Question about Miele KFN8762SDED Bottom Freezer Refrigerator
Belling Bottom Freezer / Model; BK3593 / Type; HZS 3366
Hi Philtac, when purchased the house we purchased the appliances and we were not provided with manuals etc. I have been trying to sort out what is the best setting for the fridge e.g. 0 to 7 and whether or not the -/0 switch should be at - or 0...
Also, the freezer seems to frost up fairly rapidly and I am not sure if it is a frost-free unit or not as I do not have a manual. I would 'assume' that it is as most freezers now a days are...aren't they?
I also have ice drops formed on the back wall of the refridgerator. I again am 'assuming' that the fridge is approx. 7.5 yrs old.
Many thanks,
Shelley
  • 57 Answers
SOURCE: Back of Fridge icing up
If the fan is running you more than likely have a defrost problem.
look at the back wall of the freezer section if it is frosted up. it's not defrosting.
There three components in this system. The defrost heater, the defrost termination stat., and the defrost timer. Newer refrigerators do not have a timer per say it is build into a electronic board usually mounted on the back of the refrigerator under a metal plate. The termination stat is the cheapest part @ $ 25.00. The heater should run @ 50.00 to 70.00. The board could be as much as 200.00 or more. If the refrigerator is over 10 years old you may wish to look into getting a replacement. Appliances are designed to start failing after 10 years old.
My opinion.
If you unplug the refrigerator let it defrost then plug it back in. it will work properly about 3 days before it frosts back up.
Posted on May 18, 2008
  • 171 Answers
SOURCE: freezer is icing up and
Hi miss_i2000
I'm Harvey the Master Plumber
Your question is: freezer is icing up and fridge temperature has risen to 10 from 5. Also alot of condensation in the fridge and the fan doesnt seem to be working in fridge. Correct temperature on freezer -18 but ice. new frost free fridge freezer bought 1.5 weeks ago
This is no problem for you. You are under warranty and as long as you have not tryed to repair it yourself you are completely covered. Look for the manufacturer's warranty phone number on the paper work that came with it or call the sales man, he will be happy to track that down for you because he wants repeat business.
If you bought it used the only answer is to return it. You could get a local pro to repair it at yuor own expense but I wouldn't recomend that for a frige only 1.5 weeks old!
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 11, 2008
maklean
  • 1665 Answers
SOURCE: MIELE KFN8762SDED (SS/fridge/freezer)
Have a look at page 5 (KFN8767 Miele refrigerator) it may be similar. Exact model number didnt find.
http://www.miele.co.uk/Resources/OperatingInstructions/KFN%208767%20S%20ed-2.pdf
Posted on Sep 19, 2008
paulc118
  • 15 Answers
SOURCE: My Miele frost free fridge freezer is accumulating
Call Service. 1-800-999-1360 (US) or the Canadian number. Most likely the circulation fan and/or damper flap could be out of whack.
Posted on Jul 12, 2010
ginko
  • 19396 Answers
SOURCE: The Miele Fridge Freezer KFN8462S
Hi.
F2 indicates that there is a defrost problem. For this reason, if you turn off and defrost the fridge manually, the unit will work for a while after doing defrost.
You said that you replaced temperature sensor. What is called temperature sensor is different from the defrost thermostat, which is one of the parts involved in the fault.
If there is no defrost cycle, or if defrost is insufficient, problem is usually the defrost thermostat. The thermostat is located behind the freezer section rear wall, where the evaporator resides. To access it you need to remove frozen food and undo screws holding the back panel. The thermostat is a metal cylinder shaped object connected to two wires and clipped to the evaporator. The thermostat can be tested using a multimeter set on impedance. If reading impedance at room temp. on the thermostat contacts is infinity (circuit open),then the thermostat must be replaced. In the same way is tested the defrost heater. Check also that evaporator fan is starting.
If parts in the evaporator section are working, then the problem can be the defrost timer, which starts the defrost once every 8 hours.
Here how thermostat looks like. In same page read also the repair instructions from other users.
Regards.
Ginko.
