometimes their engineers are smart guys who knows exactly what seals will work or where to get the parts you need better than the actual manufacter.
May 12, 2008 | Bunn BT10B Coffee Maker
Coffee Makers & Espresso Machines Logo
271 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
evans_lloyd
Level 1 Expert
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
