Question about Acer Aspire One AOA110-1588 Notebook
I have an acer aspire one aoa110, when i turn it on, the acer intro comes, followed by the windows intro and then a light blue screen appears stating that says "checking file system c: the type of file system is FAT32 one of your disks needs to be checked for consistency blah blah blah... i don't know what to do, someone please help
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 26 Answers
Your hard disk is problem, there is two possible things that make you get that message. First your hard disk is full and there is a problem that windows cannot find specific file, that file maybe damaged or erased or moved to other location. Second your hard disk is about to die :). When and if your successfully finish repairing itself, try to download form the Internet program : " Hard disk sentinel", that program is free of charge. When you finish downloading install it and run. The program will show you in what kind of shape is your drive or drive's if you have more than one. In the filed on top find configuration and than preferences open and click on the " Load at windows startup", uncheck it. When program shows the shape of your hard drive or drives it will also show you estimated time when is predicted it will die. If you have BAD Sectors and program shows you a lot of red fields its time to backup your file and replace that drive.
Posted on Oct 13, 2017
SOURCE:
  • 30 Answers
SOURCE: Reset Acer Aspire One to factory settings--clean hard drive
You will have to order the erecovery cds from Acer to put it back to factory settings. They can about $40.00 to $50.00 dollars and they arrive about a week after you order them. Once you get them, you boot from cdrom and follow the instructions on the screen.
Go to Acer.com to order them.
Posted on Dec 28, 2008
  • 700 Answers
SOURCE: Restore my Acer Aspire One AOA110-1588 PC Notebook
Do you mean that, in system information the users name is name after your friend?
Goto control panel, goto system,goto advanced system,click computer name, put the name you like click change and then click ok.
Changing user name- goto control panel, goto user accounts select create a new user account or manage another account fill the blank except if you don't want to password it, set it as administrator if everything is done, log off then log to the created account backup the files from the other account. Then delete the account of your friend under User Accounts. The only thing left will be name to you. Except some other name he/she change in registry like registered name.
Hope it helps
Posted on Apr 13, 2009
  • 221 Answers
SOURCE: Restore Acer Aspire One AOA110-1588 PC
There are two way's you can restore your laptop,
When you power on your laptop the acer splash screen pop's up, at that time press the -Alt- key and F10 key at the same time,
at the eRecovery Management menu it should ask you how you want to restore, click on the restore option, or
From the window's desktop click on start, then all program's, then acer Empowering Technology, click on Acer eRecovery Management, create a password, click on restore, then click on restore system to factroy default.
Posted on Apr 14, 2009
SOURCE: Volume My Acer Aspire One AOA110-1588 PC Notebook
If ur question is dat u dont have volume to ur laptop..Install the Audio drivers provided by the Acer eRecovery.I hope it will slove ur problem...If not restore ur laptop to factory setting.
Posted on Apr 22, 2009
asood23
  • 200 Answers
SOURCE: How to replace broken screen acer aspire one
You will need to buy a compatible inverter board.
Posted on Aug 17, 2009
I cannot start up my acer aspire 584g32bn
Safe Mode and System Restore can fix startup issues in an Acer Aspire One, but if the computer won't even load the boot screen, the problem could be related to the basic input/output system (BIOS).
The Acer Aspire One 110 and 150 are two models that can have BIOS-related problems that prevent the computer from booting.
You can upgrade the BIOS through a USB flash drive to repair this issue.
If you are able boot past the startup screen, but can't sign in to Windows, you can use Windows Advanced Boot Options to bypass startup problems.
Go to the Acer website (see Below).
http://us.acer.com/ac/en/US/content/drivers
Click "Support," then select "Download" from the menu on the left.
Select "Netbook" as the product family.
Click "Aspire One" as the product line. Select "AOA110" or "AOA150" as the product model.
Click the "BIOS" tab.
Click the download button and save the file to the desktop.
Go to the desktop when the download completes.
Double-click the file to open it.
Drag-and-drop the folder to the desktop.
Double-click the folder to open its contents in Windows Explorer.
Double-click the "BIOS_Acer_3310_A_AOA110 & AOA150" folder.
Double-click the "Dos_Flash" folder.
Insert a blank USB flash drive into a USB slot.
Drag-and-drop the "3310.fd" and "Flashit.exe" files to the flash drive.
Right-click the "3310.fd" file. Click "Rename."
Change the file name to "zg5ia32.fd" and press "Enter."
Connect the AC adapter to the power jack.
Hold down "Fn" and "Esc" with one hand, then press the power button with the other.
Release the "Fn" and "Esc" keys when the power indicator light comes on.
Wait at least seven minutes for the system to fix the BIOS and repair the Acer Aspire One startup issues.
The computer will restart automatically when the process is complete.
Other Models
Turn on the computer.
Press "F8" before the Windows logo appears to access the Windows Advanced Boot Options menu.
Scroll to Last-Known Good Configuration.
Press "Enter" to load Windows.
If the OS fails to start up, hold down the power button for 10 seconds to turn off the computer.
Press the power button to turn the Acer Aspire One back on. Press "F8," then select "Safe Mode" from the options.
Log in to Safe Mode. Click "Start," "All Programs," "System Tools" and then "System Restore." Click "Next."
Select the last working restore point from the options. Click "Next."
Click "Finish" to run System Restore and recover the Acer Aspire One to a previous state.
Apr 21, 2013 | Acer Aspire 5600 Series 5630-6951 Laptop
Where can i find linux wireless driver for acer aspire one aoa110 aw?
Ouch, it appears that Linux is no longer being supported by Acer. You could try the Windows XP driver (it's worth a try) http://us.acer.com/ac/en/US/content/drivers
If that doesn't work you might have to download the latest LINUX and reinstall it from scratch.
Dec 25, 2010 | Acer Aspire ONE AOA110-Aw Netbook
Blue screen of death comes up then the netbook turns off
This article may help you....or these.
If you can turn off the auto restart to get a stop error code from the blue screen, that will help you to diagnose this error. See 'disabling restart..." here. Then reboot and note the exact error code reported. Write back with that info and we'll help you to sort it out.
You can look up codes here.
Also helpful links for blue screens here, here, & here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 01, 2009 | Acer Aspire One AOA110-1588 Notebook
When i turn on laptop screen oes blank but can see curser
Do you see the acer splash screen before you get the black screen with the curser? If so it is more than likely a windows problem. Boot from your XP disk and select R when prompted to repair. Once in the repair console type the following:
chkdsk /r
When it is finished (will take about an hour) then type exit to restart the computer.
Hope this helps
Apr 23, 2009 | Acer Aspire One AOA110-1113 Netbook
Apr 14, 2009 | Acer Aspire One AOA110-1588 Notebook
Unlike other laptops, Acer laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer laptop to factory setting.
Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer laptop to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer laptop is reset to factory settings.
Tips: You can also create a backup copy of your laptop data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If you have any other issue with your Acer laptop/desktop/Notebook, feel free to get expert technical assistance at
http://www.vtechsquad.com/acer-support/
Dec 28, 2008 | Acer Aspire One AOA110-1626 Notebook
Acer Aspire One AOA110-1588 Notebook Logo
73 people viewed this question
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
