Question about Vestax CDX-05 Turntable
Disc Jumping Hi, We are using 2 CDX-05 players but after 1-2 hours of usage the discs start to jump. When we try it at home no promlem appears. In the club after a couple of hours audio cds and mp3 cds are jumping as well. We tried all kinds of brands of cds, original ones etc, the problem appears. The vibrancy could not be the problem, if I shake the players no jumping. Any suggestions? Regards, Hunor
  • hunorbsd Jul 15, 2008
    Only if I use very scratched or bad quality cd. At the club we have good cds. The only thing that could change bw two inviorments are the humidity and electrical wiring.
    Hunor
  • acacium Aug 03, 2008
    My CDX 05's would do the same thing. Also only a club or party. Mine would also cut out in the middle of a track sometimes and begin at the first track of the cd. Really discouraging. I was thinking humidity or power supply problems or power surges.
    Also one of my platters is sprung. It will spin for a very long time when pushed hard and when speeding up a track with a gentle touch it would come back a little. That one was my fault.
    Can i do anything for then before I sell them?
I used to have the same problem: the rubber feet of the players are too stiff. It is indeed vibration that causes the problem. Btw: after a couple hours in a club, you are usually playing much louder than at home, with more low-end punch.
I haven't had a single problem AFTER systematically setting the players on foam. This is similar to the tennis balls trick for regular turntables, except that here you need something a softer suspension as the players are very light. Shipping foam is good; camping foam mattress works also.
Posted on Aug 14, 2008
Prepare to remove lazer unit-this is a most stupid lazers on the world-they are not a sony-something else i have 2 pairs vestax cdx 05-but they work corectly becouse i remove original lazers
Posted on Oct 15, 2008
Blagouu, please can you specify what kind of laser you put instead? I have same problem with one of mines, so I'll change lasers.
but you change whole transport with little motor (you just disconnect wires and connect the new part?) or you change only lazer leans witch require more difficult operation?
thank you
Posted on Jan 23, 2010
  • pincukas Jan 23, 2010
    I disassembled and om lazer transport frame its SONY! but why its so lame?
    after half hour of work it starts to read really bad and plays noisy sounds..
    Blagouu, if you just tell me model number lazers you put in it would be just great!
  • 515 Answers
That is very strange. So, no issues at all @ home? Only @ work/club?
- Davis
DJ Pro Audio
www.DJPROAUDIO.com
www.1200s.com
Posted on Jul 15, 2008
Why does my sony DVP display "No Disc" for every disc; when they play fine in any other player?
Sony tend to have a notorious disc lasers... couple of things you might want to try..
1. clean the lens using a standard Lens cleaning CD.
2. Try playing a CD (music) instead of DVD (if this works...it is likely that the lens is not reading DVD)
N
Jun 02, 2014 | Sony Dvp-C660 Component Dvd Players
It will not play Dvd Error message says reject Dvd disc may not be playable type. One DVD began to play but kept jumping. Tried multple Dvd a Few fresh out of box
The device does not play.
Ensure that a supported disc is loaded in the player label-side up.
Ensure that the disc's region code matches the player's region code.
Ensure that the disc's rating level does not exceed the player's.
Ensure that the disc is not damaged or too dirty. Clean the disc or try another disc.
Moisture may have condensed inside the player. Remove the disc and leave the player on for
1-2 hours and then try again.
or lense may be dirty, try using a dvd 'head' cleaner. this may help situation, if continues, may be internal issue and need repair.
Oct 17, 2010 | Symphonic WF803 DVD Player/VCR
Hi my cd player will play for a couple of tracks then start jumping have cleaned disk but to no availehow can i clean laser on a multi disk
multi-disk or single disc player has only one (1) lens (reader), so you can use those commercially available cd player lens cleaner. ( a disc with tiny brushes in it.)
Apr 30, 2010 | 2004 Land Rover FreeLander
I can't play dvds but I can play copied dvds
Most copied DVD-Videos for home playback use a CSS crack to strip the region code i.e. to Region 0 to they will work in all DVD players.
However most standalone DVD Players can have this restriction lifted using a sequence of codes.
First check your current firmware version to see if you need to upgrade:
1. When TV shows Philips wallpaper, close disc tray with no disc.
2. Press <0>, <0>, <0>, <9>, <OK> on the Remote Control.
Note: In case the firmware version does not appear on the screen, eject and close the disc tray to reset, and try again.
In this case region is 2 (UK) and the firmware is “Feb 23 2007” this is the latest for this DVD VR.
There are other codes that can be used to set this DVD to region 0 it might be a good idea for you do to the same with yours.
Nov 22, 2009 | Philips DVDR3380/05 DVD Recorder
DVD plays well until it stutters midway thru and
If it only happens with one disc, try using a Disc Doctor/Skip Doctor on it. These instruments will repair scratches and depending on the disc, repair pinholes in the disc. Usually it's just polishing the surface of the disc. Some instruments totally resurface the disc by stripping off a thin layer of the disc to remove scratches and other damage. (Used game/music stores will do this).
Aug 29, 2009 | Panasonic DVD-RV31 DVD Player
Unlock LG LHT854
Works on the LG LHT854 - I tried it... Successful!
see http://www.videohelp.com/dvdhacks/lg-lh-w760ia/8295#29072
icon_minipost.gifRegion code hack posted by SmallRedOne, September 29 2008:
- Power On the player with no disc
- Press Pause, 1, 4, 7 and 2
- Press the Up arrow 3 times (Option 04 ?? should then appear on the display)
- Press 0 (zero) and then press Program 6 (2-3 seconds), the characters should then change to 04 0F
- Press Enter
- Power the player Off then back on again
- Press the Up arrow 4 times (Option 05 ?? should then appear on the display)
- Press 0 (zero) and then press Program 6 (2-3 seconds), the characters should then change to 05 0F
- Press Enter
Oct 23, 2008 | LG LHT854 Theater System
Ive got a kenwood hi-fi and had it for approximately 15yrs. Its a system where each part is seperate, just recently my cd's have started to jump, ive tried cleaning discs to clean the laser but they do no...
what did u mean by cd's jumping... is it physically jumping.. or is it skipping ...?
Mostly it wud be the wear and tear of the rubber inside.. rubber inside in the sense the motor's belt..
Sep 16, 2008 | Audio Players & Recorders
Help pleasee
I"LL SUGGEST U FIRST TRY TO FIX THE AUX INPUTS. CONFIRM WHETHER "AUX IN " IS "ON" or "OFF" .PRESS "SRC" SWITCH UNTIL "AUX 1" or "AUX 2" APPEARS ON DISPLAY. SELECT IT "ON".NOW HOPE FULLY THE CD PLAYER SHOULD PLAY.
May 03, 2008 | Pioneer CDX-FM687 6-Disc CD Changer
Clear sound with jumping picture
either the disc ur inserting is dirty or the laser needs cleaning try cleaning ur laser first then the disc if the problem prosist take the dvd player back
Aug 26, 2006 | Yahoo YDP305 DVD Player
Vestax CDX-05 Turntable Logo
243 people viewed this question
Top Vestax Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Vestax Audio Player and Recorder Expert? Answer questions, earn points and help others
