Mitsubihi HS-U510 language setup.Menu is stuck on french , how do i get it back to english ?John
HS-M35(NZ) VHS - language stuck on German. Haev no manual.
I have a Mitsubishi HS U520 VCR. It is stuck in the french languae mode.
I have tried holding down the "on" button when turning on the VCR but to no affect.
I would appreciate help.
Thanks,
RonI have a Mitsubishi HS U520 VCR. It is stuck in the french languae mode.
Thanks,
Ron
You can't post conmments that contain an email address.
I contacted Mitsubishi support. It is very likely the 510 and the 520 are similar. I was told to look at the back of the VCR (in the middle and lower) for a "timer reset" button. Pushing it will put you into initial setup mode and you can set your VCR to english menu. It works!
you can wirte down all of the wordsin a list and then use the google language tools, to use it go to google and on the right it will say ; advanced search preferences language tools
then when you get there simply translate the words if you need help imy emaail is [email protected]
Do you have a menu or setup button on the VCR's remote? If you press that, you'll have to look in the menu until you find the language selection. Oh, wait. If it's in Spanish, you might need a Spanish to English dictionary, too. Well, good luck, and just ask if you need more help. I hope I gave you enough info, but the menus vary with every VCR, so I can't be too much more specific.
Hi
Hit the menu button, and look for the word "idioma" which means language, and select that. You should then be able to toggle back and forth between English and Spanish.
You may have to look under "opciones config. vcr" which is VCR Setup to find it.
Hope this helps, Good Luck!
Thanks,
Ron