Posted on Jan 25, 2011
Pizza maker BPZ500 used twice. Stored , now is tripping out the power board in our house when plugged in. Barely used. What can be done re replace, repair, refund ? Faulty electrics. Was a gift
If it is tripping the main rcd it indicates power is escaping from the circuit to ground but if it is tripping a micro circuit breaker (mcb) it indicates the appliance is consuming too much power, perhaps because of a short circuit.
Both conditions require attention - thorough investigation. Under the circumstances you described the first thing I thought of was it was perhaps subject to damp conditions or perhaps you made the mistake of washing the ceramic disc before you stored the appliance after the last usage. The disc is porous and would hold moisture.
If you suspect the problem could be moisture related the best thing would be to place the oven in a warm dry place with the lid open for a few weeks and try it again - you might be lucky.
As the item was a gift you have no contract with any retailer and therefore can't hold anyone responsible. Quite probably you don't have proof of purchase either which will be a complication for a warranty claim. If it is still covered by warranty perhaps the gifter will agree to sort it out for you or perhaps provide the proof of purchase so you can sort it for yourself..
The wiring and main components will be straightforward to check and your local white appliance engineer, electrician or skilled handyman will be able to do that for you.
Dec 30, 2017 | Dryers
My Liebherr CNes 3366 fridge freezer has started to build up ice in the bottom of the freezer. How do I check the fan in the fridge is working, (I never see it going)as it may be the cause? thanks r
remove cover and test with a meter or push door switch when door open and should hear fan hum or feel air when door open fan stops unless you push switch
Apr 20, 2017 | Liebherr Refrigerators
Where can I get a manual for an unidentified dishwasher?
Trick question?
Have you tried your local appliance store?
Jan 09, 2016 | Dishwashers
Need to know how to light the pilot. This is a year old house & builder did not leave the manual
Hi Alice:
Don't know whereyou are, but with a 1 year old appliance, you should have the manual.
Your local authorithy (Building Official at City Hall) should be able to access your property file and give you the info you need to be able to contact the appliance supplier (or builder) so that you can get the proper manual.
Seriously, the Builder has a safety obligation to provide that information.
And, you as the purchaser, have a right to expect it.
Please contact your local authority.
Cheers,
Ted (Retired Building Official)
Nov 08, 2015 | Heating & Cooling
What is causing ice buildup in bottom freezer
Can you provide a model number and Make? Example Let me know by answering my post here, Thanks John T.Appliance 911
Contact
Apr 29, 2015 | Maytag Refrigerators
Where can I obtain an operators manual? We just purchased our house and the stove came with it. The house was built about 1996. I need to set the clock which is analog.
Water Filters Lawn Garden Appliance Parts
This is a link to the Sears parts website and they frequently will have manuals that you can download for different appliances. You will need the model number so that you can put it into their search engine. Hope this helps!
Mar 08, 2015 | Kenmore 30 in. Electric Self-Clean...
Would like to purchase a manual forToshiba laptop I just purchased was last one in store it did not have manualfor operating etc. it is Toshiba model C655D-S52003GB memory, 320GB harddrive, Windows 7...
Welcome to Fixya. If you need the user guide or manual of your Toshiba Satellite C655D-5200 please click on the link provided below and click on the User's Guide tab.
Toshiba Satellite C655D-5200 Manual
Thanks
Sep 03, 2011 | Computers & Internet
Appears to be the condensation leaking into freezer bottom and leaking all over the floor. Drain has been thawed but leaking continues. Local dealer advised to get a fix kit from viking, but I have no...
Drain troth kit with clasp to fix defrost drain port and to program board for conventional defrost to 4 hrs run time. Viking parts dist has that available 8004889868
Aug 26, 2011 | Viking VCBB363L Bottom Freezer...
What temp should belling fridge freezer be set at. fan not coming on
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 30, 2011 | Belling BE810 Bottom Freezer Refrigerator
Miele KFN8762SDED Bottom Freezer Refrigerator Logo
234 people viewed this question
Top Miele Refrigerators Experts
Starnley Johnwells
Starnley Johnwells
Oloyede Monsuru
Are you a Miele Refrigerator Expert? Answer questions, earn points and help others
