Question about Lexmark X340n All-In-One Laser Printer
Scanner locked - unlock scanner
At start - Scanner locked - unlock scanner
But the scanner is unlocked... What to do?
    Guru:
  • 1,049 Answers
To unlock a scanner open it where you would put cartridges in and look for a red or green colored tab hanging down. There should be a little picture of a padlock. You can switch it from lock to unlock. It's kept locked to protect the scanner during shipping.
Hope this is helpful...
Posted on Jul 28, 2008
    New Friend:
I have a samsung CLX3175N that says 'scanner locked' but there's no lock button to be found. What to do?
Posted on May 01, 2014
  • 35 Answers
SOURCE: printer is saying scanner is locked, unlock scanner
In the section where the paper exits the printer, there is a blue latch. Pull it towards you. It does take a little pressure to pull. You may need to press cancel a few times. That should clear it out. If it doesn't, The scanning unit assemply needs replaced...or the printer itselft which ever is cheaper.
Posted on Jan 30, 2009
Corysf62
  • 188 Answers
SOURCE: unlock scanner
lift up the scanner assembly to expose the underside of the scanner. slide the locking clip up from the locked position to the unlocked position. ( red )
Posted on Sep 28, 2008
rtrahan
  • 741 Answers
SOURCE: Samsung CLX 3170 scanner locked
Many scanners contain a scanning head lock to keep the scanning head from moving during shipping. This may still be still be in the lock position. All scanners are different but check the documentation on how to remove the head lock.
Posted on Dec 25, 2008
SOURCE: unlock scanner keeps appearing on my lexmark x85 printer
MY LEXMARK X5150 UNLOCK SCANNER
Posted on Aug 30, 2009
SOURCE: scanner locked
Look where your copies come out and there is a switch on the top underside, (green on the M20i) and make sure it is in the unlocked position. You may need to wiggle the switch to fully unlock it. Mine was locked but I was able to re-engage flipping the switch several times.
Posted on Jun 03, 2010
Please solve the problem of 5600/5650 usb scanner please verify that you have UNLOCKED the scanner hardware . The lock is located on the bottom of scanner click ok after you have unlocked the scanner
I have a scanner 5600/5650 UMAX , but it has been started problem since last one week and the scanning of document can not be possible give me solution
May 11, 2012 | Umax Astra 5600 Scanner
Bc898t all 500 channels are locked out. How to unlock all of them
Locking/Unlocking Banks When you are scanning conventional banks, the scanner displays the digit corresponding to all unlocked banks. To lock out a bank so that the scanner does not scan its channels, press the letter that corresponds to the bank. The bank's letter disappears from the display. To unlock locked-out banks, simply press that bank's letter again. The bank's letter appears on the display and the scanner includes that bank when scanning. Note: You cannot lock out all banks. One bank must be unlocked at all times. Locking/Unlocking Channels To lock out a channel so that the scanner does not stop on it while scanning, press L/O when the scanner is stopped on that channel, or manually select the channel and press L/O. To unlock the channel, manually select it and press L/O again.
Mar 29, 2011 | Uniden BC898T Base Scanner
Perfection 2400 scanner fails to scan; just clicks
The only thing that usually causes a scanner error of this type is either a scanner failure or the transport lock. Locate the lock and make sure it is in the unlocked position. Lock and unlock a few times leaving it in the unlocked position then power the scanner off and on again.
Jan 05, 2010 | Epson Perfection 2400 Photo Flatbed...
Dell a940 AIO makes noise as soon as i turn it on then displays unlock scanner - tried to but will not unlock
Found this: http://support.dell.com/support/edocs/systems/a940/a940en1.pdf
Page iv identifies the location of the scanner lock
Page 44 contains the following
• You unlock the scanner bed. For help locating the scanner lock, see the picture of the printer on page iv.
Page 51 contains
Unlock Scanner message
The scanner is locked. To unlock it:
1 Press Power to turn the printer off.
2 Use both hands to lift the printer (scanner unit) until the scanner support
holds it open.
To the left and beside the scanner support is the scanner lock. For help, see
page iv.
3 Pull the scanner lock toward you to unlock the scanner.
4 Using both hands, lift the printer (scanner unit).
5 Push and hold the scanner support back.
6 Lower the printer (scanner unit) until it is completely closed.
7 Press Power to turn the printer back on.
Hope it helps.
Oct 25, 2009 | Dell A940 All-In-One InkJet Printer
Unlock scanner
Sep 25, 2008 | Lexmark X5150 All-In-One InkJet Printer
Visioneer 9000 Scanner Unlocked ????
  1. Toggle the lock switch on the scanner leaving the switch in the unlocked (open padlock) position.
May 26, 2008 | Visioneer OneTouch 9000 Flatbed Scanner
Lexmark x5150 scanner locked
The scanner is locked. to unlock it
1. Press Power to turn the All-in-one off.
2. lift the scanner unit until the scanner support holds it. To the left and beside the scanner support is the scanner lock
3.pull the scanner lock toward you to unlock the scanner.
4. close the scanner lid.
5. power on.
Feb 19, 2008 | Lexmark X5150 All-In-One InkJet Printer
Samsung CLX-2160N Sanner Locked
Same problem thanks for ignoring guys!
Dec 11, 2007 | Samsung CLX-2160N All-In-One Printer
Dell A940 - Unlock Scanner then press power
See
Page 51 contains
holds it open.
page iv.
Dec 08, 2007 | Dell A940 All-In-One InkJet Printer
Lexmark X340n All-In-One Laser Printer Logo
2,527 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
