Question about Apple iPhone Smartphone
Have you solved your problem?
Did you get answer to your question "still hang after pressing the combo buttons for 5 secs"?
I still have this problem. the only thing i can see is the apple logo.
Ken
It worked, but i had to do it more than a couple of times, twice i did it and the screen went dark but you can still see an impression of the icons. but the next time i did it it got stock in the apple logo so i did it again and it worked. but i took out my sim before hand so i got no service even after i put it back in. so i turned it off then turned it on with the sim again. it was fine after that. i hope it doesn't happen again though. lolz
Posted on Jul 14, 2008
How to hard reset a Harman\Kardon AVR 55
That sounds like a classic case of processor overheating. Open it up and check for a cooling fan.
I found this in Fixya!
All it needs its a hard Reset press the power button once its on standby mode press surr button for 5 sec and it should reset.
This is different
service manual
http://www.hifi-manuals.com/Harman-Kardon/AVR-55/downloads
Jul 17, 2017 | Audio Players & Recorders
HOW TO UNLOCK A PANTECH PHONE WITH TO MANY PATTERN ATTEMS
1. try entering null as password. (together with your google username) 2. try entering your username without @gmail.com
3. Combine 1 and 2
4. Call yourself from another phone, answer, without hanging up press the home button, then menu button, settings, try to disable pattern-lock 5. Call yourself from another phone, answer, hang-up, directly after hanging up start pressing your buttons like a madman for <30-60 seconds ending with your home button (might take a while to get the timing right). Go into settings and disable pattern-lock.
6. go to recovery (vol down + search +power) and do a factory reset/wipe (it will erase all your files)
Feb 18, 2014 | Pantech Great At&t P9070 Burst Smartphone
I can't remember the unlock draw pattern to unlock my phone, what can I do?
Hello Andrin,
Ifyou forget the HTC Salsa smartphone lock screen pattern, which is more thanfive times, you can open it by entering the Google Account user name andpassword. If you have tried to open up to 5 times and still fail, you arerequired to wait about 30 seconds and then press OK to continue. If the screengoes off, press the power button to restart and then open the screen. PressForget pattern when the button appears. Enter the Google Account name, passwordand sign in, you will be prompted to create a new lock screen pattern
Oct 10, 2011 | HTC Salsa Smartphone
Iphone hangs during standby mode.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Sep 26, 2009 | Apple iPhone Smartphone
Touch screen problem
pls reset ur device like this if it doesnt help then u have to get ur digitizer replaced also called touch panel
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
Apr 07, 2009 | HTC Touch P3450 Smartphone
Scrolling message will not go away
press play for 5 sec/ should shut off
if not
try with no tape in press play and rewind at same time for 5 sec
hope this helps.
thanks,
daniel.
Jan 13, 2009 | Panasonic AG-520G 20" TV/VCR
Trying to pair BT150 but it won't go into pairing mode
I had the same problem. The many instructions available don't have quite the right details. This worked for me:
1. Turn off the BT150 by holding down the answer button about 5 sec. until the blue light goes off and is not flashing.
2. Turn on the BT150 by holding down the answer button about 5 sec. until the blue light flashes.
3. Keep holding the answer button, and press and hold the volume + button for another 5 sec. until the blue light comes on solid.
Nov 12, 2008 | Jabra BT150 Wireless Headset
Canon printer mp160 error msg 16 (e16) after replace catridge
try this PRESS STOP BUTTON FOR 5 SEC CAN FIX THIS PROBLEM
after that will adicated light alarm blinking them you can print if can't try turn off printer and turn on again.
Apr 17, 2008 | Canon PIXMA MP160 All-In-One InkJet...
IPHONE HANG UP
press the home keys and power button simultaneously for about 5 secs... it should reboot. :-)
Feb 02, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
20 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
