Question about Timex Ironman 30 Lap 53952 Wrist Watch
Indiglo light not working
Have you had any success getting your night light to be working again? I have the same problem.
please contact me at emce@pointbluntpro.com
Regards,
Emce
  • Anonymous Dec 16, 2008
    watch works but light doesn't come on anymore. Whats wrong with it?
2 Suggested Answers
escapement
  • 2334 Answers
SOURCE: after about two years, my indiglo night light
Definitely, battery change will solve the Indiglo light problem. Many of wristwatches has separate battery for Indiglo function, but my advise is to change them both at once - will be cheaper for you.
Rate me, please.
Posted on Sep 01, 2009
Might light no longer works, had battery checked and it is fully charged. Please advise
the indiglo of your watch is probably busted, you had to replaced its dial. the the battery has been checked but not the watch by a new battery? try to check the watch by a new battery. if still not lighten up check the connection of the button it probably cannot connect the connections of the light. i hope this advise will help you a lot.
Sep 08, 2011 | Timex 2D421 Stainless Steel Perpetual...
INDIGLO does not work anymore
Take this to a qualified watchmaker for inspection.
If you have any further questions please let me know.
Many thanks!
Mike Kenley
TimeOut
Worldwide watch and clock services
If it don't tick I can fix
Nov 29, 2009 | Timex 27191 Wristwatch
Timex 1854 chrono,indigo lght not working. 2nd one in 4 mths?
the same problem, after 3 years of use.
Night Indiglo light was very bad.
thought the battery replaced it, the battery was okay.
began to collect but probably need a special tool, the glass cracked)
Sep 09, 2009 | Timex Watches
After about two years, my indiglo night light function stopped working. The watch is still working, keeping time. Will changing the battery fix the indiglo problem?
Rate me, please.
Sep 01, 2009 | Timex 2J611 Watch
Timex T49271 Expedition Indiglo button dead?
There is no separate battery for the indiglo,maybe indiglo circuit is lose or defected already,just open the watch and check for lose connection.If happen the circuit is tight and still not working then replace the indiglo circuit.
Hope it may helps you;
Regards
VOTIT
Mar 23, 2009 | Timex Expedition 40141 Wristwatch
Timex indiglo. Indiglo feature died.
The indiglo technology is time limited (it dims over the years with use) and cannot be repaired - have you had the watch a long time? if so, I'm afraid it's time to get a new one. Sorry!
Dec 30, 2008 | Timex Watches
TIMEX IRONMAN TRIATHALON DIGITAL WRISTWATCH
ANALOG TIME
Pull CROWN and turn to set HOUR and MINUTE hands. TIME AND DATE A. Press and hold SET. SECONDS digits will flash. B. Press SPLIT/RESET to set SECONDS to zero. C. Press MODE to select HOURS. D. Press SPLIT/RESET to advance hours digits. Go through 12 hours for AM or PM. E. Press MODE to select MINUTES, press SPLIT/RESET to advance. F. Repeat to set MONTH, DATE, DAY, 12- or 24-hour time display. G. Press SET when done. BASIC OPERATIONS Press MODE to cycle through CHRONO, TIMER, and ALARM modes. Press INDIGLO to illuminate watch face. In any mode, press MODE to view time display. Press any button to stop alarm or timer beeps. INDIGLO INDIGLO CHRONOGRAPH A. Press MODE until CHRONO appears. B. Press START/STOP to start. C. Press SPLIT/RESET to record lap time. Display pauses. D. Press MODE to resume display of lap and split time (automatic after 10 seconds). E. Press START/STOP to pause chrono. F. Press START/STOP to resume. G. Press START/STOP to stop. H. When timing is stopped, press SPLIT/RESET repeatedly to recall last eight lap and split times. I. Press and hold SPLIT/RESET to reset chrono. MODE MODE START/ STOP START/ STOP SPLIT/ RESET SPLIT/ RESET SET SET CROWN COUNTDOWN TIMER A. Press MODE until TIMER appears. B. Press SPLIT/RESET to select timer operation (Countdown and Stop; Countdown and Repeat; Countdown and Start chrono). C. Press SET. HOURS digits will flash. Press SPLIT/RESET to advance digits. D. Press MODE to select TENS of MINUTES. Press SPLIT/RESET to advance. E. Repeat to set MINUTES, TENS of SECONDS, and SECONDS. F. Press SET when done. G. Press START/STOP to start timer. H. Press START/STOP to pause, press again to resume. I. When timer is stopped, press SPLIT/RESET to reset timer. Watch will beep when countdown reaches zero. ALARM AND CHIME A. Press MODE until ALARM appears. B. Press SET to select HOURS. Digits will flash. C. Press SPLIT/RESET to advance digits. Go through 12 hours for AM or PM. D. Press MODE to select TENS of MINUTES. E. Press SPLIT/RESET to advance. Repeat for MINUTES. F. Press SET when done. G. Press START/STOP to turn alarm on or off. H. Press SPLIT/RESET to turn chime on or off. When alarm time is reached, watch will beep for 20 seconds, or until any button is pushed. Alarm will repeat every 24 hours until deactivated. INDIGLO® NIGHT-LIGHT WITH NIGHT-MODE® FEATURE A. Press INDIGLO to activate light. Patented (U.S. Patent Numbers 4,527,096 and 4,775,964) electroluminescent technology used in the INDIGLO® night-light illuminates watch face at night and in low light conditions. B. Press and hold INDIGLO for three seconds (beep will sound) to activate or de-activate NIGHT-MODE® feature. C. While in NIGHT-MODE® feature, press any button to illuminate watch face for 3 seconds. Chime on Alarm on If your watch is water-resistant, meter marking or ( ) is indicated. Water-Resistance Depth p.s.i.a.* Water Pressure Below Surface 30m/98ft 60 50m/164ft 86 100m/328ft 160 *pounds per square inch absolute WATER AND SHOCK RESISTANCE WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER WATER. 1. Watch is water-resistant only as long as lens, push buttons and case remain intact. 2. Watch is not a diver watch and should not be used for diving. 3. Rinse watch with fresh water after exposure to salt water. 4. Shock resistance will be indicated on the watch face or caseback. Watches are designed to pass ISO test for shock resistance. However, care whould be taken to avoid damaging crystal.
Oct 27, 2008 | Timex Watches
Timex Expedition, beeps very quietly and indiglo doesn't work.
To clarify... Replace the cover with the arrow on the back pointing directly at the stem. The Indiglo backlight, alarms and chimes should all work when the back cover is in this position.
May 04, 2008 | Timex Expedition 40141 Wristwatch
Keeping time and indiglo light not working
check to make sure the button is making contact with the circuit board. It may need to be adjusted. Try and manually make contact with the copper contact. If it lights, then just adjust the tab.
Oct 15, 2007 | Timex 27191 Wristwatch
Timex Ironman 30 Lap 53952 Wrist Watch Logo
257 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
