Question about Navman F20 GPS Receiver
Error message on Navman Navman F Series Failure Unable to detect internal memory. Please return the unit to dealer. Can anyone help?
  • trina535 Jul 15, 2008
    I've managed to speak to technical support at Navman and they advise that the system requires a new motherboard. Apparently its a recognised problem with the F40. So we're just going to return to the vendor for a full refund. They would replace it but I don't think there's any point as the chances it the problem will simply recur with the new one.
  • cazzshaw1980 Jul 17, 2008
    when i turn it on it says f series failiure return to main dealer i bought this off ebay so dont know what to do
I have a similar problem, where did you download the firmware?
Posted on Oct 22, 2008
I have a F20 here I am currently tring to fix.
The error comes from the internal memory card being faulty.
It is only a micro SD car.
It may be totally usesless, or need re-programming via the USB port.
You can download the firmware, and it fixes a working MicroSD card.
If your card is damaged, then you will have to replace it, and strip the F20 down to do so.
Then you can upload the firmware.
I warn you, though.
Stripping it down is a bit tricky.
I replaced this F20 memory card, and put on the firmware, but have a new error, that it cant find any maps installed.
Hope this helped you
Michael
Scratchmittens@htomail.com
Posted on Jul 14, 2008
I reset my F series,now it tells me
unfortunately, per C-Net's review page at "http://www.cnet.com.au/navman-f20-339272352.htm#comments" there may not be any software available as that these units are now "obsolete". but there does not seem to be any "free" software at all.
hold it! just found the software page from the company at "http://www.navmansupport.com.au/All%20Navman%20FAQs/Software/F%20Series.htm" for this unit. could not find a "direct" link to the download, but you may have better luck.
it would seem that there are drivers in windows for this ( according to what I saw on the site)
on some further searching, it seems that there is a sd card in the side that may be loose, check that out, too!
Mar 02, 2012 | Navman F20 GPS Receiver
F20 GPS
Remove memory and put it back, if it still does not work memory is probably faulty.
May 24, 2008 | Navman F20 GPS Receiver
Navman f20 wont turn on says F20 ERROR UNABLE TO DETECT INTERNAL MEMORY
Not much to do here I'm afraid. a repair is needed. If your device is not under warranty anymore, you can get in touch with Navman / Mio, they have a trade in offer towards a new Mio device
Feb 22, 2011 | Navman F20 GPS Receiver
Where can i get the codes canon ir 2016 series.
Hi, here you go:
E000 0000 Fixing temperature abnormal rise
E001 0000 Fixing unit temperature rise detection (by main thermistor)
0001 Fixing unit temperature rise detection (by sub thermistor)
E002 0000 Fixing unit temperature insufficient rise
E003 0000 Low fixing temperature detection after standby (by main thermistor)
0001 Low fixing temperature detection after standby (by sub thermistor)
E007 0000 Fixing film rotation error
E010 0000 Main motor rotation error
E019 0001 Waste toner full detection
0002 Waster toner full detection sensor failure
E052 0000 Duplex unit connection error
E100 0000 BD cycle out of range
E197 0000 Erroneous communication with printer engine
E500 0001 Finisher communication error
E520 0000 Offset error
E531 0000 Stapling error
E540
0001 Paper surface not detected (standard tray)
0002 Not moved within the specified time (standard tray)
0003 Sensor not reached within 3 seconds (standard tray)
0005 Encoder clock failure (standard tray)
E542
0001 Paper surface not detected (optional tray)
0002 Not moved within the specified time (optional tray)
0003 Sensor not reached within 3 seconds (optional tray)
0005 Encoder clock failure (optional tray)
E575 0000 Stack delivery error
E584 0000 Shutter failure
E716 0000 Erroneous communication with optional cassette
E719 0000 Erroneous communication with card reader (serial communication)
0002 Erroneous communication with coin vender (serial communication)
E733 0000 Erroneous communication between controller and printer
E736 0000 CCU communication error
E739 0000 Erroneous communication between controller and network board
E744
0001 Language file/boot ROM/USB memory error
0002
0003
0004
E805 0000 Fan failure
E808 0000 Fixing drive circuit failure
Jul 16, 2010 | Canon Office Equipment & Supplies
Our copier doesn't copy and shows error message "unable to print..." we want to get it fixed, please help
The graphics is not initialized
because the graphics memory
was not reserved. This error
rarely occurs unless the printer
detects the memory failure.
Please note that
“RPCS”(RICOH printer language)
is the same worldwide
and does not need to be translated
Replace the installed memory.
Turn the power off, and then on. If the
message appears again, contact your
sales or service representative.
Oct 02, 2009 | Office Equipment & Supplies
Erreur f20
This is a fault with the internal memory chip failing. It can not be fixed and requires the unit to be sent to Navman and the chip replaced.
Return your GPS to the place of purchase and they will complete the return for you if you've had it less than a year. You will need a repair ref number from Navman before sending it back.
This would cost you if the items out of waranty.
PLEASE rate our help to keep the FREE service online++++Thanks for using FIXYA
Sep 11, 2009 | Navman F20 GPS Receiver
F20 navman error
You need to remove the 2 screews from the bottom and then gentley prize the unit apart from teh bottom using a blunt broad knife will help if you cant have the plastic case splitting tools which are used in the trade,
then once apart the same side where the power button is you will see a microsd card its the same as in a mobile phone just pull it down from the top (its hinged at the bottom) then make sure the card is in correctley and then close it back and test (b4 putting the case back on) that will fix it we ahve a lot of these coming in and its where its been dropped etc and jumps out thats it
from fototime. co .uk
Oct 29, 2008 | Navman F20 GPS Receiver
Software Problem with Navman S70 3D
you have to contact Navman from thier website and then return it to them and they will repair it for you
Stu
Sep 21, 2008 | GPS
Navman F10.........Just Out Of Warrantity
hi sir,,
may be memory card correpted..
Sep 01, 2008 | Navman F20 GPS Receiver
NAVMAN F20 failure - unable to detect internal memory
I think that the micro SD card inside the GPS is not in the good position, it is necessary to remove the grey sticker on the rear of the GPS and open the hood to access the SD card and then you can plug it in good position.
DAMS
Dec 25, 2007 | Navman F20 GPS Receiver
Navman F20 GPS Receiver Logo
1,058 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
