Question about RCA Scenium M50WH187 50" HDTV
RCA Scenium HTV won't turn on
The on/off button flashed and went out so I replaced the lamp, 3 times, still fllashes and goes out.
  • cyma80 Sep 02, 2008
    I have had my 52' Scenium for a little less than 4 years. all of the sudden with no problems before at all, the power wont come on. it flashes on, off, on , off, on and then off. it takes me an hour or more to get it to turn on but when i do get it on it stays on until it is turned off. but these problems come if it has been on for a while. i mostly have the issue in the morning. i have checked the power cords like rca said ( like i would try to turn it unplugged or something). lol. i need to know what this problem might be, if i can fix it myself, or am i lookin at something serious that i need a pro to look at? Please help. this is getting on my nerves something awful.
My tv is about not even 3 years old, the bulb was already replaced once and now the tv will not turn on, we replaced the bulb again, but no change... The blue lights come on and flash but eventually turn off.
Posted on Aug 14, 2008
61"RCA Scenium modle number d61w136d When turning
You are on the right track, if the lamp is not lighting bright enough it could do this exact thing, the three tries is standard on RCA products, called the 3 strikes and your out---set will try 3 times to make it on and then shut down.
The color wheel while possible usually makes a high pitched fan like sound and with lamp out you should be able to see it to know if missing parts of the wheel or shattered.
12_18_2012_8_04_57_pm.jpgtypical color wheel.
Dec 18, 2012 | Televison & Video
RCA SCENIUM trys to start up but wont start
most of the time in situations like this fusses are blown check them all and if still problem let me know remember you have more than one fuse in tvs
Nov 18, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
My "50" RCA Scenium won't
That's usually caused by a bad lamp. However that chassis is famous for having bad caps on the power board. The repair kit is available at the following link and has repair instructions included. http://servicemanuals.vstore.ca/product_info.php/pName/rca-atc336-dlp-power-board-repair-kit/cName/repair-kits
Aug 16, 2011 | RCA HDLP50W151 50" Rear Projection HDTV
M61WH185 rca scenium front panel flashes 5 times and no picture
this is the tv's way of saying that my lamp is getting weak or is about to go.
Sep 06, 2010 | RCA Scenium M61WH185 61" HDTV
Rca scenium hd50lpw166yx12 power blinks five
I have the same problem -- now it made a loud pop and just went completely black and only the sound will turn back on,... have you received any answers to this?
May 14, 2010 | RCA HD52W66 Projection Television
RCA scenium model hd50lpw165. lamp went out- replaced it but tried so many times to turn it on before realizing the bulb needed to be replaced that it locked up. what to do?
http://www.tvtechcenter.com/board/links/rca/ATC311%20Training%20Manual.pdf
OK above is a service and training manual this is what engineers use to teach engineers how to fix sets like yours Use this an you may be able to repair READ THE SAFETY INSTRUCTION FIRST.
Apr 29, 2010 | RCA Scenium L50000 Television
Turns its self off
Change the lamp, you can order it from RCA, the instruction manual has order info on page 84.
Jan 14, 2008 | RCA Scenium HDLP61W151 61 in. HD-Ready...
"52" RCA Scenium DLP; No Picture and the buttons flash on and off
On the back of the TV, you'll find the Access door to your lamp. Unplug the TV from power, and remove the screw on the access panel. Inside you'll find 2 additional screws holding in the lamp housing assembly. Remove the screws, then the lamp assembly and visibly inpect it. You'll know if the lamp is defective, it will have obvious damage. If so replace with part # 260962, you can acquire this lamp for arround 100 dollars off ebay, or 262.00 direct from RCA.
Nov 09, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
I kind of had the same problem..I had audio..no picture..and the display would flash 5 times. Per the manual it said the lamp needed replaced. After reading a post by someone that had the same problem and replaced the lamp, it still didnt fix the problem..I took my set in to the repair shop. Turned out to be the light engine..$1000.00 for the part...$250.00 for labor! The tv was only 15 months old..and not even used on a regualr basis..I maybe had 300 hrs on it. I did not buy the extended warranty (will for my next tv!!!) but after many heated conversations with RCA..they agreed to pay for the part..I got stuck with the labor, atleast that was better than the whole bill. Anyway..starting to act up again..after only 5 months..bottom line..I'll never buy an RCA again!!
Oct 29, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCA Scenium M50WH187 50" HDTV Logo
317 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
