Question about Saeco Royal Digital Plus Coffee Maker/Espresso Machine
When i choose which cofffee i want to make the water comes out of the nozzle and not out of the cofffee compartment.
Make sure the prebrew in programming is off or you will get water only instead of espresso. prebrew is for preground coffee in the little door on the top above the digital display and before the bean container
Posted on Dec 19, 2008
  • 515 Answers
Make sure your steam knob is closed and that your brewing unit is clean.
If you have this then it can be the electromagnet that controlls the steam or the electric board.
Posted on Jul 14, 2008
Fabric softener premature release
In my case it was simply a matter of cleaning the nozzles that spray the water into the MAIN DETERGENT compartment. Turns our that when the washer was filling up, some nozzles were partially clogged and were directing water to the side where the softener compartment was, causing the fluid level to rise and therefore releasing the softener early. The washer was NOT spraying water in the softener side, what happens is that the dispenser tray is configured in a way that when the fluid reaches a certain max level in the softener/bleach trays, it completely drains. A way to test for this problem would be to completely dry the softener tray and start the wash cycle like you normally would (including detergent), only without adding any softener to the tray and see if after filling there is any water in the softener tray, this would prove that the water is coming from the other side.
Apr 13, 2012 | Whirlpool GHW9400 Front Load Washer
I have a 2600 Troy bilt pressure washer.When I start the pressure washer,no water comes out the nozzle and the nozzle is not clogged either.I took the nozzle/gun off and there still was'nt any wat
If when you take the High Pressure water hose off the pressure washer pump no water will come out they you may simple have the bypass valve stuck. You may need to just remove the outlet fitting and clean the bypass valve.
It would be helpful to know the model number of the pressure washer or the pump.
Mar 29, 2012 | Garden
Can you incresase water temp on the ESAM 4200 model?
Get a thermometer and measure the temperature of the coffee 10mm below the nozzle while making a long black. A fully functional machine will be between 80 and 86 degrees Celsius depending on the temperature set in the menu. (normal through to very hot) Significantly less than this indicates limescale buildup. Try descaling. If nothing else works, you may require a new boiler.
Dec 25, 2011 | DeLonghi EAM3500 Espresso Machine/Coffee...
Type your problem for a solution...
If you can remove the drawer, check that the water outlet from the compartment is not obstructed. Also, look for a seal between the drawer and the compartment; if there is one, has it loosened or become damaged? Finally, clean round the water inlet nozzle/s with an old toothbrush or similar to remove any deposits that may have accumulated, disturbing the flow pattern. I can't think of any other tips. Good luck.
Jan 11, 2018 | Washing Machines
Ventilate!....shows in window and machine will not ventilate when knob is opened. it has regularly been de-scaled but we do live in a hard-water area.
Generally you can clear the ventilate error by pressing the button for Hot Water and then opening the steam knob. You should hear the pump run and water should start to flow from the steam wand. If it doesn't, try removing the frother nozzle so just the chrome pipe is showing.
To remove the frother nozzle you slide the outer sleeve off, and then grip the nozzle with one hand while twisting the cap to loosen it. Then it should slide off the metal steam pipe. Or you can check that the tip of the nozzle isn't clogged.
If you have the frother removed and the steam pipe is definitely open and not clogged and you still hear the pump running but no water is coming out, the next step is to prime the pump.
If you still have the squeeze bulb pump that came with the machine, you can use that - or if you don't have it, a turkey baster will work. You want to take the water tank off and set it aside, then pump water into the valve in the center where the tank had been sitting. You choose "Hot Water" and open the steam valve so the pump starts and then pump water into that valve with the Turkey Baster. You should hear the pump catch and start to move the water - when this happens immediately close the steam valve so the pump stops - then replace the water tank (filled with water please) and open the steam valve again and let water run out of the steam wand for several seconds.
That should clear the ventilate message.
Oct 21, 2010 | Gaggia Titanium Espresso Machine
After using steamer for milk frothing the red light comes on and cannot get esspresso to brew and no more steam or hot water comes out of the frothing nozzle, the water level is fine in reservior, beans in...
The tap valve is leaking inside the machine needs new seals.If moisture is escaped and hit the printed circuit card on the tap, the machine will stop you from doing other functions.
Feb 05, 2010 | Saeco Odea-Giro Espresso Machine
Water does not get to main compartment
try priming the machine ( find the plastic gizmo that came with the machine for this purprose..can you get water from the steam nozzle?..there is an internal water filter that may become clogged if you aren't keeping the water tank clean.
Dec 14, 2007 | Saeco Vienna SuperAutomatica Coffee...
Saeco Royal Digital Plus Coffee Maker/Espresso Machine Logo
63 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
