On wide screen mode screen flickers at top - Televison & Video
Hi there,i spoke to samsung direct and they said switch tv to standby,then press info,menu,mute then standby wait 15 seconds. then switch tv back on a secret menu appears on the screen arrow down until 12.reset arrow right on remote and follow instructions very easy hope this can help.
Posted on Jul 15, 2008
Lg55lv4400-va 55" flatscreen tv has developed a wide flickering vertical flickering stripe down the screen. any Ideas ?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 03, 2014 | Televison & Video
I am getting a vertical white line that runs from the top of the screeen down to the bottom of the screen. It is about 2" wide on a screen 12' away. It flickers. It rotates to the other side of the...
it is most likely the dmd board on the light engine. very expensive and parts may be hard to find for a projector that age. you could try to find a 4800 on ebay for parts....
Feb 03, 2011 | InFocus ScreenPlay 4800 Multimedia...
I too have the problem where the top and bottom of the picture is cut off on the TV screen. No formatting of any kind fixes it. What is the answer?
Some of the wide screen programs will leave blank strips top and bottom of the screen, you can fill the screen if your TV or the remote has picture size buttons where you can select "movie" mode or "movie zoom" modes. try stepping through picture size buttons. Some times it is marked as "wide" on your remote.
Jan 03, 2010 | Envision L32W761 32 in. LCD TV
Top, middle of screen there is a constant flicker. The flicker starts at the top, middle and goes about half way down the screen.
I have a blue line about 3/4 inch wide from the top right to the middle bottom. ( not a straight line ) I replced thr projection lamp with no fix to the problem. I added an additipnal fan and cleared up the problem. On furthe investigation I replaced the air filter and kept only the original fan and the problem was solved. Can you explain this.
Dec 06, 2009 | Zenith D52WLCD 52" Rear Projection...
When on wide mode there the full screen is not
This is very normal not all channels are HD some programs are taped like that will not fill your screen like dvd movies are.
Nov 18, 2009 | Insignia 42" LCD Flat-Panel HDTV
Nintendo DS Lite Flickering screen
hey i think i got a solution, read the link i gave below credits to votahuan, its for adjusting screen flickers in both top and lower screen of ndsl, however i need you to do me a favor in return, hope you do not mind posting up the pics for me at renginez@yahoo.com once you found the two hidden screw at ndsl, im just having hard time finding it in fat nds, so i need a rough i dea of where it mite be located. Heere's the link anyways :-
LCD FLICKER SOLUTION
Jun 15, 2008 | Nintendo DS Lite Console
Picture issues
Greetings caesar975,
Unfortunately if you chose to view the non HD channels in wide screen format, you are going to have the top and bottom of the screen cut off. Eventually this will not be a problem when everything goes to digital. However presently non HD channels are presented in 3:2 ratio where as HD is 16:9, So your choice really is to view them with the lines on either side for now.
I do not have an answer for the white flickering lines.
To get the BEST picture out of your 1080p unit I highly recommend using HDMI cables to hook it up.
I hope some of this helps.
Sincerely,
Dorothy
Go Ahead. Use Us.
Jun 11, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
I have a Toshiba Satellite P100 laptop which I bought in New Zealand. I think the model comes from the USA. Part of my screen is flickering. It runs vertically from the top to the bottom of the screen and...
Good morning, Kevin!
Sounds like an LCD problem. You can verify this by hooking up an external monitor. The external monitor will probably show a good display.
After verification of the problem,you may want to try to replug the LCD cable at both ends, just to see if that corrects the situation.
If that resolves things, all is well and good. If not, you may need a replacement LCD.
If the external monitor shows the same display, you may have a motherboard problem.
Hope this information is of some help.
Ron-
May 09, 2008 | Computers & Internet
Wide Screen vs Full Screen
look for screen format in video mode menu or if you have original remote you have that option in your remote
Jan 17, 2008 | Hitachi 43FDX01B TV
RCA 52" projection Model no. D52W19 produced 9/04
make sure you do not have the automatic screen mode set to wide screen on tv menu .Also if you have cable box set to wide mode only then the tv will only display wide mode.
Dec 05, 2007 | RCA P52937 52" Rear Projection Television
Televison & Video Logo
83 people viewed this question
Top Televison & Video Experts
Electro Med Services...
