Question about Dryers
Turn it on and its not spining - Dryers
WHIRLPOOL ELECTRIC DRYER MODEL# LEQ9508PW1. THE DRYER IS NOT SPINNING. MOTOR RUNNING AND HEATING BUT WHEN I OPENED THE TOP THE BELT IS VERY LOOSE BUT NOT BROKEN. WHAT COULD IT BE?
Posted on Oct 31, 2009
    President:
  • 1,462 Answers
Take top off machine and give the drum a push by hand. if it starts and continues to run then the fault is the motor capacitor - cheap part
Posted on Jul 14, 2008
Fan not spining
Could be a faulty fan or fluff stopping it from turning.
Dec 28, 2013 | Acer Aspire Computers & Internet
Our electric hotpoint dryer stopped spining & got hot & it smelled hot now we can't even get it to turn on
Let's start with the easy stuff.
Check the belt
Thermal fuses
door switch
Do you know where they are?
Dec 12, 2012 | Hotpoint Dryers
What is the spine corrector barrel?
The spine corrector utilized for individual needs, stretching, aligning and strengthening the spine. It also relieves stiffness of the shoulders and hips as well as relieving common backaches.
Aug 30, 2012 | Allegro Exercise & Fitness
Turntable won't stop spining
If it is a turnatable that starts spining when the arm is moved to the record, then more than likely the start/stop switch inside the turnable is broken and is fixed in the on position. Or the leaver mechanism has become detached from the arm when the record was playing and left the other part pressing on the same switch that turns the motor on or off.
Removing the bottom of the turntable should should show the trouble.
Apr 03, 2012 | Philips WMM142211 Turntable
Got a dc7600, need to add 2 more monitors, as video cards in my other computers will not fit (too large for slot)..if i can , i need a video card with two slots to attach both monitors or get 2 video...
Which part of the video-cards are "too large" -- the electronic circuitry, or just the "spine"?
If just the "spine" is too tall, then unscrew the spine from the card, and attach a shorter spine.
Or, if you are "brave", then run "*****" -- don't attach any "spine" to the video-card.
Just connect the VGA/DVI cable from the monitor directly to the video-card.
Aug 18, 2011 | HP Compaq dc7600 Small Form Factor PC...
The needle doesn't go up & down. Any suggestions? Thank you
Does the handwheel turn eazy or is it stiff. If it is stiff you need to take the top and bottom off and lubricate all moving parts. may take a bit of turning the handwheel and lubicating(it may tire you out). If the handwheel is not stiff I would check to see iff the motor is spining at all. If motor is not spining may be a bad footcontrol. If it is spining try cleaning the belt pullys and tighting the belt.
hope this helps
Mar 22, 2011 | Kenmore 15516 Mechanical Sewing Machine
How can i change myswitch on my dc07
Take of Cyclone and wand and hose so that you are left with only the the spine.
On the from of the spine at the top you will see a small silver screw. You will need to unscrew this with a Torqx Screwdriver.
Now turn the machine round and on the rear of the machine at the top of the spine you should insert a flat headed screwdrive to the clips on the left and the right. Insert the screw driver and hit the end of the screw driver to knock the clip out,. do this for both sides.
Yuo will then have access to the switch area.
Simply swap the swicth with replacement switch.
Mar 09, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
The machine is not spining properly and leaving wshing wet
when machine is empty turn on side and check underneath for slipping or broken belt Replace . hope this helps
May 17, 2010 | Washing Machines
Printing spine labels for books on hp laserjet 1020
convert the doc to a PDF so that the sizes and fonts save. That should fix your issue.
Jun 05, 2008 | HP LaserJet 1020 Printer
Dryers Logo
139 people viewed this question
Top Dryers Experts
