Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
F&P DD 603
Hi, these are just about the worst things ever invented, i would love to get a service manual. i have F1 F2 F3 you name it overnight meltdowns and now one has stopped responding altogether...signed ; desperate tea towel in Fiji philipe@pacific.net.au
  • 2 more comments
  • aljunina Jul 22, 2008
    Hi if you want the manual i have it, send me your email address...Philip
  • Tom Toole Jul 29, 2008
    Hi I have an f2 fault coming up all the time. Could I get a copy of the manual please. My email is qazwsx89724@yahoo.com.au. Thanks
  • pgh160463 Aug 05, 2008
    I too would love to see the Dishdrawer service manual. Please email a copy to me for my eternal gratitude! peter.hardern@btinternet.com
  • aljunina Sep 14, 2008
    Hi folks I have just worked out what was going on with the Fix it web pages! Any way I have the manual so if you still need it email me back. I have managed to fix one of the drawers by replacing, controller AUD$129, flood sensor board, AUD$37, hall senor AUD$26 and am now ordering parts for the second unit. Both the controllers have a heater always on failure, this cooks the thermal fuse on the heater that is easily fixed with a piece of solder, then you may get a meltdown of the water sensor PCB after the heater fuse blows, happened on both of mine. It also melts the plastic around the heater so you may need to bed the silicon O rings in with some gutter silicon, mine leaked and fried the hall sensor and that gives a F2, motor not rotating...
Same thing just happened to me. There was a slight leak from the top drawer and it wet the tray on the bottom which caused a short and the circut board and the plug to the top drawer melted. I need to replace the board and wiring harness and am looking for a manual to find out how to remove the faceplate on the top drawer. What you should do first is remove the bottom drawer and check dry the bottom tray if it is wet. There are two circles on the side of the drawer on either side. Turn these with pliers and release the plastic clips on the ends of the drawer slides. you will then be able to pull out the drawer and inspect. Good luck
Posted on Jul 20, 2008
Fuse locations on Technics SA-DX930
I have got a service manual for you which will help you out.Please CLICK HERE
Goodluck..
May 14, 2008 | Technics SA-DX930 Receiver
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Top drawer does not work and bottom drawer flashes on and off
I would need more information to assist you. Drawers run and act independent of each other, the only share to things, drain hose as they connect to each other under the sink, and the power board in which also detects water in base pan. If you have a digital display, what is currently displayed? You lower drawer flashes? What is it flashing F1? F1 is a flood in base pan, F2 is a bad motor. I would need some more detailed information to assist you. Also does you model have panel like wood? This would mean you don't have a digital display.
Please get back to me so I can help you
Jul 22, 2011 | Fisher and Paykel 23 in. DD-603 Built-in...
DD603 gives me an F3 and stops before wash ends, then beeps.
Hi- The F3 fault is related to the water temperature. Probable cause is the controller not sensing the correct water temp. It is also possible the the heater plate is faulty. Hope this helps.
Sep 09, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
Is F1 or F3 the stronger speed for fan
Hi!!
You can view F1 as Low. F2 as Med and F3 as Hi
Don't forget to rate this post!!
Aug 19, 2010 | LG Heating & Cooling
Friedrich xq08m10 - f2 and f3 fan speeds reversed
Unplu cord and remove front panel. Then remove electrical box, you should be able to find the blower motor leads.
Black is usually- hi speed motor
Blue or Yellow is- Medium Speed
Red is- low speed
Just exchange the wires to match the dial
Jun 14, 2010 | Heating & Cooling
My Fisher & Paykel DD 603 has the fault code
Check at bottom housing both top and bottom drawers for leaks.
Pull the tube out, on the left side below the tub you can access to touch the bottom housing. Dry it out with a tower. Un plug the power cord at least 24 hor so the flood sensor can be dried out before pluggin it back.
However, if you don't fix this leak, the sam F1 problem will happen again.
There is not much clogging up in filter. If you expect something clogged up, you have to take the spraying arm off then take out the bottom stainless steel with a lot of holes out to see the impeller clean or not. Good luck.
Sep 10, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
152 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
