Question about Apple iPhone 3G
Voicemail does not work
The voicemail on my iPhone 3G doesn't work. I click on the voicemail button in the bottom-right of the screen, but nothing happens.
Thanks for helping.
  • jjuracan Jul 14, 2008
    I am having the same voicemail problem on my 3G.  I tried to call my number but it just gives the message of "the voicemail has not been set up" and then it hangs up.  What do I do?
  • 30 Answers
Had the same problemwith my iPhone 3G this is how I fixed it -
1) From the iPhone 3G, I called my own iPhone 3G number.
2) Went through the setup. After finishing the ssetup Hang off the iPhone 3G.
3) Then the voicemail button on the iPhone 3G worked - first time, there was a **** pause, it asked me to enter my voicemail password that I had set in step 2, and that's it.
Good luck.
Posted on Jul 14, 2008
*5005*86*-------#
Then follow instructions. The seven blanks are for your phone number. NO AREA CODE.
After everything else had failed, this worked! Weird!! I had even gone through the voice prompts by calling my own phone number, and it said my voicemail was now setup!
But when I used this method, the voicemail button called my phone number. I had to hit * in the middle of the message which said my voicemail was not setup, and then I just followed instructions.
After I hung up, it took about 2 minutes, and then my iPhone said, "Voicemail password is incorrect" and prompted me to re-enter it. After I did so (entering the password that I had just used on the message prompt), everything was hunky dory again!
Posted on Aug 28, 2008
Solution 2 needed a little modification before it worked for me.
Instead of:
*5005*86*-------# where -----  is your mobile number try using your voicemail number instead for the ---.
I am with Vodafone and used 121, it worked perfectly.
Posted on Oct 26, 2008
Recovering voicemails I accidently deleted
hi Tee.
To find your deleted voicemails, open the Phone app, tap Voicemail, and scroll down to the bottom of the page until you see the words "Deleted Messages". If you do not see the Deleted Messages panel, then there are no messages to recover.
Can I recover a deleted voicemail on my iPhone? ' The iPhone FAQ
or this link to help you out some more.
Recovering voicemails accidently deleted Google Search
Dec 02, 2017 | Cell Phones
Tip
Apple iPhone Voicemail Button Setup/Configuration
Apple iPhone Voicemail Setup/Configuration
Apple iPhone Voicemail occaionally doesn't set itself up properly and has to be configured manually.
  1. Press the phone button on your iPhone. (Green one, bottom left)
  2. Press the keypad tab.
  3. Type the following: *5005*86*yourvoicemailnumber#
  4. Press the call button and wait a few seconds.
  5. Press the voicemail button, and it will now call your voicemail.
UK Voicemail Numbers
O2 - +447802090100
Vodafone - +447785016005
Orange - +447973100973
Three - +447782333123
T-Mobile -+4406477897123456 (77897123456 - being your mobile number without the first 0)
on Dec 23, 2009 | Cell Phones
I need to change the greeting of Iphone 3. Where to go?
I'm assuming you mean the voicemail greeting message.
iPhone 3GS How to Change Your Voicemail Greeting GROK Knowledge Base
This article should help. Has step by step instructions on how to change your voicemail greeting on your iPhone 3.
How to Record Voicemail Greeting for Your iPhone
Here's another step by step guide.
Hope this helps!
Feb 02, 2016 | Apple iPhone 3G
My voicemail stopped working. The phone rings and rings but doesn't go to voicemail.
Press Speaker
Dial *6
Enter Voicemail # (will appear on screen if you hit your voicemail button)
Press Speaker again
Nov 27, 2012 | NEC Dterm DTP-2DT-1 Phone
How do I set up voice mail on an iphone
Adding Voicemail for the First Time
  1. Tap the "Phone" button on your iPhone.
  2. Select "Voicemail." The iPhone will prompt you to create a password for accessing your voicemail, then will allow you to record your first greeting.
  3. Click "Save" to set your recording to your voicemail greeting
Recording a New Greeting
  3. Choose "Greeting > Custom."
  4. Select "Record" and begin recording your voicemail greeting.
  5. Hit "Save" to set your recording to your new voicemail greeting
Dec 06, 2011 | Apple iPhone Smartphone
How do I retrieve messages
If you have created a backup of iTunes for your iPhone, you can recover them from iPhone with ease.
  1. Plug iPhone into computer via the USB cable. iTunes will launch automatically, if not, you should open it manually.
  2. Click "File > Device > Restore from Backup", and choose the iPhone backup in the pop-up window.
  3. iTunes will start to restore the data in the backup to your iPhone. Sometimes it will ask you to enter your Apple ID to accomplish the restoring process.
This is the fastest way to restore deleted text messages from iPhone.
How to Recover Deleted Text Messages from iPhone iPad
Jan 12, 2010 | Apple iPhone 3G
Iphone voicemail
iPhone voice mail is only available on 3Gs new iPhone. you could install a patch found in cydia app
Sep 22, 2009 | Apple iPhone 3G
Problem setting up voicemail
Check the procedure is correct.
1 Tap Voicemail, tap Greeting, then tap Custom.
2 Tap Record when you’re ready to start.
3 When you finish, tap Stop. To review, tap Play.
To rerecord, repeat steps 2 and 3.
4 Tap Save.
Hope this helps
Regards
Apr 17, 2009 | Apple iPhone 3G
When I access voicemail the iPhone crashes
Apple has released the 2.2 update which fixes alot of these crash issues. Update the iPhone it from here:
http://www.apple.com/iphone/softwareupdate/
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 08, 2009 | Apple iPhone Smartphone
Voicemail does not work all the times
call 1-800-331-0500 press 3 for voicemail and then 3 again to reset it. that should do the trick
Jul 22, 2008 | Apple iPhone Smartphone
Apple iPhone 3G Logo
4,327 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
