Question about Kenmore Elite 45986 Front Load Washer
Washer will not go into final spin
The washing will spin through all cycles but once it clicks into final spin it will not do more than just slowly spin the clothes back and forth and makes a buzzing sound while doing this. This sound just started when the washer quit going into final spin
  • 234 Answers
Hello there.
The buzzing sound it probably a coin or something stuck in the pump causing it to rattle. Also, it's probably preventing all the water from draining out causing the machine to not enter the final spin cycle, since all the water needs to drain for that to happen.
It's kind of simple to clean the pump.
All you have to do is take the 2 or 3 screws off the bottom of the kick-plate and then take the pump screen off, also known as a coin trap. Clean everything and then try to run it again. I'm almost certain this is your problem.
I get a lot of calls regarding this type of situation. Please try that and see what it does before calling a certified service technician. It can save you $120.
Oh and thanks for using fixya.com. We appreciate your query.
Ned
Posted on Aug 23, 2009
Washer cycle not starting
Did you read the user manual of your whasher? Unplug the washer to the wall out let and then verify carefully whats going on. maybe some unwanted material in it..check all the necessary components and test again.
notify me for what did you notice. melnavz
Apr 09, 2008 | Frigidaire FLEB8200DS Top Load Stacked...
FRIGIDAIRE LTF2140FS1 SPIN SLOWLY
Hello friend, thanks for your post!
I understand that the spin feature on your Frigidaire washer is spinning slowly. It sounds like a potential problem with your motor control board or control board. I would recommend performing a reset and you can do that by disconnecting the power from your washer for roughly ten minutes. If that does not help correct the issue I would recommend having a professional come out. They will be able to pinpoint the cause of the issue and replace any electrical components to avoid any personal injury or future issues with your washer. -Matt
Feb 21, 2015 | Frigidaire Washing Machines
Frigidaire Gallery Series Frontloader no final spin
I had the same problem. Here's a link that might help:
http://applianceguru.com/forum2/2937.html
I removed the hoses and pump and found the filter in the hose leading from the washer was clogged with a shoelace, $2.35 in loose change and a few GI Joe issued M4's. :-) Once I pulled that filter out and cleaned the **** the washer runs like a champ.
Apr 30, 2009 | Washing Machines
Washer will not spin
Your neutral drain is not locking in.
Let the timer advance to the final spin cycle. Once there it should have about a 5 second pause and the transmission spin gears will lock in. If no pause replace the timer. If you have the pause and still no spin replace the transmission.
My bet is on the timer.
Apr 01, 2009 | Whirlpool WTW5200S Top Load Washer
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
LG front load washer/ clothes still wet after final spin
The heavy jacket prevented the washer from spinning at a rapid pace, so I added a heavy bathrobe to absorb some of the water and to balance the load. The washer then spun very quickly and drained out all the water.
Jan 07, 2009 | LG WM-1832C Front Load Washer
Kenmore Front Loading Washer Slow Final Spin Cycle
out balance are water still in tub will do that try cleaning out the pump filter under the panel at the bottom of the washer some have a big white looking screw you turnit remove filter if there water in it it will flow to the floor so have something to catch it with
Jan 26, 2008 | Kenmore 44102 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
145 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
